srange warning
Results 1 to 11 of 11
Thread: srange warning
    Default srange warning
    Hi all!
    Can anyone explain why and how such a warning is possible:
    Warning[219] C:\pbp\pbppi14e.lib 937 : Invalid RAM location specified.
    I have commented out a lot but can't figure out what causes that
    Thank you in advance
    keymuu
    Default Re: srange warning
    Which version of PBP?
    Which device are you targeting?
    Which version of MPASM?
    Can you post the code?
    Hi Henrik,
    my PBP is 2,60C and the code is:
    TMPaddr  CON %1001110  ' the address to TMP100
    LCDaddr  con $20       ' the address to LCD
    cont     con $A0       ' for I2C READ and WRITE, NOT for any other use
    TRUE     con 1         ' or HIGH
    FAlSE    con 0         ' or LO
                           'LCD
    firstL   con $80       ' LCD first (1) line  (page 107 PICBASIC PRO book)
    secondL  con $C0       ' LCD second (2) line
    thirdL   con $94       ' LCD third (3) line
    fouthL   con $D4       ' LCD fourth (4) line
    home     con $02       ' LCD return home
    clearD   con $01       ' LCD clear display
    offC     con $0C       ' LCD cursor off
                           'PORTA.x
    dataPort var PORTA.0   ' I2C data port
    clkPort  var PORTA.1   ' I2C clock port
    RELE     var PORTA.2   ' OUT- RELE, or TIP120 (darlington) that drives the rele
    LEDs     VAR PORTA.3   ' OUT- Lo (GREEN) Hi (RED)
    goDOWN   var PORTA.4   ' IN- or SET DOWN one step (target)
    goUP     var PORTA.5   ' IN- SET the temperature UP (target)
                           'TEMP and TIME
    changeTEMP var byte    ' how much TEMPERATURE (TARGET)
    changeTIME var byte    ' how much TIME (TARGET)
    changeTEorTI   var bit ' is there a need to change TIME or TEMPERATURE (TARGET)
    nowTEMPERATURE var byte' update TEMPERATURE only NOT TIME
    nowTIME   var byte     ' ready to change TIME not TEMPERATURE
    tempREAD  var byte     ' the real water temperature
    tempSET   Var byte     ' the temperature goal or set temperature
                           'FALSE is the active state for the nexts command flags:
    markUP    var bit      ' temporary mark remembers wich one is active
    markDOWN  var bit      ' temporary mark
    b         var byte     ' general index
    temp      var byte     ' temperary variable
                           'Next LCD stuff, here under, 4 lines
    tempData  var word     ' Temperature data
    timeData  var word     ' Time data
    hour      var byte
    minut     var byte
    second    Var byte    ' Define display hour variable
    minute    Var byte    ' Define minute variable
    ticks     Var byte    ' Define pieces of seconds variable
    update    Var byte    ' Define variable to indicate update of LCD
    '12345678901234567890'    LCD has 20 places for characters
    INTCON = $a0     ' Enable TMR0 interrupts
    writeLCD         ' general write to LCD
      i2cwrite dataPort, clkPort, cont, $FE, secondL, tempdata' the real temperature
      i2cwrite dataPort, clkPort, cont, $FE, thirdl,  timedata' write the real time
    return ' writeLCD
     writeFirstLineLCD           ' when the user has changed from TEMP to TIME or vs
       if nowTIME = true then    ' first line tells wich will change TEMP or TIME
         i2cwrite dataPort, clkPort, cont, $FE, firstl, "       Time         "
       else' nowTEMPERATURE
         i2cwrite dataPort, clkPort, cont, $FE, firstl, "    Temperature     "
     return  ' writeFirstLineLCD
    '======================end=LCD==================================================
    Debounce
       For b = 1 To 100     ' Debounce and delay for 100ms
         Pause 1 ' 1ms at a time so no interrupts are lost
       Next b
    SET                     ' set a TARGET for TIME or TEMPERATURE
      if nowTIME = true then                   ' is the time or perhps not?
