16F1828 HPWM and ADC
Results 1 to 20 of 20
    Jan 2014
    Default 16F1828 HPWM and ADC
    Hi guys,
    I have a strange problem with 16F1828 .
    So, I want to use AN6 (PORTC.2) to read a variable from 5k potentiometer . In main program if I use only HPWM2 , all works ok.
    If I add HPWM1 , on AN6 pin I have not a proportional voltage, like this pin is not analog input.
    Can somebody help me, please ? The last 2 days I spent my time to solve this problem, but no succes !
            __CONFIG _CONFIG1, _FCMEN_OFF & _FOSC_INTOSC & _WDTE_OFF & _MCLRE_OFF & _CP_ON & _IESO_OFF & _BOREN_OFF & _PWRTE_OFF
            __CONFIG _CONFIG2, _PLLEN_OFF & _STVREN_OFF & _LVP_OFF
    DEfine  OSC 4
    OSCCON = %01101010   'sets the internal oscillator to 4Mhz
    ADCON0 = %00000000
    ADCON1 = %00000000
    FVRCON = %11000010    'voltage reference set  to 2.048V
    CM1CON0 = 0   ' COMPARATORS OFF
    CM1CON1 = 0
    CM2CON0 = 0   ' COMPARATORS OFF
    CM2CON1 = 0
    CPSCON0 = 0   'CAPACTIVE SENSE MODULE OFF
    RCSTA.7 = 0   'SERIAL PORT OFF
    'APFCON0 = %10000000
    'APFCON1 = %00001010
    'APFCON1.3 = 1
    TRISA =  %00000011
    TRISB =  %00000000
    TRISC =  %00000100 ' PORTC.2 input
    ANSELA = %00000011
    ANSELB = %00000000
    ANSELC = %00000100 ' ANALOG INPUT AN6
    OPTION_REG.7 = 1 ' disable WPU
    WPUA =  %00000000
    WPUB =  %00000000
    WPUC =  %00000000
    porta = 0
    portb = 0
    portc = 0
    inh1    var  portc.4
    inh2    var  portc.0
    adval  var byte
    duty1  var byte
    duty2  var byte
    duty1 = 0
    pause 200
    '========================PROGRAM=============================
    adcin 6 , adval
    pause 10
    duty2 = adval
    hpwm 2 , duty2, 2000
    hpwm 1 , duty1, 2000 '- here is problem
    high inh1
    high inh2
    1000 x thx
    Jan 2014
    Default Re: 16F1828 HPWM and ADC
    ..or a simple way to see where is the problem (PORTC.2 is not set ADC) !
    Datasheet 16F1828
    http://ww1.microchip.com/downloads/e.../40001419F.pdf
    DEfine  OSC 4
    ADCON0 = %00000000
    ADCON1 = %00000000
    CM1CON1 = 0
    CM2CON1 = 0
    'APFCON1.3 = 1
    TRISA =  %00000011
    TRISB =  %00000000
    ANSELA = %00000011
    ANSELB = %00000000
    WPUA =  %00000000
    WPUB =  %00000000
    WPUC =  %00000000
    porta = 0
    portb = 0
    portc = 0
    inh1    var  portc.4
    inh2    var  portc.0
    adval  var byte
    duty1  var byte
    duty2  var byte
    duty1 = 0
    pause 200
    adcin 6 , adval ' AN6(PORTC.2) is not ADC ?
    pause 10
    duty1 = adval
    high inh1
    high inh2
    which thing doesn't work
    no output on cp1 (portc.5) ?
    or
    adcin 6 yields an incorrect result ?
    can I suggest try
    duty1 = 128
    is there an output ?
    and
    adcin 6, adval
    debug #adval
    is there a realistic result ?
    Jan 2014
    HPWM 1, 128, 1000 - I have a output
    ADCIN 6 give me a incorrect result.
    If I use ADCIN 6 with any HPWM (2,3,4) , I have correct ADC input, also correct PWM output.
