Fuses? Switches? Pic settings help!! MCS5 help
Results 1 to 8 of 8
    Oct 2009
    Utah, USA
    Default Re: Fuses? Switches? Pic settings help!! MCS5 help
    i'm by no means an expert and I have not tried the pickit3 (I have and love my pickit2)
    I also have PBP3
    you should be able to set your configuration bits by doing something like the following...
        #IF __PROCESSOR__ = "16F1828"
            __CONFIG _CONFIG1, _FOSC_INTOSC & _WDTE_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOREN_OFF & _CLKOUTEN_OFF & _IESO_OFF & _FCMEN_OFF
            __CONFIG _CONFIG2, _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
            #endconfig
        #ELSE
            #IF __PROCESSOR__ = "16F690"
                __CONFIG _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _CPD_OFF & _BOD_OFF & _IESO_OFF & _FCMEN_OFF
                #endconfig
            #ELSE
                #ERROR "Program does not support " + __PROCESSOR__
            #ENDIF
        #ENDIF
        #msg "compiling for target " + __PROCESSOR__
    The above allows you to set the configuration bits for more than one processor.
    NOTE: some of the configs above begin with just 1 underscore "_" and some have two
    and I believe it is important to get that correct.
    Dwight
    Open up the manual and look at the #CONFIG, #ENDCONFIG directives. Then open up the DEVICE_REFERENCE folder in the PBP3 installation directory and look at the file for your particular target device, it will show you exactly what the PBP default configuration for that device IS and all the available options.
    The "format" of what goes in between the #CONFIG and #ENDCONFIG directives depends on the device family, PIC16, PIC18 etc so it looks a little bit different.
    Sep 2010
    Las Vegas, NV
    As I recollect when MCSPBP installs it creates an INFO folder. In that folder, for at least most of the PICs, there is file showing the format of the configs and what fuses are available but most importantly what they're called. Just copy and paste, delete what you don't need and/or comment out what you don't need.
    Remember that as soon as you place the #CONFIG/"ENDCONFIG block in your program it replaces ALL PBP defaults.
    So you need to include ALL configs that you need to change from the whatever is the default when the flash is cleared - which you need to look up in the datasheet. It's usually best to copy the PBP defaults and change/add what you want.
  1. Hall-effect Switches and pic Inputs
    By andybarrett1 in forum Schematics
    Last Post: - 3rd October 2014, 17:21
  2. Replies: 17
    Last Post: - 16th March 2013, 00:11
  3. Controlling switches with a PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 4th March 2008, 23:44
  4. Coding Style - PIC 18F4620 config fuses
    Last Post: - 8th January 2008, 21:05
