Scaling ADC Result to a Set Range
Results 1 to 40 of 45
    Default Re: Scaling ADC Result to a Set Range
    the voltage to the pot is probably fluxuating small amount....... add a good size cap to wiper arm (1 microfarad +-) to smooth voltage.
    I added a 1uF, 63V electrolytic cap between the middle wiper arm input to the PIC and GND, but no change. I measured the voltage on the middle wiper arm of the pot and with a reading of '255' I see 4.99V and with '1' I see 0.00V.
    Am I doing something wrong with using ADRESH in 8-bit mode?
    Interestingly, if I switch to 10-bit resolution on ADC I get values from 5-1023. I think there must be something wrong with my config or code:
    #DEFINE USE_LCD_FOR_DEBUG   ; comment out for non-debug use
    ' Vdd      -> pin 1         -> +5V
    ' RC5/Rx   -> pin 5         -> EUSART receive
    ' RC4/Tx   -> pin 6         -> EUSART transmit (LCD)
    ' RA1      -> pin 12        -> trim pot input (1 uF electrolytic cap?)
    ' Vss      -> pin 14        -> GND
    DEFINE OSC 16               ; Set oscillator 16Mhz
    DEFINE ADC_BITS      10     ; Set number of bits in result
    DEFINE ADC_SAMPLEUS  50     ; Set sampling time in uS (was 5)
    DEFINE ADC_CLOCK     3      ; Set clock source (3=rc)
    DEFINE HSER_TXSTA   20h     ; Set transmit status and control register
    DEFINE HSER_BAUD    2400    ; Set baud rate
    ' Device Fuses
       __config _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_ON & _MCLRE_OFF & _CP_OFF & _CPD_OFF
       __config _CONFIG2, _PLLEN_OFF & _STVREN_ON & _BORV_LO & _LVP_OFF
    ' Initialization
    OSCCON    = %01111000       ; 16MHz internal osc
    APFCON0.2 = 0               ; Tx on RC4 for LCD display
    APFCON0.7 = 0               ; Rx on RC5
    BAUDCON.4 = 1               ; Transmit inverted data to the Tx pin
    ANSELC    = 0               ; Digital only for all PortC pins
    TRISC     = 0               ; Make all PORTC pins output
    TRISA     = %00000010	    ; Make all pins output except for RA1 (trim pot input)
    ANSELA    = %00000010       ; Analog on PORTA.1 (AN1) only
    FVRCON    = 0               ; Fixed Voltage Reference is disabled
    ADCON0    = %00000101       ; ADC (analog-to-digital) is enabled on AN1 (RA1) only
    PAUSEUS 20                  ; wait for the analog switch 'glitch' to die down
    ADCON1.7  = 1               ; Right-justified results in 10-bits
    #IFDEF USE_LCD_FOR_DEBUG
        LCD_INST   CON 254       ' instruction
        LCD_CLR    CON 1         ' Clear screen
        LCD_L1     CON 128       ' LCD line 1
        LCD_L2     CON 192       ' LCD line 2
    #ENDIF
    ADCInVal       VAR WORD      ; stores ADCIN result read from trim pot
    compVal        VAR WORD      ; stores last-changed ADC value
    GOSUB Do_ADC
    compVal = ADCInVal           ; set initial compare value
        gosub Do_ADC
            If (compVal > (ADCInVal + 1)) or (compVal < (ADCInVal - 1)) THEn
                ' If this method of reading ADC is as rock-solid as it appears.
                ' then I can remove the +/- 1 before doing anything; it would be
                ' IF ADCInVal <> compVal
                ' DO SOMETHING HERE
                compVal = ADCInVal
            HSEROUT [LCD_INST, LCD_CLR]
            pause 5
            HSEROUT ["ADC val=", DEC ADCInVal, "       ", 13, 10] ; Send text followed by carriage return and linefeed
        #ENDIF
    GOTO Main
    Do_ADC:
        PAUSEUS 50              ' Wait for A/D channel acquisition time
                                ' (does this need to be the same as ADC_SAMPLEUS?)
