Truncated Core Size Messages For 18F26K22 ?
Results 1 to 6 of 6
    Dec 2012
    Türkiye
    Default Re: Truncated Core Size Messages For 18F26K22 ?
    I just copied some LCDOUT special character line over and over again in order to test the IDE .. and the code has reached to 129010 bytes .. But it still compiles succesfully even though it has exceeded the max. flash memory range ... Is such a thing possible ?
    - Ipsa scientia potestas est -
    I believe that the final code size is returned by the assembler and not by the compiler.
    Since some 18F parts are capable of extending its program memory to external memory it's possible that the assembler doesn't care what the final size actually is and therefor happily assembles the program no matter what.
    Of course, I'm only speculating.
    Dec 2012
    Türkiye
    Hmm... Sounds logical ...
    Aug 2003
    You should be able to tell by the file size of the compiled hex,
    Or if it has inline asm you could use org to shove some program code in a location that doesn't exist on the chip.
  1. 18F26K22 slow startup
    Last Post: - 7th January 2014, 22:10
  2. Compiling for 18F26K22 - Does anyone have a solution for me?
    By Balachandar in forum mel PIC BASIC Pro
    Last Post: - 28th August 2012, 12:49
  3. 18f26k22 - setting fuse in program
    By smsteves in forum mel PIC BASIC Pro
    Last Post: - 4th October 2011, 13:09
  4. Anyone found a Bootloader for 18F26K22?
    By Dave in forum mel PIC BASIC Pro
    Last Post: - 11th August 2011, 18:23
  5. 12 bit core
    By Ruben Pena in forum mel PIC BASIC
    Last Post: - 6th December 2007, 18:04
