Serial help
Results 1 to 4 of 4
Thread: Serial help
    Default Re: Serial help
    Never used one of those and I don't quite understand what "nothing happens" actually means. Are you saying that you have data on the screen but when executing the Clear Screen command the screen does not clear?
    Anyway, the PBP equivalent of the following Arduino code
    Serial.write(0x76);  // Clear display command, resets cursor
    Serial.write(0x01);  // Hex value for 1, will display '1'
    Serial.write('2');   // ASCII value for '2', will display '2'
    Serial.write(0x0A);  // Hex value for 10, will display 'A'
    Serial.write('B');   // ASCII value for 'B', will display 'b'
    would be something like:
    SEROUT2 PortB.3, 84, [$76]  'Clear the display
    SEROUT2 PortB.3, 84, [$01, "2", $0A, "B"]   ' Display 12AB
    What if you try:
    For i = 0 to 1000
    SEROUT2 PortB.3, 84, [$76, DEC4 i]
    PAUSE 1000
    NEXT
    Jan 2012
    Grid EN19MV
    Thanks Henrik. I looked over what I wrote, and I was tired at the time. Yes, what I meant was that clear screen did not work, but if I sent decimal numbers, they showed up in the display. I am at work and will try your suggestions tonight.
    Andy
    -Stephen Hawking
    Jan 2012
    Grid EN19MV
    Thank you so much Henrik. Your knowledge has once again saved me and I understand it now.
    Works great!
    -Stephen Hawking
