a problem RF Signal with PULSIN
Results 1 to 7 of 7
    What is your transmited signal? What baud rate? How many bits?
    Are you transmiting with some kind of Serout like command?
    Jul 2005
    I solved it by TMR0 and I changed the RF pin. The pin was PortA.0 but I cannot get any signals from here. Then I decided to chage port and the new port was PortC.5. And the result was Ok. I could read signals. Why I didnt read any signals from PortA.0 ? (16F876) Does anybody has an idea? Thank you so much again.
    PORTA on the F876 is configured to A/D inputs by default on power-up due to
    the default value in the ADCON1 register on power-up.
    ADCON1 = 7 ' configures A/D pins as digital I/O.
    Also, PORTC.5 is a schmitt trigger input. RA0 is TTL.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  2. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  3. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. problem with RF receiver
    By nanami7702002 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2005, 22:55
