for what its worth I tried your code cleaned up a bit and slightly changed to suit a 16f1825
and it works perfectly with nice steady results , could you have a noisy pot or power supply ?
Code:'**************************************************************** '* Name : Nacelle_Steady-On_Lights_12F1840_16Mhz_Int.pbp * '* Author : Ross A. Waddell * '* Notice : Copyright (c) 2016 * '* : All Rights Reserved * '* Date : 02/02/2016 * '* Version : 1.0 * '* Notes : Steady-on nacelle engine lights (TOS Enterprise) * '* : * '**************************************************************** #CONFIG __config _CONFIG1, _FOSC_INTOSC & _CP_OFF & _WDTE_ON & _PWRTE_ON & _MCLRE_ON & _CLKOUTEN_OFF __config _CONFIG2, _PLLEN_ON & _LVP_OFF #ENDCONFIG OSCCON=$70 DEFINE OSC 32 ANSELA = %00001000 ; Analog on PORTA.4(AN3) only ADCON1 = %10100000 ; Right-justified results in 10-bits; Fosc/32 as timer; ; VREF is connected to VDD TRISA = %111110 ' Make all pins input except for RA0 (ser out) trisc= %11011111 ' ccp1 ADCInVal VAR WORD ; stores ADCIN result read from trim pot LEDBrVal VAR WORD FadeInPause CON 25 ; Pause during LED fade in i VAR WORD ' *************************************************************** ' Set up PWM on CCP1 ' *************************************************************** CCP1CON = %00001100 ; Use CCP1 in PWM mode ' Set duty cycle registers initially to 0 CCP1CON.4 = 0 CCP1CON.5 = 0 CCPR1L = 0 lata.0=1 pause 2000 ' ************************ ' CCP1 uses TMR2 ' ************************ T2CON = %00000110 ; Timer2 on with 1:16 prescaler PR2 = 255 ; For 16Mhz OSC the desired output freq of 976.563Hz ; is achieved with this PR2 value (10-bit resolution ; with 1:16 prescaler) MaxDuty VAR WORD ; According to Darrel: ; MaxDuty = (PR2 + 1) * 4 MaxDuty = (PR2 + 1) * 4 ; 1024 MinDuty CON 0 ; Minimum brightness for this application MaxADCVal CON 1023 ; 255 for 8-bit; 1023 for 10-bit compVal VAR WORD ; stores last-changed ADC value CounterA var BYTE ' Just a BYTE Temporary working variable DataW var WORD ' Just a WORD Temporary working variable RawData var WORD [16] ' Array holding ADC Result serout2 PORTA.0,84, ["ready",13,10 ] GOSUB DO_ADCIN_Chk LEDBrVal = ADCInVal compVal = LEDBrVal FOR i = 0 to LEDBrVal CCP1CON.4 = i.0 CCP1CON.5 = i.1 CCPR1L = i >> 2 pause FadeInPause NEXT i Main: GOSUB DO_ADCIN_Chk PAUSE 100 IF ADCInVal <> compVal THEN LEDBrVal = ADCInVal compVal = LEDBrVal gosub ChngLEDBrightness ENDIF GOTO Main '*********** Read ADC or USART Rc inputs ******************************* Do_ADCIN_Chk: ' Stuff 16 Element WORD Array full of ADC values ' ---------------------------------------------- For CounterA=0 to 15 ADCON0 = %00001101 ' Select Channe3, Turn-On A/D Pauseus 50 ' Wait for channel to setup ADCON0.1 = 1 ' Start conversion While ADCON0.1=1:Wend ' Wait for conversion DataW.HighByte=ADRESH ' Read variable from ADC and save DataW.LowByte=ADRESL RawData(CounterA)=DataW Next CounterA ' Sort ADC Input ' -------------- CounterA=0 GetADCSortLoop: If RawData(CounterA+1) < RawData(CounterA) then DataW=RawData(CounterA) RawData(CounterA)=RawData(CounterA+1) RawData(CounterA+1)=DataW If CounterA>0 then CounterA=CounterA-2 endif CounterA=CounterA+1 If CounterA < 15 then goto GetADCSortLoop ' Quanticise, discarding top and bottom FOUR elements ' ---------------------------------------------------- DataW=0 For CounterA=4 to 11 DataW=DataW+RawData(CounterA) Next CounterA ADCInVal=DataW>>3 ' Divide Result by EIGHT serout2 PORTA.0,84, ["adc ",#ADCInVal,13,10 ] return '*********** Set duty registers **************************************** ChngLEDBrightness: CCP1CON.4 = LEDBrVal.0 CCP1CON.5 = LEDBrVal.1 CCPR1L = LEDBrVal >> 2 RETURN
