GLCD / OLED serial displays
Results 1 to 3 of 3
    Oct 2009
    Default GLCD / OLED serial displays
    Up until now I've used 16 x 2 and 20 x 4 LCD displays in my projects. Recently I used a 128 x 64 GLCD which used a BV4615 daughter board which handled the drawing on the screen, and allowed the screen to be connected as a serial device, and made for easy code writing as the commands were no more complicated than using an LCD, eg:
    serout2 portB.0, 84, ["Alarm Off"]
    However I'm looking at using an I2c or SPI based display, and noticed that there is a nokia 3310 screen library for PBP. In that library it uses a lookup / lookdown table for the characters thus
    Lcd_SendChar:
        lookdown Lcd_data,[" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ"],CharNum'[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],CharNum
        Lcd_data = CharNum +32
        sELECT CASE lcd_data
        Case 32
            FC(0)=$00:FC(1)=$00:FC(2)=$00:FC(3)=$00:FC(4)=$00 ' // sp
        Case 33
            FC(0)=$00:FC(1)=$00:FC(2)=$2f:FC(3)=$00:FC(4)=$00 ' // !
        Case 34
            FC(0)=$00:FC(1)=$07:FC(2)=$00:FC(3)=$07:FC(4)=$00 ' // " (use \)
        Case 35
            FC(0)=$14:FC(1)=$7f:FC(2)=$14:FC(3)=$7f:FC(4)=$14 ' // #
        Case 36
            FC(0)=$24:FC(1)=$2a:FC(2)=$7f:FC(3)=$2a:FC(4)=$12 ' // $
        Case 37
            FC(0)=$c4:FC(1)=$c8:FC(2)=$10:FC(3)=$26:FC(4)=$46 ' // %
        Case 38
            FC(0)=$36:FC(1)=$49:FC(2)=$55:FC(3)=$22:FC(4)=$50 ' // &
        Case 39
            FC(0)=$00:FC(1)=$05:FC(2)=$03:FC(3)=$00:FC(4)=$00 ' // '
        Case 40
            FC(0)=$00:FC(1)=$1c:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // (
        Case 41
            FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$1c:FC(4)=$00 ' // )
        Case 42
            FC(0)=$14:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$14 ' // *
        Case 43
            FC(0)=$08:FC(1)=$08:FC(2)=$3E:FC(3)=$08:FC(4)=$08 ' // +
        Case 44
            FC(0)=$00:FC(1)=$00:FC(2)=$50:FC(3)=$30:FC(4)=$00 ' //
        Case 45
            FC(0)=$10:FC(1)=$10:FC(2)=$10:FC(3)=$10:FC(4)=$10 ' // -
        Case 46
            FC(0)=$00:FC(1)=$60:FC(2)=$60:FC(3)=$00:FC(4)=$00 ' // .
        Case 47
            FC(0)=$20:FC(1)=$10:FC(2)=$08:FC(3)=$04:FC(4)=$02 ' // /
        Case 48
            FC(0)=$3E:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$3E ' // 0
        Case 49
            FC(0)=$00:FC(1)=$42:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // 1
        Case 50
            FC(0)=$42:FC(1)=$61:FC(2)=$51:FC(3)=$49:FC(4)=$46 ' // 2
        Case 51
            FC(0)=$21:FC(1)=$41:FC(2)=$45:FC(3)=$4B:FC(4)=$31 ' // 3
        Case 52
            FC(0)=$18:FC(1)=$14:FC(2)=$12:FC(3)=$7F:FC(4)=$10 ' // 4
        Case 53
            FC(0)=$27:FC(1)=$45:FC(2)=$45:FC(3)=$45:FC(4)=$39 ' // 5
        Case 54
            FC(0)=$3C:FC(1)=$4A:FC(2)=$49:FC(3)=$49:FC(4)=$30 ' // 6
        Case 55
            FC(0)=$01:FC(1)=$71:FC(2)=$09:FC(3)=$05:FC(4)=$03 ' // 7
        Case 56
            FC(0)=$36:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // 8
        Case 57
            FC(0)=$06:FC(1)=$49:FC(2)=$49:FC(3)=$29:FC(4)=$1E ' // 9
        Case 58
            FC(0)=$00:FC(1)=$36:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // :
        Case 59
            FC(0)=$00:FC(1)=$56:FC(2)=$36:FC(3)=$00:FC(4)=$00 ' // ";"
        Case 60
            FC(0)=$08:FC(1)=$14:FC(2)=$22:FC(3)=$41:FC(4)=$00 ' // <
        Case 61
            FC(0)=$14:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$14 ' // =
        Case 62
            FC(0)=$00:FC(1)=$41:FC(2)=$22:FC(3)=$14:FC(4)=$08 ' // >
        Case 63
            FC(0)=$02:FC(1)=$01:FC(2)=$51:FC(3)=$09:FC(4)=$06 ' // ?
