Henrik,
It is using DHCP but the lease time is a couple days, so it's maintaining the same IP when it reconnects. The AP just drops it when it sits quiet for a while.
I ran a test and set up a regular loop running with a counter and periodically spitting the hserout and it worked fine.
The code I'm having an issue with is using Darrell Taylors interrupt setup. I don't think the interrupt is running as I can't get the light to flash.
Please see the two code samples below.
'*  Name    : Heartbeat No Interrupt.PBP                        *
'*  Date    : 10-29-15                                          *
 #config
 __CONFIG _CONFIG1H, _OSCS_OFF_1H & _OSC_XT_1H
 __CONFIG _CONFIG2L, _BOR_ON_2L & _BORV_27_2L & _PWRT_ON_2L
 __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
 __CONFIG _CONFIG3H, _CCP2MUX_OFF_3H
 __CONFIG _CONFIG4L, _LVP_OFF_4L
#endconfig
CLEAR
DEFINE ADC_BITS 10          ' 10 Bit Resolution
DEFINE ADC_CLOCK 3          ' Internal RC A/D Oscillator
DEFINE ADC_SAMPLEUS 50      ' Delay before A/D Conversion
DEFINE OSC 4                ' 4 MHz Internal Oscillator
DEFINE HSER_RCSTA 90h       ' Serial Input Enabled
DEFINE HSER_TXSTA 24h       ' Serial Output Enabled (High Speed)
DEFINE HSER_BAUD 9600       ' Serial Baud Rate (9600 BPS)
D           CON 10          ' Divide by D (10 for 4MHz, 2 for 20MHz)
LED1        VAR PortG.0     ' Test LED
LED2        VAR PortG.4     ' Piezo Output
Awake       var byte        ' variable for counting to keep unit alive on network
Awake1      var byte        ' variable for counting to keep unit alive on network
ID1         var byte
Buffer1     var byte
Buffer2     var byte
PortA   =   %00100000       ' PortA All Off
PortB   =   %00000000       ' PortB All Off
PortC   =   %00000000       ' PortC All Off
PortD   =   %00000000       ' PortD All Off
PortE   =   %00000000       ' PortE All Off
PortF   =   %00000000       ' PortF All Off
PortG   =   %00000000       ' PortG All Off
TRISA   =   %00011111       ' Inputs = 1, Outputs = 0
TRISB   =   %11111111       ' Inputs = 1, Outputs = 0
TRISC   =   %10000010       ' Inputs = 1, Outputs = 0
TRISD   =   %11111111       ' Inputs = 1, Outputs = 0
TRISE   =   %11111111       ' Inputs = 1, Outputs = 0
TRISF   =   %11111111       ' Inputs = 1, Outputs = 0
TRISG   =   %00000000       ' Inputs = 1, Outputs = 0 RG(7-5) NA
ADCON0  =   %00000001       ' A/D Enabled, Channel 0 (AN0)
ADCON1  =   %00001110       ' AN0 Analog Input (Rest Digital I/O)
ADCON2.7 = 1                ' Right Justify 10 Bit Word
CMCON   =   %00000111       ' Both Comparators Disabled
INTCON2.7 = 0               ' Turn ON PortB Pull-Ups
T1CON   =   %00110100       ' 1:8 Prescale
Awake = 0
Buffer2 = %11111111             'wifi heartbeat
hserin 200,TimeOut,[dec2 ID1, skip 1, bin8 Buffer1]
TimeOut:
ID1 = ID1 + 1
if ID1 = 99 then ID1 = 0
    Awake = Awake + 1
    if Awake > 50 then                          'sends out
            Awake = 0                          ' reset count
            toggle LED1
            gosub Heartbeat
goto Main
Heartbeat:              'periodically send out current status to keep wifi alive
Toggle LED2                     ' toggle on Beep to see frequency
Hserout ["y"]
HSEROUT [dec2 ID1, " "]         ' Decimal 2 Characters, Space
HSEROUT [bin8 Buffer2]          ' Binary 8 Characters, Space
Hserout ["z"]
'*  Name    : Heartbeat Interrupt.PBP                        *
#config
#endconfig
INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
'INCLUDE "Elapsed_INT-18.bas"  ; Elapsed Timer Routines
'GOSUB ResetTime               ; Reset Time to  0d-00:00:00.00
'GOSUB StartTimer              ; Start the Elapsed Timer
CLEAR
DEFINE LOADER_USED 1        '
DEFINE HSER_CLOERR  1       ' automatic clear overrun error
InBuffer1   VAR BYTE        ' Input Buffer 1
InBuffer2   VAR BYTE        ' Input Buffer 2
Buffer1     VAR BYTE        ' Output Buffer 1
Buffer2     VAR BYTE        ' Output Buffer 2
ID1         var byte
ID2         var byte
ID3         var byte
        INT_Handler    RX_INT,    _serialin,   PBP,  no
    INT_CREATE                ; Creates the interrupt processor
T0CON  = %10010010             ; T0 = 16-bit, Prescaler 8
@   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
PortA   =   %00100000       ' PortA All Off (Rx Enabled/RF Switch = Receive)
ADCON1  =   %00001111       ' AN0 Analog Input (Rest Digital I/O)
T1CON   =   %00110100       ' 1:8 Prescale, T1OSCEN Off (524.288mS)
Awake = 0
ID1 = ID1 + 1
    Awake = Awake + 1
            toggle LED1
            'INTCON.6 = 0  'Interrupt 0=OFF, 1=ON
            gosub Heartbeat
            'INTCON.6 = 1  'Interrupt 0=OFF, 1=ON
goto Main
Hserout ["y"]
Hserout ["z"]
serialin:
hserin [dec2 ID1, skip 1, bin8 Buffer1]
'hserin 2,NoSignal,[dec2 ID1, skip 1, bin8 Buffer1]
@ INT_RETURN
'NoSignal:
'@ INT_RETURN
Hylan