            if goUP = true then                '
              changetime = changetime + 1      ' increase the time with one
              markup = true : markdown = false '
            else                               '
              changetime = changetime - 1      ' decrease the time with one
              markDOWN = true : markup = false '
            endif                              '
            nowTIME = true : nowTEMPERATURE = false ' use TIME
      else ' nowTEMPERATURE                    ' if not TIME then TEMPERATURE
              changeTEMP = changeTEMP + 1      ' increase the temp with one
            else                               '
              changeTEMP = changeTEMP - 1      ' decrease the temp with one
              markdown = true : markup = false '
            endif                              '
            nowTEMPERATURE = true : nowTIME = false ' use TEMPERATURE
    return 'SET
    ' this is like an interrupt routine, however, it is not an interrupt routine,
    ' so it is just a normal sub routine
    longPress ' if up/down is pressed for about 5 sec change from TEMP to TIME or vs
     ' First we have to decice is UP or DOWN pressed
       if (goUP = true) and (goDOWN = true) then return ' NOT pressed anything
                                                        ' not UP or DOWN
       if goUP = false then         ' IF upwards is active
         gosub Debounce
         for b = 1 to 5             ' every round takes 1 second
           if goUP = true then return    ' end if not pressed anymore
           pause 1000            ' wait for 1000 ms and the total will be 5 seconds
           markup = true : markdown = false ' also mark it UP
         next b
       else                           ' IF downward is active
         gosub Debounce
         if goDOWN = true then return ' it is not time to change the TIME or TEMP
         for b = 1 to 5                  ' the total will be 5 seconds
           if goDOWN = true then return  ' end if not pressed anymore
           markdown = true : markup = false ' also mark it DOWN
         next b
                      ' FALSE is active state, i.e. button pressed UP
           if (markup = true) and (b = 5) then
              changetime = changetime - 1   ' compensate the UP press
           endif    ' FALSE is active state, i.e. button pressed DOWN
       if (markdown = true) and (b = 5) then
         changetime = changetime + 1    ' compensata the DOWN press (possible long)
                     ' if b=5 then we will change from TEMP to TIME or TIME to TEMP
                     ' time has elapsed for 5 seconds
       if b = 5 then toggle changeteorti 'do the change from TEMP to TIME or vs
       gosub SET ' change (TIME to TEMP) or (TEMP to TIME)
       gosub writeFirstLineLCD
    return ' longPress                                                       ' L378A
    '======================end=longPress============================================
    checkIFpressed        ' check if pressed and also mark if it is UP or DOWN
                          ' and act to that
      if goup = true then                      ' first check UP
        markup = true  : high rele : high leds ' and act to that
      else                                     ' else it is false
        markup = false : low rele : low leds   ' and act to that
    return ' chekIFpressed                     now we know if it is UP or DOWN also
    readTEMP              ' Read the REAL water temp to readTEMP
      i2cread dataPort, clkPort, cont, TMPaddr, tempRead
      if tempRead < tempSet then   ' Check where the real temperature is
        changeTeorti = true        ' set the heat ON
        changeTeorti = FALSE       ' or OFF. But not here, IT HAPPENS LATER
    return 'readTEMP               ' now we know, shall we HEAT or NOT HEAT
    input  PORTA.5   :  input PORTA.4  ' UP and DOWN, the only button
    output PORTA.3   : output PORTA.2  ' 3=LEDs (green and red), 2=TIP120-> RELE
    changetime = 60  : changetemp = 60 ' initial values for TIME and TEMP (60 & 60)
       Pause 500                       ' Wait for LCD to startup
       hour = 0                        ' Set initial time to 00:00:00
      minute = 0
      second = 0
    mLoop: ' the main Loop                                                           writeLCD
          markup = false : markdown = false   ' mark them FALSE for next round       writeToLCD
      changeTEMP = false                      ' Let's assume it is not pressed       Debounce
      changetime = false                      ' and this also                        SET
                                              '                                      longPress
      gosub readTEMP   ' read the temp and check if the SET temperature has changed  checkIFpressed
      gosub checkIFpressed  ' the changeTEorTI will perhaps have a value             readTEMP
                        ' next we do a fake interrupt call
      gosub longPress   ' check if there is a need to change from TEMP to TIME of vs
    '  i2cwrite dataPort, clkPort, cont, lcdaddr, temp    ' write the LCD
    goto mloop ' keep on looping
    the processor is PIC12LF1552 but I don't have it yet, and the program is far from ready
    and it is not so nice to have a warning like floating around, it could be a symptom of something
    more problematic.
    keymuu
    Your code compiles fine for a 12LF1552 using PBP 3.0.8.4 and MPASM 5.45.
    I don't have 2.6C available to try with but it seems as if the warning is thrown by the assembler and not by the compiler. Googling a bit further suggests that the problem might be due to a corrupt or incompatiable .inc file for the device (that would be the .inc file in the MPASM folder, not in the PBP folder).
    You didn't say which version of MPASM you're using but I'd try updating or re-installing MPLAB. I'm attaching the p12LF1552.inc file from my MPASM installation (renamed to .txt to able to upload it). You could try replacing yours with this one and see if it helps.
    Dec 2010
    Are you sure you chose the correct device to compile for? I saw this once when I accidentally changed devices and the new choice had less ram.
    Hi !
    I don't know where I can see the version of MPASM.
    I use under (at the moment) 600 words when there is 2k in PIC12LF1552.
    And I will upgrade to PIC 3.0 very soon and I suspect that it can be a
    question of something that is amended in the latest version.
    keymuu
    You can see which version of MPASM you're using in the progress window during the assembly process:
    If, for some reason you don't see that you can always start the MPASM GUI application (MPASMWIN.exe) in the MPASM installation folder and see it there:
    Yes but are you sure that you're actually compiling for the 12LF1552 and not for another device, by mistake. Are you using MicroCodeStudio, do you have the 12LF1552 selected in the dropdown list?
    Before you upgrade to PBP3 (which I highly recommend anyway) you can try replacing the MPASM .inc file with the one in my previous post. Make sure you save the old one.
    Hello,
    the version of MPASM is 5.39
    kind regards
    keymuu
    Then I'd try an update of MPLAB.
    Go here and download a new version. I'm currently on v8.85 but I'd grab the last v8 there is (v8.92).
    Hi!
    I have now PBP 3.08 and MPLAB is something like 8.95, but I have a problem,
    my PBP3 is a "Trial Edition" and I don't understand why.
    When I installed PBP3 I did NOT check the empty checkbox between PBP3 and
    MPLAB not so far from the beginning of the installation.
    Maybe this is not the correct place for this question, if not then where should
    i address my question, to who or to what instans.
    keymuu
    Did you buy the upgrade from MeLabs or did you just download PBP3 from their website?
    If you bought the upgrade you should've received your personal activation code. Run the PBP Activation Manager to activate your license.
    If you did not buy the upgrade well, then that's the reason for it being trial.
  1. Warning !
    Last Post: - 18th November 2010, 21:06
  2. Warning and Message
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 10th September 2009, 17:57
  3. Mplab 8.20 warning
    By Acetronics2 in forum General
    Last Post: - 28th January 2009, 23:55
  4. Warning[202]
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 24th October 2008, 18:41
  5. warning message
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 03:53
