ok remarking out - didnt work
ADCON1.7 = 0 - didnt work
ADCON1.7 = 1 - WORKED!
OK so now we are sending to the computer what we need. Now to get the part to receive from the PC a Byte.
Heres my modified code, its been reworked several times stuff moved round Ill make notes at bottom of what its doing.
ok, it goes in blinks the led quick and starts the line of code for hserin then it jumps to the test loop runs the adc and sends to the pc and the led continues to blink at 1 sec intervals, it never does the quick led blink of the main loop when test loop led duration is longer. and im not sure if I have the HSERIN coded right, it was taken from other code I had working last year with another chip. the weird thing is, if I change the mainloop led to 1000 and the test loop to 250, it still blinks at the 1 sec rate????Code:Include "12F1572.bas" DEFINE OSC 20 DEFINE ADC_BITS 10 ' A/D number of bits DEFINE ADC_CLOCK 1 ' Uses A/D internal RC clock DEFINE ADC_SAMPLEUS 50 ' Set sampling time in us define HSER_BAUD 9600 DEFINE HSER_BITS 8 DEFINE HSER_CLROERR 1 ADCON1.7 = 1 TRISA = %00000100 ANSELA = %00000100 A VAR word 'Stores 10 Bit Analog Reading B var byte mainloop: b = 0 porta.4 = 1 pause 250 porta.4 = 0 HSERIN 250, test,[B] : Pause 50 goto mainloop ' Do it all over again test: ADCIN 2, A 'Grab analog input from pin3 pause 250 Hserout [#A,13,10] ' Send char out serial port porta.4 = 1 pause 1000 porta.4 = 0 goto mainloop
