Scaling ADC Result to a Set Range
Results 1 to 40 of 45
    Default Re: Scaling ADC Result to a Set Range
    (MaxDuty - MinDuty) would be 250(2)-100= 150
    this would make more sense if your pwm value is a byte
    it now becomes
    MotorDuty = ADCInVAL */ 150(2) + 100
    not knowing whats in the sub ChngMotorHPWM
    snippets lead to speculation
    I'm using 8-bit resolution for PWM so it should be a byte but I have the variable defined as WORD in case the math takes it over 255:
    MotorDuty   VAR WORD        ; Actual duty cycle for motor
    ChngMotorHPWM:
        CCP3CON.4 = MotorDuty.0
        CCP3CON.5 = MotorDuty.1
        CCPR3L    = MotorDuty >> 2
        CCP4CON.4 = MotorDuty.0
        CCP4CON.5 = MotorDuty.1
        CCPR4L    = MotorDuty >> 2
    Do you think the issue would be resolved if I change the datatype of MotorDuty to BYTE? I was also thinking I might switch to 10-bit resolution for both ADC and PWM to get the finest grain control of the motor speed, but that may be overkill.
    > Do you think the issue would be resolved....
    What issue? What exactly is it that doesn't work the way you expect? What do you expect and what does it do?
    75% dutycycle (8bit resolution) +/-25% from an 8bit ADC readin:
    PWMDuty = 191 + (64 - ADCValue >> 1)
    191 is 75% of 255, your initial PWM duty cycle. When ADCvalue (BYTE) is 0 PWMDuty (BYTE) will be 255=100%. When ADCValue is 255 PWMDuty will be 127=50%.
    The goal is to scale the ADC values of 0-255 to a range of duty cycles appropriate for my project (100-252 with the chosen prescaler). If I manually calculate the results are correct:
    • ADCInVal =0 yields 100
    • ADCInVal=127 yields 175
    • ADCinVal=255 yields 252
    But perhaps I don't have the order right in the expression because I don't see those results with the above code.
    from excel chart, multiply adc val by .6 and add 100........ but can't mult decimal so multiply by 6 then divide by 10 then add 100
    Sure you can, sort of, by using the */ or ** operators.
    PWMDuty = 100 + (ADCInValue ** 39322)  ' Same as 100 + ADCInValue * 0.600006 but likely faster than 100+ADCInValue*6/10
    Thanks Henrik! I'll try that tonight.
  1. Replies: 4
    Last Post: - 27th January 2015, 15:34
  2. Replies: 4
    Last Post: - 30th May 2012, 08:28
  3. Converting 10bit ADC result to 8 bit
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 5th March 2012, 20:38
  4. strange A2D 5V scaling result - 16F819
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 8th April 2010, 02:28
  5. Scaling ADC values
    By purkolator in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 05:14
