In order to save code, I'd like to do for n...next n cicle using classic var(n) to deal with 10 or more variables with same process. But I don't know if it is possible.
Is there a way in pbpl of referring to a numbered var array so we can write and read variables? Arraywrite and arrayread I think can't do it, except somebody knows a trick in pbp or asm, because it would be necessary to get an item with its position number in the array.
Or at least, somebody could pass to the wish list for next version to make functions with parameters in and return, and getting items by its position.
Thank you
Luis J.