        ADCON0.1 = 1            ' Start conversion
        WHILE ADCON0.1          ' Wait for it to complete
        WEND
        ADCInVal.HighBYTE = ADRESH
        ADCInVal.LOWBYTE = ADRESL
    If I remove the DEFINEs usually associated with the ADCIN function:
    'DEFINE ADC_BITS      10     ; Set number of bits in result
    'DEFINE ADC_SAMPLEUS  50     ; Set sampling time in uS (was 5)
    'DEFINE ADC_CLOCK     3      ; Set clock source (3=rc)
    and use Fosc/8 as the timer:
    ADCON1    = %00010000       ; Left-justified results in 8-bits; Fosc/8 as timer
    Then I get 0-255. If I do the same for 10-bit resolution, though, I now get 1-1023.
    that's cool...... 1 count in 1023 is small..small error..... that error with 0 volts could be where pic ground is in relation to pot low end...... ground pot low end close to pic ground.....
    what about the fluxuating readings ?
    Now that I'm not using PBP's ADCIN the readings are rock solid.
    I found the math behind the Arduino map function and have replicated it in a subroutine in PBP:
    PR2     = 62                ; For 16Mhz OSC the desired output freq of 15,873Hz is
                                ; achieved with this PR2 value (8-bit resolution
                                ; with 1:4 prescaler)
                                ; PWM freq must be ~ 16-20kHz to reduce noise
    MinDuty     CON 100         ; Minimum speed to rotate motor for this application
    MaxDuty     VAR WORD        ; According to Darrel:
                                ;   MaxDuty = (PR2 + 1) * 4
    MaxDuty = (PR2 + 1) * 4     ; 252 but with prescaler resolution it's actually 250
    MotorDuty   VAR WORD        ; Actual duty cycle for motor
    MaxADCVal   CON 255         ; 255 for 8-bit; 1023 for 10-bit
    ADCInVal    VAR BYTE        ; stores ADCIN result read from trim pot
    compVal     VAR BYTE        ; stores last-changed ADC value
        gosub Do_ADC
        If ADCInVal <> compVal Then
                pause 5
                HSEROUT ["new ADCInVal=", DEC ADCInVal, "       ", 13, 10] ; Send text followed by carriage return and linefeed
            #ENDIF
            GOSUB Map_ADC_Val_to_PWM_Duty
            gosub ChngMotorHPWM
            compVal = ADCInVal
    GOTO Main
    Do_ADC:
        WHILE ADCON0.1 = 1      ' Wait for it to complete
        WEND
        ADCInVal = ADRESH
    Map_ADC_Val_to_PWM_Duty:
    '   Arduino Map function to emulate:
    '   map(value, fromLow, fromHigh, toLow, toHigh)
    '   long map(long x, long in_min, long in_max, long out_min, long out_max)
    '     return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
        MotorDuty = (ADCInVal - 0) * (MaxDuty - MinDuty)/(MaxADCVal - 0) + MinDuty
            pause 5
            HSEROUT ["MotorDuty=", DEC MotorDuty, "       ", 13, 10] ; Send text followed by carriage return and linefeed
            pause 1500
        #ENDIF
    It doesn't look like this is working as expected - any ideas?
    I don't know exactly how you expect it to work but if Iäm not mistaken your formula, when re-written looks like:
    MotorDuty = ADCInVAL * 252 / 255 + 100
    When ADCInVal = 1 Motor Duty will be 100
    When ADCInVAL = 255 MotorDuty will be 352
    Is that what you're seeing?
    Quote Originally Posted by RossWaddell View Post
    Well, they were rock solid. Now the readings are varying quite a lot and even with Melanie's 'averaging' code to pick the middle 8 values from 16 it's still jumping around a lot (and still doesn't read 0 when the trim pot wiper is at the GND end). If I measure the voltage reaching pin 6 (AN1) with a voltmeter it seems accurate and steady, varying from +5V to 0. What am I doing wrong now?
