Interfacing microcontroller into wifi module or wifi adapter...
Results 1 to 23 of 23
    Dec 2005
    Default Re: Interfacing microcontroller into wifi module or wifi adapter...
    Datasheet for the Rabbit Semiconductor 20-101-1309
    However, that has no application with PicBasic Pro nor even with a PIC as it includes its own microcontroller and is programmed in a dialect of C.
    Where are you located? Mouser has branches worldwide so you may be able to find the ConnectOne device through one of those branches.
    Nov 2011
    I am from philippines..I tried the mouser and avnet but they refuse because of delivery and minimum order sir..is there any ways?
    Dec 2005
    Then your best bet is the WIZ610wi which you can buy online from Wiznet directly for $35US.
    It is through-hole but the pins are on 1.27mm centers so you cannot use it with a breadboard. To test with a PC, use the Sparkfun adapter I referenced earlier
  1. New WiFi Module
    By dhouston in forum WiFi
    Last Post: - 15th February 2017, 10:27
  2. Serial WiFi module
    By Art in forum WiFi
    Last Post: - 6th December 2015, 04:50
  3. RN 171 WiFi module
    By Pimentel in forum WiFi
    Last Post: - 20th August 2014, 08:47
  4. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 04:19
