a problem RF Signal with PULSIN
Results 1 to 7 of 7
    Wink
    Hi, Muskut
    You're new with PBP ... that's the worst reason I ever heard to ask for a "ready cooked" solution !!!
    I think the first thing you should do is understand what the different functions do and how they do it.
    For that first step, reading carefully the manual is not too much ... see what RCTime can do for you and we will be talking about that one next time.
    Learning is NOT a shame, it's the beginning of intelligence ... begging might be prohibited here !!!
    What is your transmited signal? What baud rate? How many bits?
    Are you transmiting with some kind of Serout like command?
    Jul 2005
    I solved it by TMR0 and I changed the RF pin. The pin was PortA.0 but I cannot get any signals from here. Then I decided to chage port and the new port was PortC.5. And the result was Ok. I could read signals. Why I didnt read any signals from PortA.0 ? (16F876) Does anybody has an idea? Thank you so much again.
    PORTA on the F876 is configured to A/D inputs by default on power-up due to
    the default value in the ADCON1 register on power-up.
    ADCON1 = 7 ' configures A/D pins as digital I/O.
    Also, PORTC.5 is a schmitt trigger input. RA0 is TTL.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  2. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  3. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  4. Replies: 11
    Last Post: - 13th July 2005, 20:26
  5. problem with RF receiver
    By nanami7702002 in forum mel PIC BASIC Pro
    Last Post: - 31st January 2005, 22:55
