Using a parallel LCD(44780 based) as a serial LCD
Results 1 to 8 of 8
    Dec 2012
    Tennessee
    Default Re: Using a parallel LCD(44780 based) as a serial LCD
    you might just want to invest in a serial to parallel board for your lcd. you can get them for about 99 cents on ebay. Ive tried a couple and they seem to work pretty good. if you want one that does uart,spi,and i2c they cost about 7 bucks.
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Or simply buy one of these converters modules on Ebay ( @ 1 or 2 $ /pc !!! )
    Aug 2003
    A HD44780 parallel interface LCD is what the LCDOUT command talks to!
    Oct 2009
    Utah, USA
    If you are going to use a "serial backpack", then instead of the LCDOUT command, you would just use SEROUT or SEROUT2
    and in addition to what Art said... the LCDOUT command will work with either 4 or 8 data lines to the LCD (but you probably already knew that)
    Dwight
    Aug 2003
    It sounds like OP thinks LCDOUT is serial, so trying to make the LCD module serial to accommodate that.
    If it’s a matter of not enough IO pins to use parallel, a shift register would at least take care of the data lines.
    You’d probably need an extra pin. The data pins are already supposed to be in their state when the enable pin transitions.
    Sep 2015
    Hi All,
    Yes I was confused with the use of LCDOUT and SEROUT and SEROUT2.
    Thanks for the info and explanations.
    mike
  1. Universal Serial-Parallel LCD Controller
    By Tywais in forum Schematics
    Last Post: - 18th June 2013, 05:23
  2. Replies: 9
    Last Post: - 18th March 2013, 22:52
  3. Parallel LCD to Serial LCD
    By Mostafa in forum mel PIC BASIC Pro
    Last Post: - 17th June 2007, 21:14
  4. parallel LCD to serial LCD
    By maxbao in forum mel PIC BASIC Pro
    Last Post: - 28th October 2006, 11:44
  5. to convert LCD // hd 44780 --> serial LCD
    By in forum mel PIC BASIC Pro
    Last Post: - 15th March 2003, 12:37
