How to enable two interrupts?
Results 1 to 4 of 4
    Default Re: How to enable two interrupts?
    Hi again,
    I'm taking a stab at a possible solution to my own problem:
    Of course there cannot be two interrupt handlers. So, within the single handler a test could be made to determine which of the two interrupt flags is set. Then, based on that test, branch to the appropriate handler steps for that interrupt. All within one handler.
    Oct 2009
    Utah, USA
    Dick,
    I think your on to the right answer...
    Here is what I did to detect between a timer overflow vs a button push with a 12f683
    MyInt:
      inttype = PIR1 & %00000001  'check if timer1 overflow occured
      if inttype = 1 then goto TimerInt
      goto buttonint  'interrupt was gpio.3
    then i clear the interupt flag here...
    ExitInt:
       intcon.0 = 0
       PIR1.0 = 0
       resume
    enable
    Dwight
    That is correct. That is what the interrupt flags are for, to allow the interrupt routine determine which interrupt occured.
    EN82fn
  1. Disable/Enable DT interrupt
    By aratti in forum PBP3
    Last Post: - 16th June 2018, 17:50
  2. Disable/Enable in Interrupts
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 15th June 2015, 08:47
  3. DT_INTS-14 /interrupts enable bits / flag bits
    By bogdan in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 19:42
  4. Enable and Disable in Interrupts
    By stevecrunch in forum mel PIC BASIC Pro
    Last Post: - 30th October 2007, 02:10
  5. ENABLE command not always mandatory?
    Last Post: - 23rd October 2006, 19:11
