Serial Baudrate 115200
Results 1 to 36 of 36
    SWITZERLAND (french speaking)
    Thumbs up Serial Baudrate 115200 using HSEROUT - how to?
    if serout2 was inverted, HSER is not inverted.
    Why didn't you SHOUT IT OUT LOUD!!??
    You're absolutely right: the signal has to be inverted in the way I'm using it. I added a transistor to invert the signal going to the MAX232 chip and guess what: IT WORKS!!!!
    The HSEROUT code example in one of my previous post is working fine, also with 115200bps.
    I still have some transmission errors but I think this can be due to the small error rate - I'll try with a 18,432MHz crystal.
    Thanks a lot and have a nice day.
    Roger
    Default Using a "non-DEFINE-listed" oscillator speed
    Hi there,
    I need to use a 18,432MHz crystal with this PIC16F690 project to achieve a clean 115200bps serial comm.
    Looking at the OSC values in the DEFINEs list, I can't find the value "18".
    Shall I simply define the OSC as, i.e., "20" while connecting a 18MHZ crystal?
    The only drawback I can see is about timing in PAUSE commands or similar. I assume the HUSART will still run from the 18MHz osc; right?
    Any other problems I wouldn't see?
    Roger
    Default Re: Using a "non-DEFINE-listed" oscillator speed
    I don't like to yell because I'm usually wrong.
    Just a few thoughts, the Max232 chip inverts signal, if your using USB to serial adapter, that takes a non-inverted signal, so you may be inverting redundently. Also, have you tried OSC-Tune to adjust clock to good 115Kb, then you can use standard Xtal ?
    Don
    Yes, I do use a USB-to-serial interface (FTDI).
    I now corrected the BAUDCTL register so as it sends data inverted (no need for a hw inverter anymore).
    As far as I understand this register's function, OSCTUNE calibrates the internal oscillator so I don't think it will affect the baud rate generator (I don't know).
    BTW, how do I measure a "good" 115200bps signal?
    ' HSEROUT
    ' PIC 16F690 Fuses
    @ __Config _FCMEN_OFF &_IESO_OFF &_BOR_OFF &_CPD_OFF &_CP_OFF &_MCLRE_OFF &_PWRTE_OFF &_WDT_OFF &_HS_OSC
    OPTION_REG = %10000000 'PORT A&B Pull-Ups (look WPUA & WPUB)
    ADCON0     = %00000000 'A/D Module
    ANSEL      = %00000000 'Select analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Select analog inputs Channels 8 to 11
    INTCON     = %00000000 'INTERRUPT Control
    'WPUA       = %00000000 'Select PORTA weak pull-ups
    'IOCA       = %00000000 'Interrupt On Change selection
    CM1CON0    = %00000000 'Comparator1 Module
    CM2CON0    = %00000000 'Comparator2 Module
    TRISA      = %00000000 'Set Input/Output (0 to 5)
    PORTA      = %00000000 'Ports High/Low (0 to 5)
    TRISB      = %00000000 'Set Input/Output (4 to 7)
    PORTB      = %00000000 'Ports High/Low (4 to 7)
    TRISC      = %00000000 'Set Input/Output (0 to 7)
    PORTC      = %00000000 'Ports High/Low (0 to 7)
    ' DEFINEs
    DEFINE OSC 20
    RCSTA = $90 ' Enable serial port & continuous receive
    TXSTA = $24 ' Enable transmit, BRGH = 1
    SPBRG = 42 ' 115200 Baud @ 20MHz, 0.94%
    BAUDCTL = 24 'Transmit INVERTED data to RB7, Enable 16 bit baudrate generator
    LED1    var PORTA.2
    Counter var word
    Counter = 0
    TEST:
      Toggle led1
      HSEROUT [dec counter,13,10]
      Counter = counter + 1
      goto test
    Roger
    Sep 2005
    Campbell, CA
    The baud rate generator will be accurate. If the formula says you will get 115KBaud with a 20Mhz oscillator, you will.
    If you don't get 115K baud, then you aren't really running at 20Mhz, or the receiving device has an issue.
    I mentioned in another post how to measure just how fast your chip is running - without an oscilloscope.
    (Turn LED ON)
    For X = 1 to 60
    Pause 60000
    Next X
    (Turn LED OFF)
    Wait one hour. If your LED goes off in exactly 60 minutes, your chip is running the speed you think it is. Using a
    calculator, you can measure the actual frequency to about 0.1%
    A useful tool is BRAY's TERMINAL program (Google it). Free, and it lets you set odd baud rates, like 113Kbaud.
    or 120Kbaud.
    Charles Linquist
    I need to use a 18,432MHz crystal...
    Can anyone give some info about this please?
    Roger
    Does really nobody know something about that?
    Roger
    Sep 2005
    Campbell, CA
    You are going to have to unless you change the libraries. Just remember that any PAUSE commands will be 8.5% longer than you think.
    You can get around that by creating some variables.
    For example: If your program needed 3 different delays 20ms, 50ms, 190ms
    You would create 3 vars
    delay20 con 18
    delay50 con 46
    delay190 con 175
    Now, if you need a 20mSec delay, you can use the command
    PAUSE delay20
    It is not exact, but it is close.
    Charles Linquist
    Default Re: Serial Baudrate 115200
    Thanks Charles,
    I thought this would happen. No problem then, for me ;-)
    Roger
  1. Replies: 33
    Last Post: - 19th March 2010, 03:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. 16f88 internal osc 8mhz max serial baudrate ?
    Last Post: - 16th December 2008, 23:27
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
