Serial Baudrate 115200
Results 1 to 36 of 36
    Sep 2005
    Campbell, CA
    Default Re: Using a "non-DEFINE-listed" oscillator speed
    You are going to have to unless you change the libraries. Just remember that any PAUSE commands will be 8.5% longer than you think.
    You can get around that by creating some variables.
    For example: If your program needed 3 different delays 20ms, 50ms, 190ms
    You would create 3 vars
    delay20 con 18
    delay50 con 46
    delay190 con 175
    Now, if you need a 20mSec delay, you can use the command
    PAUSE delay20
    It is not exact, but it is close.
    Charles Linquist
    SWITZERLAND (french speaking)
    Default Re: Serial Baudrate 115200
    Thanks Charles,
    I thought this would happen. No problem then, for me ;-)
    Roger
  1. Replies: 33
    Last Post: - 19th March 2010, 03:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. 16f88 internal osc 8mhz max serial baudrate ?
    Last Post: - 16th December 2008, 23:27
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