    '*  Name    : Nacelle_Steady-On_Lights_12F1840_16Mhz_Int.pbp    *
    '*  Author  : Ross A. Waddell                                   *
    '*  Notice  : Copyright (c) 2016                                *
    '*  Date    : 02/02/2016                                        *
    '*  Notes   : Steady-on nacelle engine lights (TOS Enterprise)  *
    ' TODO:
    ' Add gamma correction
    ' Increase ADC resolution to 1024
    ' Update PWM frequency/prescaler to use higher resolution
    ' The PWM/fade works perfectly when **not** connected to a FET
    '   - if using a FET, the LEDs 'pulse' and blink but don't fade in/out
    '   - use a 2N2222A transistor
    DEFINE OSC 16                ' Set oscillator 16Mhz
    ' For production version of this code, comment out the line below re:
    ' LCD debugging and also update config fuses to have code protect on
    ' Pin Connections
    ' VDD    -> pin 1            -> +5V
    ' RA5/Rc -> pin 2            -> EUSART receive
    ' RA2    -> pin 5            -> 1kohm -> 2N2222A transistor -> LEDs
    ' RA1    -> pin 6            -> Trim pot input
    ' RA0/Tx -> pin 7            -> EUSART transmit (LCD)
    ' VSS    -> pin 8            -> GND
    ' EUSART Settings for Tx/Rc (e.g. LCD)
    ' > use Mister E PIC Multi-Calc application to get register/DEFINE settings
    ' > as the values are dependent on the OSC and desired baud rate
    DEFINE HSER_SPBRG 160 ' 9600 Baud @ 16MHz, -0.08%
    ' Device Fuses
    ' PIC chip data sheets can be found here: C:\Program Files\Microchip\MPASM Suite
    ' Initialization
    OSCCON    = %01111000        ' 16MHz internal osc
    pause 100                    ' for EEPROM issue
    APFCON.2 = 0                 ; Tx on RA0 for LCD display
    APFCON.7 = 1                 ; Rc on RA5
    APFCON.0 = 0                 ; CCP1 on RA2
    ' Some LCD serial modules need inverted data, some do not
    ' Enable the line below if needed, but for SparkFun SerLCD it should be
    ' commented out
    'BAUDCON.4 = 1               ; Transmit inverted data to the Tx pin
    ' From Mister E's Multi-Calc (EUSART):
    SPBRGH    = 1
    BAUDCON.3 = 1                ' Enable 16 bit baudrate generator
    FVRCON    = 0                ' Fixed Voltage Reference is disabled
    'ADCON0    = %00000101        ' ADC (analog-to-digital) is enabled on AN1 (RA1) only
    'PAUSEUS 20                   ; wait for the analog switch 'glitch' to die down
    ADCON1    = %10010000        ; Right-justified results in 10-bits; Fosc/8 as timer;
                                 ; VREF is connected to VDD
    TRISA     = %00100010	     ' Make all pins output except for RA1 (trim pot input)
                                 ' and RA5 (EUSART Rc)
    LEDBrVal       VAR WORD
    FadeInPause    CON 25        ; Pause during LED fade in
    i              VAR WORD
    ' Set up PWM on CCP1
    CCP1CON = %00001100          ; Use CCP1 in PWM mode
    ' Set duty cycle registers initially to 0
    CCP1CON.4 = 0
    CCP1CON.5 = 0
    CCPR1L    = 0
    ' Use Mister E's PICMultiCalc_1.3.1.exe application (Windows only)
    ' to determine prescaler and PR2 values for given OSC frequency (e.g. 16Mhz)
    ' and duty cycle (use 100% to see highest actual value)
    ' CCP1 uses TMR2
    T2CON   = %00000110         ; Timer2 on with 1:16 prescaler
    PR2     = 255               ; For 16Mhz OSC the desired output freq of 976.563Hz
                                ; is achieved with this PR2 value (10-bit resolution
                                ; with 1:16 prescaler)
    MaxDuty = (PR2 + 1) * 4     ; 1024
    MinDuty       CON 0         ; Minimum brightness for this application
    MaxADCVal     CON 1023      ; 255 for 8-bit; 1023 for 10-bit
    CounterA      var BYTE		' Just a BYTE Temporary working variable
    DataW         var WORD		' Just a WORD Temporary working variable
    RawData       var WORD [16]	' Array holding ADC Result
    '   Display control codes for SerLCD serial LCD (SparkFun part #LCD-09395)
    '   (see 'Dropbox\PBP Projects\PIC Datasheets\SerLCD_V2_5 Datasheet.pdf'
    '   for list of control codes)
