HC-12 error correction
Results 1 to 15 of 15
    Jun 2008
    Varese , Italy
    Default Re: HC-12 error correction
    yours are good result.
    I will try @ 4800 8 n 1 .
    Ambrogio
    Aug 2008
    Portugal
    Quote Originally Posted by iw2fvo View Post
    Ambrogio
    Ok, than post your test result here. I'm curious. Can you also send me where you bought you rmodules?
    I bought mine in Banggood!
    Thanks and Regards;
    Gadelhas
    Jun 2008
    Varese , Italy
    I bought two modules here:
    http://www.ebay.com/itm/1Pcs-433Mhz-...-/171907297975.
    Yesterday, because of my fault in power supply connection, one module crashed . I ordered one more this morning.
    I am waiting to receive it ... but it will need some time .
    Ambrogio
    Jun 2008
    Varese , Italy
    Good day,
    I received the module this morning.
    I wrote a simple program just to test the operative range of those modules.
    I checked one way transmission only : tx is located in my home basement and the receiver is outside near the entrance gate.
    The distance is few meter less than 50 with this set_up.
    I used the default setting: 9600 8 n 1 and FU_3 mode. Power supply for the tx is around 3v3 and 4v0 for the receiver.
    Two " rubber" antennas is used.
    Sine I would like to test the Max communication range, I am asking if is there avaialable a " dedicated " tx pattern of data or text to be used for .
    The gap or the repetion rate is interesting too.
    The output from my set_up is attached here togethre with the relevant picbasic program used.
    Ambro
    Aug 2008
    Portugal
    Good day,
    Ambro
    From my point of view is working fine.
    You can try out my configs above. Also increasing the VCC of the TX to something like 4,5V will improve the transmission.
    Thanks and Regards;
    Gadelhas
    Jun 2008
    Varese , Italy
    I configured the module to operate at 4800 baud.
    The max range is now 150 meters with very few errors.
    It is OK for my application now.
    Ambrogio
    Aug 2008
    Portugal
    Ambrogio
    Great!
    Thanks and Regards;
    Gadelhas
  1. sht_75 and SHT XX pgm correction
    By iw2fvo in forum Code Examples
    Last Post: - 17th October 2015, 08:06
  2. ADC non linear reading correction table
    Last Post: - 29th December 2013, 03:24
  3. ERROR line 90: Sintax error----> [TabIndex]
    By martintorres in forum mel PIC BASIC Pro
    Last Post: - 9th September 2012, 04:29
  4. Replies: 1
    Last Post: - 30th March 2012, 04:13
  5. Forward error correction
    By Ron Marcus in forum General
    Last Post: - 2nd June 2005, 15:12
