RN 171 WiFi module
Results 1 to 11 of 11
    Dec 2006
    Brasil, Sao Paulo, Campinas
    Default RN 171 WiFi module
    Hi all,
    Somebody alread used the RN171 wifi module with PBP?
    I am working with this module but using a C code for while. I would like of to use basic to config it. I will apreciate some example code about it to use as basis.
    Pimentel
    Default Re: RN171 wifi module
    a search with "rn-171 " gets a few hits
    Feb 2004
    Michigan, USA
    Rather than starting a new thread, I'll tack on to the bottom of this one.
    I have a RN 171 connected to a 18F2550. I can receive commands via usb and serout them to the RN 171 but I'm not getting a response. I can see data to and from the RN 171 but I cant get it to load in to a variable using serin. I've seen a few examples of this issue on the forum but no one documented how they fixed it.
    serout  PORTC.6,2,[text, text1, text2]
    serin PORTC.7,6,2000, main1, [wifi]
    WRITE 50, wifi.0
    write 51, wifi.1
    write 52, wifi.2
    write 53, wifi.3
    write 54, wifi.4
    write 55, wifi.5
    write 56, wifi.6
    write 57, wifi.7
    ARRAYWRITE USBTXBuffer, [wifi]
    GOSUB WaitToSend
    Note that I used mode 2 for serout and mode 6 for serin. If I use mode 2 for serin, it times out and jumps to my "didnt get any data" routine at main1. Currently, using mode 6, wifi is full of 0's and it repeats the loop sending text1, text2, text3 again.
    Jun 2009
    Sc*nthorpe, UK
    Do not include [ ] for serin item as these are used around a qualifier.
    Feb 2004
    Michigan, USA
    Nice catch.
    However I only get 1 byte so in looking at the manual I need to use SERIN2 with the STR qualifier. Awesome I think, then I modify the code to the following and now I get nothing again. It hangs at SERIN2 until the time is up then it jumps to my loop again. Wifi is defined as BYTE[16]
    serin2 portc.7,84,250, main1, [STR wifi\16]
    WRITE 50, wifi.0
    write 51, wifi.1
    write 52, wifi.2
    write 53, wifi.3
    write 54, wifi.4
    write 55, wifi.5
    write 56, wifi.6
    write 57, wifi.7
    write 58, wifi.8
    write 59, wifi.9
    write 60, wifi.10
    write 61, wifi.11
    write 62, wifi.12
    write 63, wifi.13
    write 64, wifi.14
    write 65, wifi.15
    serin2 portc.7,84, [STR wifi\16]    'wait here till 16 total bytes rcvd
    'now, 16 bytes are in wifi array starting at wifi[0]
    'toggle led or something to tell you got 16 new bytes
    continue on....................
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by jmgelba View Post
    Nice catch.
    WRITE 50, wifi.0
    write 51, wifi.1
    write 52, wifi.2
    write 53, wifi.3
    write 54, wifi.4
    write 55, wifi.5
    write 56, wifi.6
    write 57, wifi.7
    write 58, wifi.8
    write 59, wifi.9
    write 60, wifi.10
    write 61, wifi.11
    write 62, wifi.12
    write 63, wifi.13
    write 64, wifi.14
    write 65, wifi.15
    Serin2 is waiting for 16 characters to be received if you do not send 16 characters it will eventually time out. This is a common issue with serial communication however SERIN2 gives you the "tools" to overcome this.
    I use a start character to indicate the start of a command string and an end character as a termination, which is not unusual. A commonly used start character is "!" and end character is $0D (CR). You could follow the LCDOUT protocol and use $FE as the start character the choice is yours.
    Having decided which start and end characters to use modify your code and obviously include the start and end characters in the string you are sending.
    serin2 portc.7,84,250, main1, [WAIT("!"),STR wifi\16\%0D]
    WRITE 50, wifi.0
    write 51, wifi.1
    write 52, wifi.2
    write 53, wifi.3
    write 54, wifi.4
    write 55, wifi.5
    write 56, wifi.6
    write 57, wifi.7
    write 58, wifi.8
    write 59, wifi.9
    write 60, wifi.10
    write 61, wifi.11
    write 62, wifi.12
    write 63, wifi.13
    write 64, wifi.14
    write 65, wifi.15
    Sep 2009
    jmgelba,
    It's not clear to me what you are trying to do with write command....
    WRITE 50, wifi.0 - this will write only one bit, just 0 or 1
    WRITE 50, wifi[0] - this will write only byte from array
    I was going to say the same thing. Misuse of the indexing modifier. Byte indexing should use "[x]" and bit indexing should use ".x"
    EN82fn
    Feb 2004
    Michigan, USA
    I cant assign a start and end character because the module returns many different responses depending on circumstance and they can be different lengths.
    I did indeed screw up the bit vs byte indexing, and this is what is causing my issue with this test code. I made the changes and I can now write the bytes to EEPROM which I can read. I now have to figure out how to send those bytes as a string out the USB port, unless I do they byte to text conversion on the PC side.
    Jun 2009
    Sc*nthorpe, UK
    I cant assign a start and end character because the module returns many different responses depending on circumstance and they can be different lengths. I now have to figure out how to send those bytes as a string out the USB port, unless I do they byte to text conversion on the PC side.
    Can you give examples of the responses is there a common termination character?. On the PC side ASCII characters are usually the default. So I guess you are sending ASCII characters from the PC to the PIC over USB which is then transmitted to the wifi module. Does the wifi module respond with ASCII characters?
  1. New WiFi Module
    By dhouston in forum WiFi
    Last Post: - 15th February 2017, 09:27
  2. Serial WiFi module
    By Art in forum WiFi
    Last Post: - 6th December 2015, 03:50
  3. PIC with WIFI module
    By JAWORSKI in forum Schematics
    Last Post: - 3rd December 2008, 03:19
