how to read ky40 mechanical encoder ?
Results 1 to 21 of 21
    Jun 2008
    Varese , Italy
    Default Re: how to read ky40 mechanical encoder ?
    Thanks Richard for the code.
    I am just a little bit busy on these days and so I plan to try your code on next days.
    As you have seen I am using pic18f452: Is your code applicable to this micro ?
    If no, what should I modify or adapt ?
    Ambrogio
    for a pic18f452 you need to use RBC_INT for best results and pins portb.4,5 or portb.6,7 or portb.5,6
    this line needs to match chosen p1ns
    ev=ev|((porta&12)>>2) ;read enc pins 2,3 mask off others then combine this reading with last reading
    for pins portb.4,5 it would be
    ev=ev|((portb&48)>>4)
    INT_LIST macro
          INT_HANDLER IOC_INT, _enc_isr,pbp,NO
     INT_CREATE
    would be
    INT_LIST macro
          INT_HANDLER RBC_INT, _enc_isr,pbp,NO
     INT_CREATE
    IOCAP=12 ;enca porta.2 encb porta.3 pos edge trigger
    IOCAN=12 ;enca porta.2 encb porta.3 neg edge trigger
    IOCAF=0
    INTCON=$C8
    would be
    dummy_var = portb
    INTCON=$C8
    any references to IOCAF need to be deleted , trisb must be appropiate
    Jun 2008
    Varese , Italy
    Hi Richard,
    I am going to modify my previous program with your indications.
    Probably I did something wrong and it is not working.
    I am attaching the full code : could you please have a look of it ?
    Thanks again for the assistance
    regards,
    Ambro
    I would do it like this
    '*  Name    : pic controlled power supply                       *
    '*  Notice  : Copyright (c) 2015 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 11/09/2015                                        *
    '*  Notes   : pic18f452 10mhz x 4 pll = 40 MHZ                  *
    ';Program Configuration Register 1H
    @  __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ';Program Configuration Register 2L
    @  __CONFIG    _CONFIG2L, _BOR_OFF_2L & _BORV_20_2L & _PWRT_ON_2L
    ';Program Configuration Register 2H
    @  __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    ';Program Configuration Register 3H
    @  __CONFIG    _CONFIG3H, _CCP2MX_OFF_3H
    ';Program Configuration Register 4L
    @  __CONFIG    _CONFIG4L, _STVR_OFF_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
    ';Program Configuration Register 5L
    @  __CONFIG    _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    ';Program Configuration Register 5H
    @  __CONFIG    _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    ';Program Configuration Register 6L
    @  __CONFIG    _CONFIG6L, _WRT0_OFF_6L & _WRT1_OFF_6L & _WRT2_OFF_6L & _WRT3_OFF_6L
    ';Program Configuration Register 6H
    @  __CONFIG    _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    ';Program Configuration Register 7L
    @  __CONFIG    _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    ';Program Configuration Register 7H
    @  __CONFIG    _CONFIG7H, _EBTRB_OFF_7H
    DEFINE OSC 40                 ' XTAL= 10 MHZ   CLOCK= 40 MHZ
    INCLUDE "MODEDEFS.BAS"
    include "dt_ints-14.bas"
    include "REENTERPBP.bas"
    CNT VAR WORD                   ' COUNTER TO BE DISPLAYED ON TERMINAL
    CNT= 32000
    CNTOLD VAR WORD
    CNTOLD=32000
    counter VAR WORD
    counter= 32000
    ' DEBUG INTERFACE  \\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
    '' Set Debug pin port   ________________________________________
    DEFINE DEBUG_REG PORTD
    '' Set Debug pin bit   _________________________________________ PIC_PIN_30
    DEFINE DEBUG_BIT 7
    '' Set Debug baud rate _________________________________________
    DEFINE DEBUG_BAUD 115200
    '' Set Debug mode: 0 = true, 1 = inverted ______________________
    DEFINE DEBUG_MODE 1
    DEBUG 13,10,13,10, " PROGRAM IS STARTING...", 13, 10, 13, 10
    ADCON1=7                      ' all digital !
            INT_Handler    RBC_INT,  _enc_isr,   PBP,  NO
    '@   INT_ENABLE   RBC_INT     ; enable external (INT) interrupts
       ev    VAR BYTE BANK0
       TMP   VAR BYTE BANK0
       enca  VAR portb.4
       encb  VAR portb.5
       TRISA = 255
       lata.0=1
       tmp = portb  ;; read portb to establish pin change status
       INTCON=$C8  ; enable RBC_INT and clear rbcif
      PAUSE 1000
      gosub get_cnt:
      IF counter <> CNTOLD THEN
         DEBUG DEC CNT,13,10
         CNTOLD=counter  ENDIF
    GOTO Main
    enc_isr:
    ev=ev<<2              ;shift last reading into position
    ev=ev|((portb&48)>>4)  ;read enc pins 4+5  mask off others then  combine this reading with last reading
    LOOKUP (ev&$f),[0,255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0],tmp ;lookup the decision matrix
    if tmp then         ; decide to inc , dec or ignore
     if tmp.7 then
       cnt=cnt-1
        cnt=cnt+1
    intcon.0=0                   ; clean up and exit
    @ INT_RETURN
    get_cnt:       ;  cnt is not atomic   this is needed to avoid rollover miss reads
    intcon.3=0
    counter=cnt
    intcon.3=1
    Jun 2008
    Varese , Italy
    Thanks Richard,
    Your program compiles well.
    I do have the follwing :
    32009
    32005
    32009
    32013
    32017
    32021
    32033
    32042
    32073
    32113
    32153
    32173
    32197
    32209
    32233
    32257
    32221
    32199
    32161
    32129
    32101
    32065
    32061
    32057
    32053
    32045
    32041
    32040
    32037
    32013
    31999
    31997
    I have changed the encoder too but not working...
    Ambro
    the isr counts edges , an indented re has 4 edges per indent . you would expect to increment counter by 4
    don't forget the display routine and the isr are asynchronous .
    if you are trying to count indents then
     cnt_f var bit
      PAUSE 10
      IF cnt_f THEN
     gosub get_cnt:
         DEBUG DEC counter,13,10
    GOTO Main
    enc_isr:
        ev=ev|((portb&48)>>4)  ;read enc pins 4,5  mask off others then  combine this reading with last reading
        LOOKUP (ev&15),[0,255, 1, 0, 1, 0, 0, 255, 255, 0, 0, 1, 0, 1, 255, 0],tmp;lookup the decision matrix
            if tmp.7 then
               cnt=cnt-1
               cnt_f=1
                cnt=cnt+1
                cnt_f=1
    @ INT_RETURN
    get_cnt :
    intcon.3=0
        counter=cnt/4
        cnt_f=0
      intcon.3=1
    Jun 2008
    Varese , Italy
    Richard:
    for each one click ( or detent ) it prints four numbers.
  1. Question about mechanical relay
    Last Post: - 1st October 2012, 10:37
  2. Mechanical question
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 11th October 2011, 05:41
  3. Probe to read quadrature encoder with DT_INT need help
    By phoenix_1 in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 20:43
  4. Mechanical question
    By selbstdual in forum Off Topic
    Last Post: - 8th February 2008, 14:34
  5. Replies: 6
    Last Post: - 14th October 2005, 19:41
