RS232 with multiple slaves
Results 1 to 12 of 12
    Aug 2011
    Default Re: RS232 with multiple slaves
    That one should work fine.
    As Henrik pointed out the CAT5 cable is 100 ohm. You can always change the terminations to 100 instead of 120 ohms to better match the cable (the ADM4850 can drive 50 ohms) but with the slower slew rates I doubt you'll notice much of a difference.
    I'd start with the higher value and see how it works out... less power that way.
    Jan 2008
    Thanks for all the answers, I will order some parts now and start testing.
    At 2400 baud, and one-way comms, I would even try without the RS-485/422 driver, simply modulating the signal with a transistor (or a pair, to retain the polarity) at the transmitter end, at perhaps 15 volts or so; at the receiving end, just use a voltage divider to get a 5 volt signal back.
  1. Programming multiple pics with multiple programs
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 3rd April 2013, 17:47
  2. I2C: slaves to alien master
    By dhouston in forum mel PIC BASIC Pro
    Last Post: - 28th June 2011, 12:46
  3. PIC as I2C Master/Slaves
    By Adamey in forum mel PIC BASIC Pro
    Last Post: - 14th February 2011, 03:38
  4. I2C project - 10 slaves, 1 master
    By mikey11 in forum General
    Last Post: - 29th June 2010, 18:20
  5. master HSEROUT to mixed slaves
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 21st December 2009, 16:44
