Dac1220
Results 1 to 5 of 5
Thread: Dac1220
    MikeTamu's Avatar
    MikeTamu Guest
    Hi, I don't have code for a DAC1220, but I do have code for a Max1270 which is a 12 bit A/D convertor with SPI interface. You can easily convert my code to match your application by comparing data sheets. Here is my code:
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2005 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 8/14/2005 *
    '* Version : 1.0 *
    '* Notes : *
    DEFINE OSC 10 'resonator frequency at 10 Mhz
    DEFINE LCD_DREG PORTB 'assign portb as data ports (DB4-DB7)
    DEFINE LCD_DBIT 0 'assign starting DB4 on portb.0
    DEFINE LCD_RSREG PORTB 'assign RS pin on portb
    DEFINE LCD_RSBIT 4 'assign RS pin on portb.4
    DEFINE LCD_EREG PORTB 'assign E pin on portb
    DEFINE LCD_EBIT 5 'assign E pin on portb.5
    DEFINE LCD_BITS 4 'set up 4 bit transfer lcd mode
    DEFINE LCD_LINES 2 'number of lcd screen display lines
    Pause 1000 ' Wait for LCD to startup
    'Variables
    rng var bit
    bip var bit
    channel var byte
    tval1 var word
    result var word
    newresult var word
    x var byte
    pd var byte
    xsee var byte
    pd0 var bit 'power mode variable
    pd1 var bit 'power mode variable
    c0 var channel.0
    c1 var channel.1
    c2 var channel.2
    clk var PORTC.6
    datin var PORTD.4
    csl var PORTC.7
    datout var PORTD.5
    Quanta5 CON 3125 'the sample conversion constant, (5/4095*256)*10000 for 0-5V
    Quanta10 CON 6251 'the sample conversion constant, (10/4095*256)*10000 for 0-5V
    Quantab5 CON 6251 'the sample conv. constant, (5/(4095/2)*256)*10000 for -5-5V
    Quantab10 CON 12503 'the samp. conv. const., (10/(4095/2)*256)*1000 for -10-10V
    Quanta var word
    negflag var bit
    'set up Max2710 pins
    TRISC.6=0 'output clk
    TRISD.4=0 'output datin
    TRISC.7=0 'output csl
    TRISD.5=1 'input datout
    pd0=1 'this sets normal power operation mode with external clock
    pd1=0
    'Inputs
    rng=1 'data conversion modes, see data sheet for max1270
    bip=1 'data conversion modes, see data sheet for max1270
    channel=0 'channel for conversion to read
    'Trial run
    loop:
    negflag=0 'reset the negative flag for lcd
    csl=1 'keep max2710 off till called
    clk=0 'keep clock low till ready
    gosub max1270
    if bip = 0 or result.11=0 then skiptwoscompliment 'skip if not in bipolar mode
    'if we come here then we are in bipolar mode not caught by above statements
    'or if the number is positive we skip this conversion as well
    negflag=1 'negative flag for use on lcd
    result=result-1 'subtract 1 to get to 1's compliment from 2's compliment
    'now we take the 1's compliment of result
    if result.0=0 then newresult.0=1
    if result.0=1 then newresult.0=0
    if result.1=0 then newresult.1=1
    if result.1=1 then newresult.1=0
    if result.2=0 then newresult.2=1
    if result.2=1 then newresult.2=0
    if result.3=0 then newresult.3=1
    if result.3=1 then newresult.3=0
    if result.4=0 then newresult.4=1
    if result.4=1 then newresult.4=0
    if result.5=0 then newresult.5=1
    if result.5=1 then newresult.5=0
    if result.6=0 then newresult.6=1
    if result.6=1 then newresult.6=0
    if result.7=0 then newresult.7=1
    if result.7=1 then newresult.7=0
    if result.8=0 then newresult.8=1
    if result.8=1 then newresult.8=0
    if result.9=0 then newresult.9=1
    if result.9=1 then newresult.9=0
    if result.10=0 then newresult.10=1
    if result.10=1 then newresult.10=0
    result=newresult
    'now we have the 2's compliment of a 2's compliment which is the real value
    skiptwoscompliment:
    'here we test for which constant to use in the conversion
    if bip=0 and rng=0 then Quanta=Quanta5
    if bip=0 and rng=1 then Quanta=Quanta10
    if bip=1 and rng=0 then Quanta=Quantab5
    if bip=1 and rng=1 then Quanta=Quantab10
    Lcdout $fe, 1 ' Clear LCD screen
    Lcdout DEC result
    result=result*/QUANTA
    result=result/100 'truncate 2 decimal places
    if negflag=1 then Lcdout $fe, $c0,"-"
    if negflag=0 then Lcdout $fe, $c0," "
    Lcdout $fe, $c0+1 'go to second row of lcd, 2nd position
    Lcdout DEC result DIG 2,".",DEC2 result
    LCDOUT " Volts"
    Lcdout $fe, $80+10
    Lcdout DEC result
    pause 330
    goto loop
    max1270:
    'start process
    csl=0 'cs going low starts the conversion process
    'start bit
    datin=1
    pulsout clk,1
    'channel select
    datin=c2
    pulsout clk,1
    datin=c1
    pulsout clk,1
    datin=c0
    pulsout clk,1
    'set rng
    datin=rng
    pulsout clk,1
    'set bip
    datin=bip
    pulsout clk,1
    'set pd1,pd0
    datin=pd1
    pulsout clk,1
    datin=pd0
    pulsout clk,1
    '5 clk pulse wait
    datin=0
    for x=0 to 4
    pulsout clk,1
    next
    'bring the data in
    result=0
    shiftin datout,clk,0,[result\12]
    pulsout clk,1
    Here is the data sheet for the Max1270: http://pdfserv.maxim-ic.com/en/ds/MAX1270-MAX1271.pdf
    gcoulondres's Avatar
    gcoulondres Guest
    Default dac1220
    Thank you for the code. I look at it.
    But I have to work for a job on this dac1220 because I must have a 20 bit digital to analog converter.
    MikeTamu's Avatar
    MikeTamu Guest
    All you have to do is modify what bits to send in order to access your DAC1220. Take a look at the signal bit trains in the DAC1220 data sheet. The SPI setup for the MAX1270 is similar.
