HELP! HSER issues from old to new
Results 1 to 12 of 12
Threaded View
  1. #3
    Default Re: HELP! HSER issues from old to new
    Hi WD,
    I am not sure which part you are having trouble with, and am presently unable to work on HSER*** but I played with your code using a 16F690 demo board and debug and pretty well got it to function, accuracy notwithstanding . . .
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    ; DEFINE LOADER_USER 1   ' Boot-Loader is being used
    DEFINE OSC 4          ' Change to your chip
    DEFINE DEBUG_MODE  0         ' Debug sending True serial data
    DEFINE DEBUG_REG_PORTA       ' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUG_BIT 0           ' Debug.bit = PortA.0
    DEFINE DEBUG_BAUD 9600       ' Default baud rate = 9600
    DEFINE DEBUGIN_REG PORTA     ' Debug Port = PortA as required by PICKIT2 serial Monitor
    DEFINE DEBUGIN_BIT 1         ' Debugin bit PortA.1
    DEFINE DEBUGIN_BAUD 9600     ' Default baud rate = 9600
    DEFINE DEBUGIN_MODE 0        ' Debugin receiving data true = 0 inverted = 1
    ;DEFINE HSER_BAUD	9600	' override the default of 2400
    ANSEL  = 0                   '
    ANSELH = 0
    ADCON0 = %00001011
    led	VAR portc.1		' change if needed
    TrisC = %00000000
    TrisA = %00000010
    A VAR word 'Stores 16 Bit Analog Reading
    B0 VAR byte 'Temp Holder
    a=0
    b0=0
    Switch VAR byte
    ;portC = %00000000
    mainloop:
    ADCIN 2, A   'Grab analog input from RA2
    Debugin [B0]
        IF B0 = "5" THEN
             led = 1
             Debug " high fives"
            led = 0
            Debug " still low"
    Debug B0		' Send char out serial port
    A = a + 48
    debug A
    goto mainloop		' Do it all over again
    Maybe something useful in there.
    JS
  1. Need help with HSER on the 16F747
    By allanb in forum Serial
    Last Post: - 18th September 2013, 04:28
  2. HSER baudrate
    By pedja089 in forum Serial
    Last Post: - 7th August 2011, 19:46
  3. HSER Problems
    By Kaldurenik in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 08:33
  4. HSER with interrupts
    By ronjodu in forum mel PIC BASIC Pro
    Last Post: - 25th February 2007, 20:19
  5. Hser-rx test
    By nicjo in forum Serial
    Last Post: - 26th November 2006, 09:53
