Trying to stay on wifi network
Results 1 to 3 of 3
    Sep 2007
    Default Trying to stay on wifi network
    I have a board set up which is attached to an Microchip wifi module MRF24WGOMA. The project is for this to receive a signal.
    On some networks, if it sits too long, the access point kicks it off the network and you have to cycle the power to get it to get back on the network.
    I figured the easy answer would be to set up an hserout command and just spit something out to the network.
    However, it appears that if I send it to a made up IP address or even a good one but with nothing to catch it. The network must be replying with an error that then locks up my program.
    Any ideas on what I could hserout to the network just to keep the unit alive and online?
    Default Re: Trying to stay on wifi network
    I don't know anything about the MRF24 module but is it and/or you/your router using DHCP? If so it might be the leasetime for the IP-adress running out.
    Sep 2007
    Henrik,
    It is using DHCP but the lease time is a couple days, so it's maintaining the same IP when it reconnects. The AP just drops it when it sits quiet for a while.
    I ran a test and set up a regular loop running with a counter and periodically spitting the hserout and it worked fine.
    The code I'm having an issue with is using Darrell Taylors interrupt setup. I don't think the interrupt is running as I can't get the light to flash.
    Please see the two code samples below.
    '*  Name    : Heartbeat No Interrupt.PBP                        *
    '*  Date    : 10-29-15                                          *
     #config
     __CONFIG _CONFIG1H, _OSCS_OFF_1H & _OSC_XT_1H
     __CONFIG _CONFIG2L, _BOR_ON_2L & _BORV_27_2L & _PWRT_ON_2L
     __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
     __CONFIG _CONFIG3H, _CCP2MUX_OFF_3H
     __CONFIG _CONFIG4L, _LVP_OFF_4L
    #endconfig
    CLEAR
    DEFINE ADC_BITS 10          ' 10 Bit Resolution
    DEFINE ADC_CLOCK 3          ' Internal RC A/D Oscillator
    DEFINE ADC_SAMPLEUS 50      ' Delay before A/D Conversion
    DEFINE OSC 4                ' 4 MHz Internal Oscillator
    DEFINE HSER_RCSTA 90h       ' Serial Input Enabled
    DEFINE HSER_TXSTA 24h       ' Serial Output Enabled (High Speed)
    DEFINE HSER_BAUD 9600       ' Serial Baud Rate (9600 BPS)
    D           CON 10          ' Divide by D (10 for 4MHz, 2 for 20MHz)
    LED1        VAR PortG.0     ' Test LED
    LED2        VAR PortG.4     ' Piezo Output
    Awake       var byte        ' variable for counting to keep unit alive on network
    Awake1      var byte        ' variable for counting to keep unit alive on network
    ID1         var byte
    Buffer1     var byte
    Buffer2     var byte
    PortA   =   %00100000       ' PortA All Off
    PortB   =   %00000000       ' PortB All Off
    PortC   =   %00000000       ' PortC All Off
    PortD   =   %00000000       ' PortD All Off
    PortE   =   %00000000       ' PortE All Off
    PortF   =   %00000000       ' PortF All Off
    PortG   =   %00000000       ' PortG All Off
    TRISA   =   %00011111       ' Inputs = 1, Outputs = 0
    TRISB   =   %11111111       ' Inputs = 1, Outputs = 0
    TRISC   =   %10000010       ' Inputs = 1, Outputs = 0
    TRISD   =   %11111111       ' Inputs = 1, Outputs = 0
    TRISE   =   %11111111       ' Inputs = 1, Outputs = 0
    TRISF   =   %11111111       ' Inputs = 1, Outputs = 0
    TRISG   =   %00000000       ' Inputs = 1, Outputs = 0 RG(7-5) NA
    ADCON0  =   %00000001       ' A/D Enabled, Channel 0 (AN0)
    ADCON1  =   %00001110       ' AN0 Analog Input (Rest Digital I/O)
    ADCON2.7 = 1                ' Right Justify 10 Bit Word
    CMCON   =   %00000111       ' Both Comparators Disabled
    INTCON2.7 = 0               ' Turn ON PortB Pull-Ups
    T1CON   =   %00110100       ' 1:8 Prescale
    Awake = 0
    Buffer2 = %11111111             'wifi heartbeat
    hserin 200,TimeOut,[dec2 ID1, skip 1, bin8 Buffer1]
    TimeOut:
    ID1 = ID1 + 1
    if ID1 = 99 then ID1 = 0
        Awake = Awake + 1
        if Awake > 50 then                          'sends out
                Awake = 0                          ' reset count
                toggle LED1
                gosub Heartbeat
    goto Main
    Heartbeat:              'periodically send out current status to keep wifi alive
    Toggle LED2                     ' toggle on Beep to see frequency
    Hserout ["y"]
    HSEROUT [dec2 ID1, " "]         ' Decimal 2 Characters, Space
    HSEROUT [bin8 Buffer2]          ' Binary 8 Characters, Space
    Hserout ["z"]
    '*  Name    : Heartbeat Interrupt.PBP                        *
    #config
    #endconfig
    INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    'INCLUDE "Elapsed_INT-18.bas"  ; Elapsed Timer Routines
    'GOSUB ResetTime               ; Reset Time to  0d-00:00:00.00
    'GOSUB StartTimer              ; Start the Elapsed Timer
    CLEAR
    DEFINE LOADER_USED 1        '
    DEFINE HSER_CLOERR  1       ' automatic clear overrun error
    InBuffer1   VAR BYTE        ' Input Buffer 1
    InBuffer2   VAR BYTE        ' Input Buffer 2
    Buffer1     VAR BYTE        ' Output Buffer 1
    Buffer2     VAR BYTE        ' Output Buffer 2
    ID1         var byte
    ID2         var byte
    ID3         var byte
            INT_Handler    RX_INT,    _serialin,   PBP,  no
        INT_CREATE                ; Creates the interrupt processor
    T0CON  = %10010010             ; T0 = 16-bit, Prescaler 8
    @   INT_ENABLE   RX_INT     ; enable external (INT) interrupts
    PortA   =   %00100000       ' PortA All Off (Rx Enabled/RF Switch = Receive)
    ADCON1  =   %00001111       ' AN0 Analog Input (Rest Digital I/O)
    T1CON   =   %00110100       ' 1:8 Prescale, T1OSCEN Off (524.288mS)
    Awake = 0
    ID1 = ID1 + 1
        Awake = Awake + 1
                toggle LED1
                'INTCON.6 = 0  'Interrupt 0=OFF, 1=ON
                gosub Heartbeat
                'INTCON.6 = 1  'Interrupt 0=OFF, 1=ON
    goto Main
    Hserout ["y"]
    Hserout ["z"]
    serialin:
    hserin [dec2 ID1, skip 1, bin8 Buffer1]
    'hserin 2,NoSignal,[dec2 ID1, skip 1, bin8 Buffer1]
    @ INT_RETURN
    'NoSignal:
    '@ INT_RETURN
    Hylan
  1. WIFI video possible ?
    By lerameur in forum General
    Last Post: - 12th February 2015, 05:10
  2. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  3. output doesn't stay high
    By dfort in forum mel PIC BASIC Pro
    Last Post: - 5th November 2007, 23:37
  4. Stay or Go deleted.
    By Darrel Taylor in forum Forum Requests
    Last Post: - 13th July 2007, 23:57
