Inicializing to Interrupt World
Results 1 to 6 of 6
    May 2012
    Default Re: Inicializing to Interrupt World
    Hello Mark and thanks for your answer, but it doesn't work...
    It happens the same thing, enter the first time, and after that, never enter in sleep again.
    I include the "On interrupt goto..." . In this case, the first time it works as expected, but after wakeup the first time, enter in loop in subprogram "Wakeup".
    If anyone coul help, i'm lost...
    Nuno
    Hi
    I dug up some old code I did on a pic16f819. Maybe it will help? I did not see Intcon.7 set in your code?
    Place this above your variable declaration
    OPTION_REG.6 = 0        'INTERUPT PORTB.0 ON 1 = RISING EDGE 0 = falling
    INTCON.4 = 1            'ENABLE RBO INTERUPT
    Sleep
    SLEEPLOOP:
        'OPTION_REG.7 = 0        'ENABLE PULLUP RESISTORS PORTB
        INTCON.7 = 1    'ENABLE GLOBLE INTERUPTS
    @ SLEEP             ;ASSEMBLY SLEEP COMMAND - TURNOFF uP CLOCK
        INTCON.7 = 0    'ON INTERUPT DISABLE GLOBLE INTERUPTS
        INTCON.1 = 0    'RESET INTERUPT FLAG
    Aug 2003
    I don’t know how PBP interrupts work, but yes you do have to clear the interrupt flag.
    if INTCON.1 = 1	then		' check if portb.0 interrupt occurred
    ‘ do the thing you wanted portb.0 interrupt to make happen
    INTCON.1 = 0			' clear portb.0 interrupt flag
    This is in a case where the interrupt could have been triggered by more than one event.
    May 2012
    Thanks everyone.
    The major problem, was a pull down button RB0, that was not working correctly.
    Nuno
  1. Hello World help please 18F14K50 config
    By Bonxy in forum mel PIC BASIC Pro
    Last Post: - 4th August 2011, 18:35
  2. Welcome into PIC world
    By shafi008 in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:51
  3. Remote Control World !
    By iugmoh in forum General
    Last Post: - 23rd April 2008, 00:03
  4. (noob)hello world?
    By m4gill4 in forum mel PIC BASIC
    Last Post: - 30th November 2007, 01:23
  5. wired world
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 6th February 2007, 17:23