        Case 64
            FC(0)=$32:FC(1)=$49:FC(2)=$59:FC(3)=$51:FC(4)=$3E ' // @
        Case 65
            FC(0)=$7E:FC(1)=$11:FC(2)=$11:FC(3)=$11:FC(4)=$7E ' // A
        Case 66
            FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$36 ' // B
        Case 67
            FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$22 ' // C
        Case 68
            FC(0)=$7F:FC(1)=$41:FC(2)=$41:FC(3)=$22:FC(4)=$1C ' // D
        Case 69
            FC(0)=$7F:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$41 ' // E
        Case 70
            FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$01 ' // F
        Case 71
            FC(0)=$3E:FC(1)=$41:FC(2)=$49:FC(3)=$49:FC(4)=$7A ' // G
        Case 72
            FC(0)=$7F:FC(1)=$08:FC(2)=$08:FC(3)=$08:FC(4)=$7F ' // H
        Case 73
            FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$41:FC(4)=$00 ' // I
        Case 74
            FC(0)=$20:FC(1)=$40:FC(2)=$41:FC(3)=$3F:FC(4)=$01 ' // J
        Case 75
            FC(0)=$7F:FC(1)=$08:FC(2)=$14:FC(3)=$22:FC(4)=$41 ' // K
        Case 76
            FC(0)=$7F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // L
        Case 77
            FC(0)=$7F:FC(1)=$02:FC(2)=$0C:FC(3)=$02:FC(4)=$7F ' // M
        Case 78
            FC(0)=$7F:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$7F ' // N
        Case 79
            FC(0)=$3E:FC(1)=$41:FC(2)=$41:FC(3)=$41:FC(4)=$3E ' // O
        Case 80
            FC(0)=$7F:FC(1)=$09:FC(2)=$09:FC(3)=$09:FC(4)=$06 ' // P
        Case 81
            FC(0)=$3E:FC(1)=$41:FC(2)=$51:FC(3)=$21:FC(4)=$5E ' // Q
        Case 82
            FC(0)=$7F:FC(1)=$09:FC(2)=$19:FC(3)=$29:FC(4)=$46 ' // R
        Case 83
            FC(0)=$46:FC(1)=$49:FC(2)=$49:FC(3)=$49:FC(4)=$31 ' // S
        Case 84
            FC(0)=$01:FC(1)=$01:FC(2)=$7F:FC(3)=$01:FC(4)=$01 ' // T
        Case 85
            FC(0)=$3F:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$3F ' // U
        Case 86
            FC(0)=$1F:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1F ' // V
        Case 87
            FC(0)=$3F:FC(1)=$40:FC(2)=$38:FC(3)=$40:FC(4)=$3F ' // W
        Case 88
            FC(0)=$63:FC(1)=$14:FC(2)=$08:FC(3)=$14:FC(4)=$63 ' // X
        Case 89
            FC(0)=$07:FC(1)=$08:FC(2)=$70:FC(3)=$08:FC(4)=$07 ' // Y
        Case 90
            FC(0)=$61:FC(1)=$51:FC(2)=$49:FC(3)=$45:FC(4)=$43 ' // Z
    '    Case 91
    '        FC(0)=$00:FC(1)=$7F:FC(2)=$41:FC(3)=$41:FC(4)=$00 ' // [
    '    Case 92
    '        FC(0)=$02:FC(1)=$04:FC(2)=$08:FC(3)=$10:FC(4)=$20 ' // \  (we are using this for " above)
    '    Case 93
    '        FC(0)=$00:FC(1)=$41:FC(2)=$41:FC(3)=$7F:FC(4)=$00 ' // ]
    '    Case 94
    '        FC(0)=$04:FC(1)=$02:FC(2)=$01:FC(3)=$02:FC(4)=$04 ' // ^
    '    Case 95
    '        FC(0)=$40:FC(1)=$40:FC(2)=$40:FC(3)=$40:FC(4)=$40 ' // _
    '    Case 96
    '        FC(0)=$00:FC(1)=$01:FC(2)=$02:FC(3)=$04:FC(4)=$00 ' // '
    '    Case 97
    '        FC(0)=$20:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$78 ' // a
    '    Case 98
    '        FC(0)=$7F:FC(1)=$48:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // b
    '    Case 99
    '        FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$20 ' // c
    '    Case 100
    '        FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$48:FC(4)=$7F ' // d
    '    Case 101
    '        FC(0)=$38:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$18 ' // e
    '    Case 102
    '        FC(0)=$08:FC(1)=$7E:FC(2)=$09:FC(3)=$01:FC(4)=$02 ' // f
    '    Case 103
    '        FC(0)=$0C:FC(1)=$52:FC(2)=$52:FC(3)=$52:FC(4)=$3E ' // g
    '    Case 104