    Jan 2014
    This code work perfectly :
    adcin 6 , adval
    pause 10
    duty1 = adval
    hpwm 2 , duty1, 2000
    high inh1
    high inh2
    try setting the pwm manually (the frequency will be way off ) but its worth a try
     t2con=4
        PR2 = 255
        CCPR1L = adval             ;set pwm
        ccp1con=12
    I don't have a 16f1828 to test with , I do not think your code is incorrect but at this stage that's all I can offer
    just noticed you have no adc defines
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 100
    could help, they should be included anyway
    ADCON1 = %00000000
    you are setting the frv (ps bit 6 of fvrcon is read only) but never connecting it to the adc module .
    to use the fvr as ref you need to set adcon1 bits 0 & 1 to 1
    you have also selected a conversion clock of fosc/2 which @4mhz is out of specs
    you need fosc/4 or rc clock for adc
    Jan 2014
    If I add HPWM1 line, I have not correct ADC input
    Here AN6 pin is not ADC input:
    adcin 6 , adval
    pause 10
    duty1 = adval
    hpwm 1 , 128, 2000
    high inh1
    high inh2
    Jan 2014
    Thank you very much for your help ,Richard !
    I made the changes, but now CCPR1L = 0
    Define  OSC 4
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    ADCON0 = %00000000
    ADCON1 = %00000011
    FVRCON = %10000010     'voltage reference set  to 2.048V
    CM1CON1 = 0
    CM2CON1 = 0
    'APFCON1.3 = 1
    TRISA =  %00000011
    TRISB =  %00000000
    ANSELA = %00000011
    ANSELB = %00000000
    WPUA =  %00000000
    WPUB =  %00000000
    WPUC =  %00000000
    porta = 0
    portb = 0
    portc = 0
    inh1    var  portc.4
    inh2    var  portc.0
    adval  var byte
    duty1  var byte
    duty2  var byte
    duty1 = 0
    t2con=4
    PR2 = 255
    ccp1con=16
    pause 200
    adcin 6 , adval
    pause 10
    duty1 = adval
    high inh1
    high inh2
    ccp1con=16 is incorrect, that is just nothing
    ccp1con=12 ; pwm mode
    if adval= 0 then yes it would
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    ADCON0 = %00000000
    ADCON1 = %00000011
    ADCON1 = %00000011 ; this line just destroyed all your defines
    ADCON1 = ADCON1 | %00000011 ; will set bits 0 and 1 without wrecking the others
    Jan 2014
    Thx Richard, now I understand.
    Now, AN6 work corectly. The value of CCPR1L is 2 x adval. If I divide adval to 2 , exist a little diference betwen PWM1 and PWM2 on outputs (~ 0,8 units)
    t2con=4
    PR2 = 255
    ccp1con=12
    pause 200
    adcin 6 , adval
    pause 10
    CCPR1L = adval/2            ;set pwm
    duty1 = adval
    high inh1
    high inh2
    some more things to consider
    1.
    Many devices allow a selection of Timer resource for some or all of the PWM
    channels. The HPWM command will automatically determine the preset Timer
    selection upon execution. Note that PWM channels that share a single timer may
    not operate at independent output frequencies. While duty-cycle settings are
    always independent from one channel to the next, independent frequency settings
    require independent timer resources.
    you have not set any individual timer resource options [ CCPTMRS0 ]
    so
    t2con=4
    PR2 = 255
    settings get overwritten by use of
    2.
    you have not specified how your "pot" is connected , if its connected between vdd an ground then use of a fvr of 2.048 v is totally inappropriate and
    may even damage your chip. analogue in voltage should never exceed vref
    3.
    all your trouble was probably caused by incorrect adc settings , hpwm1 should now work
    Jan 2014
    My potentiometer is connect between +5v and gnd.
    I can not understood why I had some troubles because :
    1. I used AN0 or AN1 and HPWM(1-4) worked perfectly
    2. I used AN6 , so HPWM2 worked perfectly(AN6 analog input ok) ! , but when I added HPWM1 , the HPWM2 not worked because I had not a analog input. I suposed that exist a conflict between AN6 and HPWM1.
    Now, HPWM1 work . AN6 work but here is some trouble, I have analog input but after some time toggle itself on digital input !
    Now I read carefully in datasheet and I'll post the code.
    Its clear that I'm begginer in pbp, all my projects are for hobby. Richard, you explained me step by step and I start to understand some "secrets" about settings. Thank you very much for patience!!
    Jan 2014
    I'm very confused.
