ADC Question
Results 1 to 8 of 8
Thread: ADC Question
    Default Re: ADC Question
    Here's another aproach
    ON CON 1
    OFF CON 0
    Hysteresis CON 5
    Setpoint CON 120
    Solenoid VAR PortB.0
    InputSignal VAR BYTE
    ' With the above value we will turn the output ON when the SetPoint reaches 125 and OFF when it reaches 115.
    If (Solenoid = OFF) AND (InputSignal >= (Setpoint + Hysteresis)) THEN
      Solenoid = ON
    IF (Solenoid = ON) AND (InputSignal <= (Setpoint - Hysteresis)) THEN
      Solenoid = OFF
    May 2012
    Merseyside, UK
    Hi Henrik
    Thank you for help re:- my coding... Us HW people suffer with S/W issues... Cant see what is happening if cant prod it with Fluke
    Anyway got it working today... See below :-
    '*  Name    : TRIP.BAS                                      *
    '*  PIC     : PIC16F688                         *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 29/10/2015                                        *
    '*  Notes   : 322 Words used                                    *
    '*  Process Signal  AN0                                         *
    '*  Alarm Preset    AN1                                         *
    '*  Trip Preset     AN2                                         *
    '*  Delay Trip Dly  RC2                                         *
    '*  Alarm Relay     RC3                                         *
    '*  Trip Relay      RC4                                         *
    '*  Reset Trip P/B  RC5                                         *
    DEFINE OSC 8              ' Set RC Clock to 8 Megs
    CMCON0 = 7                  'Disable both comparators
    'Define ADCIN parameters
    Define  ADC_BITS     10    ' Set number of bits in result
    Define  ADC_CLOCK    3     ' Set clock source (3=rc)
    Define  ADC_SAMPLEUS 50    ' Set sampling time in uS
    ANSEL = %00000111          ' Enable ADC channels AN2-AN0
    ADCON1 = %10000000         ' Set PORTA analog and right justify result
    'Analogs
    PROC_SIG Var word           ' Create PROC_SIG to store result
    ALARM_TRIM Var word         ' Create ALARM_TRIM to store result
    TRIP_TRIM Var word          ' Create TRIP_TRIM to store result
    'Digitals
    ALARM_RLY VAR PORTC.3       ' Alarm Relay
    TRIP_RLY VAR PORTC.4        ' Trip Relay
    TRIP_RST VAR PORTC.5        ' Trip Reset PB
    TRIP_DLY VAR PORTC.2        ' Trip Delay Link
    'Constants
    RLY_OFF CON 0               ' Relay Off
    RLY_ON CON 1                ' Relay On
    HYS CON 25                  ' 25 = 1/8Volt
    START:
    LOW TRIP_RLY                ' Ensures Trip Rly off
    LOW ALARM_RLY               ' Ensures Alarm Rly off
    Gosub ANALOG_READ
    If (ALARM_RLY = RLY_OFF) AND (PROC_SIG >= (ALARM_TRIM + HYS)) THEN ALARM_RLY = RLY_ON
    If (ALARM_RLY = RLY_ON) AND (PROC_SIG <= (ALARM_TRIM - HYS)) THEN ALARM_RLY = RLY_OFF
    If (TRIP_RLY = RLY_OFF) AND (PROC_SIG >= (TRIP_TRIM + HYS)) and TRIP_DLY = 0 THEN goto D_TRIP
    If (TRIP_RLY = RLY_OFF) AND (PROC_SIG >= (TRIP_TRIM + HYS)) AND TRIP_DLY = 1 THEN goto L_TRIP
    GOTO START
    L_TRIP:                     ' Latching Trip
    high TRIP_RLY               ' Latch Trip Relay
    IF TRIP_RST = 0 THEN GOTO START     'Release If PB Reset  Pressed
    Goto L_trip
    D_TRIP:                     ' Delayed Trip
    HIGH TRIP_RLY               ' Latch Trip Relay
    PAUSE 1000                  ' Pause for T_Delay
    GOTO START
    ANALOG_READ:                ' Read analogs
    ADCIN 0, PROC_SIG           ' Read channel 0 to PROC_SIG
    ADCIN 1, ALARM_TRIM         ' Read channel 1 to ALARM_TRIM
    ADCIN 2, TRIP_TRIM          ' Read channel 2 to TRIP_TRIM
    Anything you see wrong in my attempt above do tell ..... Is there a correct order to list the defines / setup etc ?
    Thank you again for your help
    BR
    Andy
    you might need another read of the hardware manual for a 16f688
    ADCON1 = %10000000 ' Set PORTA analog and right justify result ?????????????
    this will REALLY be
    ADCON1 = %10000000 ' Set Conversion Clock = FOSC/2 and bit 7 does nothing
    you need
    ADCON0.7=1 ' right justify result
    May 2012
    Merseyside, UK
    Hi Richard
    Point taken on ADCON1... My Bad !
    But ADCON0 = %10000001
    BIT 7 = Right justify
    BIT 1 = ADC Enable
    BR
    Andy
  1. ADC Question
    By Art in forum General
    Last Post: - 24th January 2012, 02:35
  2. ADC question again
    By Bobbo_ZA in forum mel PIC BASIC Pro
    Last Post: - 7th May 2010, 13:02
  3. ADC question
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 8th June 2007, 09:52
  4. A question about ADC (using Pic16f876)
    By mimmmis in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2007, 16:26
  5. ADC question
    By schu4647 in forum mel PIC BASIC Pro
    Last Post: - 28th May 2006, 14:15
