Scaling ADC Result to a Set Range
Results 1 to 40 of 45
    Default Re: Scaling ADC Result to a Set Range
    either setting will work the 0% error eusart option is probably best ,
    if you set the baudrate regs manually ie
    DEFINE HSER_SPBRG 130 ' 2400 Baud @ 16MHz, 0.0%/SPBRGH = 6
    or
    DEFINE HSER_SPBRG 103 ' 2400 Baud @ 16MHz, 0.17%
    then DEFINE HSER_BAUD should not be used ,it may cause your setting to be overwritten
    ps
    baudrate error is not your display problem, you need to find out
    1. how to initialise your display and how long it takes to happen
    2. how to send control codes to the display ( seems $fe is not correct)
    do you have any docs for the display / or a model no ?
    I switched to using the EUSART DEFINEs & register settings (commenting out the original ones) and it seems better (no initial wonky characters) but the 2nd line still isn't going to the 2nd line. Maybe if I split out the instruction for the 2nd line with a 5 ms pause?
    Here's the data sheet for my serial LCD.
    From Data sheet
    Smart Linefeed (control-J, ASCII 10)
    Move cursor down one line. If immediately preceded by carriage return, linefeed is ignored
    Try it without the 13, see what happens. Or try it with only 13 (more likely)
    Failing that, if your message never changes, add spaces between " and MOTOR
    none of these are correct
    #IFDEF USE_LCD_FOR_DEBUG
    LCD_INST CON 254 ' instruction
    LCD_CLR CON 1 ' Clear screen
    LCD_L1 CON 128 ' LCD line 1
    LCD_L2 CON 192 ' LCD line 2
    #ENDIF
    LCD_CLR CON 12 ' Clear screen
    LCD_HOME CON 1 ' HOME
    LCD_NEXT_LINE CON 13 ' CR does this go back to line 1 when current line is line2 ? seems it will go to first pos of line
    LINE 2
    WOULD BE HSEROUT [16,80] to be sure
    TRY
    HSEROUT [1,"ADCInVal=", DEC ADCInVal, " ", 13, "MotorDuty=", DEC MotorDuty, " "]
    or
    HSEROUT [1,"ADCInVal=", DEC ADCInVal, " ", 16,80, "MotorDuty=", DEC MotorDuty, " "]
    ps the display needs 1000ms delay to power on/boot before you try to write to it
    LINE 2
    TRY
    or
    What makes you think they're not correct? The clear screen command has worked just fine all along. Nonetheless, I will try what you suggest.
    from your data sheet link
    Clear Screen (control-L, ASCII 12)
    Clear the screen.
    you did read it ?
    Thanks to all your help, the screen is finally working. In case anyone is interested, here's the working code:
    #DEFINE USE_LCD_FOR_DEBUG   ; comment out for non-debug use
    ' Pin Connections
    ' Vdd      -> pin 1         -> +5V
    ' RC5/Rx   -> pin 5         -> EUSART receive
    ' RC4/Tx   -> pin 6         -> EUSART transmit (LCD)
    ' RC2      -> pin 8         -> Port motor direction signal (motor 2)
    ' RC1/CCP4 -> pin 9         -> Port motor PWM output (motor 2)
    ' RC0      -> pin 10        -> Stbd motor direction signal (motor 1)
    ' RA2/CCP3 -> pin 11        -> Stbd motor PWM output (motor 1)
    ' RA1      -> pin 12        -> trim pot input
    ' Vss      -> pin 14        -> GND
    DEFINE OSC 16               ; Set oscillator 16Mhz
    ' USART Settings for Tx/Rc (e.g. LCD)
    ' > use Mister E PIC Multi-Calc application to get register/DEFINE settings
    ' > as the values are dependent on the OSC and baud rate
    ' Device Fuses
       __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    ' Initialization
    OSCCON    = %01111000       ; 16MHz internal osc
    APFCON0.2 = 0               ; Tx on RC4 for LCD display
    APFCON0.7 = 0               ; Rx on RC5
    BAUDCON.4 = 1               ; Transmit inverted data to the Tx pin
    ' From Mister E's Multi-Calc for EUSART:
    SPBRGH    = 6
    BAUDCON.3 = 1               ' Enable 16 bit baudrate generator
    ANSELC    = 0               ; Digital only for all PortC pins
    TRISC     = 0               ; Make all PORTC pins output
    TRISA     = %00000010	    ; Make all pins output except for RA1
                                ; (trim pot input)
    ANSELA    = %00000010       ; Analog on PORTA.1 (AN1) only
    FVRCON    = 0               ; Fixed Voltage Reference is disabled
    ADCON0    = %00000101       ; ADC enabled on AN1 (RA1) only; ADC conversion
                                ; enabled
    PAUSEUS 20                  ; wait for the analog switch 'glitch' to die down
    ADCON1    = %00110000       ; Left-justified results in 8-bits; Frc as timer
    '   Display control codes for PC1602LRU-XWA serial LCD
    '   (see 'Dropbox\PBP Projects\PIC Datasheets\PC1602LRU-XWA LCD Datasheet.pdf'
    '   for list of control codes)
        LCD_HOME      CON 1     ' Cursor home
        LCD_HIDE_CRSR CON 4     ' Hide cursor
        LCD_NEXT_LINE CON 13    ' Move cursor to the first position of the next line
    #ENDIF
    MotorDuty   VAR BYTE        ; Actual duty cycle for motor
    ADCInVal    VAR BYTE        ; stores ADCIN result read from trim pot
    compVal     VAR BYTE        ; stores last-changed ADC value
    MinDuty     CON 100         ; Minimum speed to rotate motor for this application
    MaxDuty     CON 252
    MaxADCVal   CON 255         ; 255 for 8-bit; 1023 for 10-bit
        HSEROUT [LCD_CLR]
        pause 5
        HSEROUT ["LCD Init",LCD_NEXT_LINE]
        pause 5
        HSEROUT ["PC1602LRU-XWA"]
        pause 1500
    #ENDIF
    gosub Do_ADC
    compVal = ADCInVal           ; set initial compare value
    GOSUB Map_ADC_Val_to_PWM_Duty
        gosub Do_ADC
        If ADCInVal <> compVal Then
            compVal = ADCInVal
    GOTO Main
    Do_ADC:
        PAUSEUS 50              ' Wait for A/D channel acquisition time
        ADCON0.1 = 1            ' Start conversion
        WHILE ADCON0.1 = 1      ' Wait for it to complete
        WEND
        ADCInVal = ADRESH
    Map_ADC_Val_to_PWM_Duty:
    '   Arduino Map function to emulate:
    '   map(value, fromLow, fromHigh, toLow, toHigh)
    '   long map(long x, long in_min, long in_max, long out_min, long out_max)
    '     return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
        MotorDuty = (compVal - 0) * (MaxDuty - MinDuty)/(MaxADCVal - 0) + MinDuty
            HSEROUT [LCD_CLR]
            pause 5
            HSEROUT ["compVal=",DEC compVal,"  ",LCD_NEXT_LINE]
            pause 5
            HSEROUT ["MotorDuty=",DEC MotorDuty,"  "]
        #ENDIF
  1. Replies: 4
    Last Post: - 27th January 2015, 16:34
  2. Replies: 4
    Last Post: - 30th May 2012, 09:28
  3. Converting 10bit ADC result to 8 bit
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 5th March 2012, 21:38
  4. strange A2D 5V scaling result - 16F819
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 8th April 2010, 03:28
  5. Scaling ADC values
    By purkolator in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 06:14
