error message
Results 1 to 5 of 5
Thread: error message
    Aug 2009
    Paso Robles California
    Default error message
    Im setting up PBP and MPLAB on an older laptop windows 7 home edition Im getting error ERROR: Unable to execute mpasmwin.Error[118] Im not sure where to start ?
    Default Re: error message
    Are you using an IDE like MicroCodeStudio or are you compiling from the commandline?
    If you're using MicroCodeStudio have you pointed it to the location where MPLAB is installed?
    What version of PBP? What version of MPLAB?
    Aug 2009
    hi Henrik
    I'm using windows 7 home edition PB pro 2.60a and Mplab 8.53.
    I'm thinking its a path problem but I have never used windows 7 so not sure how to set it and what to set, still using xp pro on my pc
    I have read to go to my computer but I don't have that on my screen
    using a pickit 3 also the pickit will not power the board
    Aug 2009
    I called Charles at Melabs it was a path problem all is well
    Oct 2009
    Is there any wiki or technical manual for PBP? I have error [113] C:\pbp\pbppic18.lib931:symbol not previoulsy defined (Regin)
    plus a host of similar but with different numbers after the lib and (Bitin) at the end...
    I'm moddifying some existing code but not changing any of the include files etc.
    Running 2.60c, MCS 4.0, MPSAM 5.06 (all works fine with tests on other code)
  1. Error Message
    By mel4853 in forum mel PIC BASIC Pro
    Last Post: - 15th March 2009, 20:15
  2. Error message???
    By dangill in forum mel PIC BASIC Pro
    Last Post: - 11th February 2009, 12:53
  3. error message
    By chip_select in forum mel PIC BASIC Pro
    Last Post: - 21st March 2008, 08:14
  4. HPWM...error message?
    By ibra in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:34
  5. error message
    By jcleaver in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:54