    '        FC(0)=$7F:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // h
    '    Case 105
    '        FC(0)=$00:FC(1)=$44:FC(2)=$7D:FC(3)=$40:FC(4)=$00 ' // i
    '    Case 106
    '        FC(0)=$20:FC(1)=$40:FC(2)=$44:FC(3)=$3D:FC(4)=$00 ' // j
    '    Case 107
    '        FC(0)=$7F:FC(1)=$10:FC(2)=$28:FC(3)=$44:FC(4)=$00 ' // k
    '    Case 108
    '        FC(0)=$00:FC(1)=$41:FC(2)=$7F:FC(3)=$40:FC(4)=$00 ' // l
    '    Case 109
    '        FC(0)=$7C:FC(1)=$04:FC(2)=$18:FC(3)=$04:FC(4)=$78 ' // m
    '    Case 110
    '        FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$78 ' // n
    '    Case 111
    '        FC(0)=$38:FC(1)=$44:FC(2)=$44:FC(3)=$44:FC(4)=$38 ' // o
    '    Case 112
    '        FC(0)=$7C:FC(1)=$14:FC(2)=$14:FC(3)=$14:FC(4)=$08 ' // p
    '    Case 113
    '        FC(0)=$08:FC(1)=$14:FC(2)=$14:FC(3)=$18:FC(4)=$7C ' // q
    '    Case 114
    '        FC(0)=$7C:FC(1)=$08:FC(2)=$04:FC(3)=$04:FC(4)=$08 ' // r
    '    Case 115
    '        FC(0)=$48:FC(1)=$54:FC(2)=$54:FC(3)=$54:FC(4)=$20 ' // s
    '    Case 116
    '        FC(0)=$04:FC(1)=$3F:FC(2)=$44:FC(3)=$40:FC(4)=$20 ' // t
    '    Case 117
    '        FC(0)=$3C:FC(1)=$40:FC(2)=$40:FC(3)=$20:FC(4)=$7C ' // u
    '    Case 118
    '        FC(0)=$1C:FC(1)=$20:FC(2)=$40:FC(3)=$20:FC(4)=$1C ' // v
    '    Case 119
    '        FC(0)=$3C:FC(1)=$40:FC(2)=$30:FC(3)=$40:FC(4)=$3C ' // w
    '    Case 120
    '        FC(0)=$44:FC(1)=$28:FC(2)=$10:FC(3)=$28:FC(4)=$44 ' // x
    '    Case 121
    '        FC(0)=$0C:FC(1)=$50:FC(2)=$50:FC(3)=$50:FC(4)=$3C ' // y
    '    Case 122
    '        FC(0)=$44:FC(1)=$64:FC(2)=$54:FC(3)=$4C:FC(4)=$44 ' // z
    '    case 123
    '        FC(0)=$00:FC(1)=$08:FC(2)=$36:FC(3)=$41:FC(4)=$00'  // {
    '    case 124
    '        FC(0)=$00:FC(1)=$00:FC(2)=$7F:FC(3)=$00:FC(4)=$00 ' // |
    '    case 125
    '        FC(0)=$00:FC(1)=$41:FC(2)=$36:FC(3)=$08:FC(4)=$00'  // }
    '    case 126
    '        FC(0)=$10:FC(1)=$08:FC(2)=$08:FC(3)=$10:FC(4)=$08'  // ~
        'case 127
        '    FC(0)=$10:FC(1)=$08:FC(2)=$08:FC(3)=$10:FC(4)=$08'  // DEL
        'Case 128
       '     FC(0)=$55:FC(1)=$2A:FC(2)=$55:FC(3)=$2A:FC(4)=$55 ' // 55 (shaded)
        end SELECT
    Write_LCD:
        High Lcd_DC
        SHiftOUT Lcd_SDO , Lcd_CLK , MSBFIRST, [ FC(0),FC(1),FC(2),FC(3),FC(4),$00 ]
        Low Lcd_DC
    I don't really understand the inner working of these screens, but could I use the above table on any OLED / TFT screen that uses the same protocol, or are the charater generation tables different for each device ?
    Default Re: GLCD / OLED serial displays
    Hello Scampy,
    Here is my advice...take a look at the library made by Richard here:
    http://www.picbasic.co.uk/forum/showthread.php?t=20115
    It is very good and it works great.
    And you can use 2 types of displays ( with or without touch capability ) better than the traditional 3310 displays.
    Rui
    Oct 2009
    Rui,
    Thanks for the reply. The only problem is I'm running 2.60c so don't have the usercommand option that is a feature of PBP3.0
    I have a nice 2.8 TFT colour display with 240x320 resolution and SPI interface that would be nice to work with
  1. Cannot drive I2C Oled :(
    By elcrcp in forum mel PIC BASIC Pro
    Last Post: - 20th August 2016, 13:19
  2. Any transparent GLCD displays available
    By Normnet in forum Off Topic
    Last Post: - 14th June 2015, 15:31
  3. Help With OLED Display / 128X64 SSD1306
    By Denner in forum General
    Last Post: - 25th May 2013, 16:40
  4. A Serial GLCD 128x64 Simple Project
    Last Post: - 8th March 2010, 21:58
  5. Serial GLCD, how?
    By mindthomas in forum General
    Last Post: - 16th April 2008, 16:00
