Interfacing microcontroller into wifi module or wifi adapter...
Results 1 to 23 of 23
    Dec 2005
    Default Re: Interfacing microcontroller into wifi module or wifi adapter...
    I didn't mention it because I was unaware of it. I doubt the C stack is a necessity but have not looked at whether it's inputs/outputs are documented sufficiently to use with other languages/chips. The price is good ($30 at Mouser). It's surface mount which makes it tough to breadboard.
    From the data sheet:
    The MRF24WB0MA/MRF24WB0MB modules are designed to be used with Microchip’s TCP/IP software stack. The software stack has an integrated driver that implements the API that is used in the modules for command and control, and for management and data packet traffic.
    The Microchip TCP/IP software stack is available in the free Microchip Application Libraries download (including example applications and source code) from the Microchip web site, http://www.microchip.com/wireless
    The combination of the module and a PIC running the TCP/IP stack results in support for IEEE Standard802.11 and IP services. This allows, for example, the immediate implementation of a wireless web server.
    It is breadboard able with thin lead wires soldered to each MRF24WB0M connection and at the other end a short length of a clipped resistor lead to connect to the breadboard.
    Norm
    Nov 2011
    Sir do you have a schematic in minisocket iwifi to max232 to rs232?...tnx
  1. New WiFi Module
    By dhouston in forum WiFi
    Last Post: - 15th February 2017, 10:27
  2. Serial WiFi module
    By Art in forum WiFi
    Last Post: - 6th December 2015, 04:50
  3. RN 171 WiFi module
    By Pimentel in forum WiFi
    Last Post: - 20th August 2014, 08:47
  4. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 04:19