        LCD_BR_CMD CON 124       ' command character for adjusting backlight brightness
        LCD_BR_LVL CON 140       ' 140==40%
    #ENDIF
    ' Should only need to do this one time to adjust backlight brightness
    '#IFDEF USE_LCD_FOR_DEBUG
    '    HSEROUT [LCD_BR_CMD, LCD_BR_LVL]
    '    PAUSE 5
    '#ENDIF
        HSEROUT [LCD_INST, LCD_CLR, "LCD Init"]
        pause 5
        HSEROUT [LCD_INST, LCD_L2, "SerLCD_V2_5"]
    #ENDIF
    GOSUB DO_ADCIN_Chk
    LEDBrVal = ADCInVal
    compVal = LEDBrVal
    'compVal = ADCInVal
    'GOSUB Map_VrefInVal_to_PWM_Duty
        pause 5
        HSEROUT ["LEDBrVal=",DEC LEDBrVal,"  "]
    #ENDIF
    ' Fade in LED to final brightness
    FOR i = 0 to LEDBrVal
        CCP1CON.4 = i.0
        CCP1CON.5 = i.1
        CCPR1L    = i >> 2
        pause FadeInPause
            pause 5
            HSEROUT ["i=",DEC i,"  "]
        #ENDIF
    NEXT i
        GOSUB DO_ADCIN_Chk
        PAUSE 100
        IF ADCInVal <> compVal THEN
                pause 5
                HSEROUT ["new ADCInVal", LCD_INST, LCD_L2, DEC ADCInVal, "  "]
            #ENDIF
            LEDBrVal = ADCInVal
            compVal = LEDBrVal
            gosub ChngLEDBrightness
    GOTO Main
    '*********** Read ADC or USART Rc inputs *******************************
    Do_ADCIN_Chk:
    '	Stuff 16 Element WORD Array full of ADC values
    	For CounterA=0 to 15
            ADCON0    = %00000101 ' Select Channel, Turn-On A/D
    						      '	7=0 Unused
    						      '	6=0 Unused
    						      '	5=0 )
    						      '	4=0 )
    						      '	3=0 ) selects AN1
    						      '	2=0 )
    						      '	1=0 Go-done Bit
    						      '	0=1 switch-On ADC Module
    		Pauseus 50			     ' Wait for channel to setup
    		While ADCON0.1=1:Wend	 ' Wait for conversion
    		DataW.HighByte=ADRESH	 ' Read variable from ADC and save
    		DataW.LowByte=ADRESL
    		RawData(CounterA)=DataW
    	Next CounterA
    '	Sort ADC Input
    	CounterA=0
        GetADCSortLoop:
    	If RawData(CounterA+1) < RawData(CounterA) then
    		DataW=RawData(CounterA)
    		RawData(CounterA)=RawData(CounterA+1)
    		RawData(CounterA+1)=DataW
    		If CounterA>0 then CounterA=CounterA-2
    	CounterA=CounterA+1
    	If CounterA < 15 then goto GetADCSortLoop
    '	Quanticise, discarding top and bottom FOUR elements
    	DataW=0
    	For CounterA=4 to 11
    		DataW=DataW+RawData(CounterA)
    	Next CounterA
    	ADCInVal=DataW>>3			' Divide Result by EIGHT
        ' Read trim pot Vref to set LED brightness
    '    PAUSEUS 50              ' Wait for A/D channel acquisition time
    '    ADCON0.1 = 1            ' Start conversion
    '    WHILE ADCON0.1 = 1      ' Wait for it to complete
    '    WEND
    '    ADCInVal.HighBYTE = ADRESH
    '    ADCInVal.LOWBYTE = ADRESL
    '*********** Set duty registers ****************************************
    ChngLEDBrightness:
        CCP1CON.4 = LEDBrVal.0
        CCP1CON.5 = LEDBrVal.1
        CCPR1L    = LEDBrVal >> 2
    after setting adc input you need to Wait A/D channel acquisition time before you Start conversion
    I removed the CCP stuff to leave just the ADC and still the value jumps around by +- 6 or more:
    ' Pin Connections
    ' Device Fuses
    ' Initialization
    ' commented out
    SPBRGH    = 1
    compVal        VAR WORD
    #ENDIF
    '    PAUSE 5
    '#ENDIF
        pause 5
    #ENDIF
    GOSUB DO_ADCIN_Chk
    compVal = ADCInVal
        pause 5
        HSEROUT ["ADCInVal=",DEC ADCInVal,"  "]
    #ENDIF
        GOSUB DO_ADCIN_Chk
        PAUSE 100
                pause 5
            #ENDIF
            compVal = ADCInVal
    GOTO Main
    Do_ADCIN_Chk:
        WEND
  1. Replies: 4
    Last Post: - 27th January 2015, 16:34
  2. Replies: 4
    Last Post: - 30th May 2012, 09:28
  3. Converting 10bit ADC result to 8 bit
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 5th March 2012, 21:38
  4. strange A2D 5V scaling result - 16F819
    By Max Power in forum mel PIC BASIC Pro
    Last Post: - 8th April 2010, 03:28
  5. Scaling ADC values
    By purkolator in forum mel PIC BASIC Pro
    Last Post: - 29th November 2007, 06:14