    I think that settings are ok, but some its very strange. I changed the PIC with another one, but the same results.
    PIC config & settings :
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    ADCON0 = %00000000
    ADCON1 = %00000000
    FVRCON = %00000000
    CM1CON1 = 0
    CM2CON1 = 0
    TRISA =  %00000011 'PORTA.0 and PORTA.1  set Input
    TRISB =  %00000000
    TRISC =  %10000100 ' PORTC.7 and PORTC.2 input
    ANSELA = %00000011 ' AN0 and AN1 set analog
    ANSELB = %00000000
    ANSELC = %00000100 ' AN6 set analog
    OPTION_REG.7 = %00000001 'WPU enable ; Fosc/4; Prescaler 1/4
    WPUA =  %00000000
    WPUB =  %00000000
    WPUC =  %10000000 ' enable WPUC.7
    porta = 0
    portb = 0
    portc = 0
    inh1    var  portc.4
    inh2    var  portc.0
    adval  var byte
    duty1  var byte
    Here work all 4 HPWM:
    adcin 0 , adval '(or adcin 1 , adval)
    pause 10
    duty1 = adval
    hpwm 3 , duty1, 2000
    hpwm 4 , duty1, 2000
    Here works fine HPWM(2,3,4):
    adcin 6 , adval
    pause 10
    duty1 = adval
    Here AN6 toggled to digital input (why ??):
    adcin 6 , adval
    pause 10
    duty1 = adval
    I tried to set manually all 4 CCP , frequency doesn't matter (2-4khz is enough for me) , maxim duty cycle measured with a osciloscope is 99,7 % . What is very strange , after some time, the AN6 toggle from analog to digital input. I hope that manual settings are ok.
    T2CON = %00000100 ' Timer2 ON
    PR2 = 255
    CCP1CON = %00001100
    CCP2CON = %00001100
    CCP3CON = %00001100
    CCP4CON = %00001100
    pause 200
    adcin 6 , adval
    pause 10
    CCPR1L = adval
    CCPR2L = adval
    CCPR3L = adval
    CCPR4L = adval
    So, If I add HPWM1 in main program , AN6 toggle instantly from analog input to digital input. If I set manual CCP , AN6 toggle from analog to digital after some time.
    I tried with 16F1938 , the same program, with different analog inputs and all work ok.
    Hi, Midali
    I do not see much config lines for your CCP Modules ...
    'APFCON1.3 = 1
    being commented out ... ( I did not check if correct )
    as AN6 is shared by the CCP outputs and your ADC input ...
    unfortunately, I do not have those 16F18xx chips here to verify.
    did you try with another ADC input ( not CCPx related ), AN10 or 11 i.e. ???
    Jan 2014
    First time when I used HPWM ,I configured the APFCON to "APFCON1.3 = 1" but no succes.
    Now I set manually the CCP and APFCON1.3 = 1, all its ok! AN6 work perfectly ! I want to play with it more time because I want to be sure that all its ok.
    Also, I tried again with HPWM and some APFCON configs, but the same problems : AN6 is digital input or AN6 toggle from analog to digital input.
    I'll try to test with AN10 or An11 , but will be a little hard because my pcb is make ready .
    Thank you very much Alain...
    Jan 2014
    Conclusions :
    1. I tested with AN10 and ADC work perfectly with HPWM. Also, works well with AN0 and AN1.(another ADC I not tested)
    2. ADC on AN6 pin work perfectly if I config APFCON1.3 = 1 and manually set for CCP.
    3. I think that all troubles was from PIC revision...may be I'm wrong
    4. I'll modify my PCB and I'll use AN10 ( this pin is near AN6)
    5. In my opinion , is the best if avoid to use PORTC.2 (AN6) .
    6. I prefer to work with HPWM because I can set very easy the freq and duty cycle .
    Thank you again to Richard and Alain for your help!
  1. ADC values above 4095 for 12 bit ADC
    Last Post: - 1st February 2015, 22:24
  2. ADC problem on 18F46K22 device using all 28 ADC pins
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:22
  3. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  4. Newbie HPWM / ADC question
    By Johan in forum mel PIC BASIC Pro
    Last Post: - 25th June 2007, 12:52
  5. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
