Release HPWM?
Results 1 to 5 of 5
Thread: Release HPWM?
    Aug 2003
    Default Release HPWM?
    Hi Guys
    I’m wondering when HPWM command is used once, what does it take to make it go away?
    Or the “proper way”, so you can use the pin as normal.
    I know of a few like setting duty cycle 0 or 255, or frequency below what the pic is capable, etc.
    but what it supposed to be done to stop it and use the pin entirely manually?
    It’s for a digital controlled slayer exciter (mini Tesla coil).
    Once I get below the frequency HPWM can handle, I’d like to take over and do lower frequencies manually with DT’s timer.
    Cheers, Art.
    Default Re: Release HPWM?
    ccpxcon = 0
    would do it
    although tris bit for cpx would remain cleared.
    Aug 2003
    Ok thanks Richard, I will try.
    For now I have just been setting duty cycle 100% and then using tris for the pin to toggle a transistor base.
    ccpxcon = 0
    would do it
    Thing works BTW
    Feb 2012
    PERTH AUSTRALIA
    looks cool art
    Aug 2003
    It will make a few of them safer if I can do a small unit in a can for each neon.
    Then they can be supplied with 12 Volts 2.5A along the supply cable instead of 3kV 30mA.
  1. detecting switch release.
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 30th November 2012, 08:14
  2. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  3. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  4. HPWM of the port of two HPWM
    By ja2rqk in forum mel PIC BASIC Pro
    Last Post: - 25th April 2007, 15:05
  5. Hpwm
    By robertmark68 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2006, 19:13
