Graphic LCD support?
Results 1 to 23 of 23
    bioeng-mostafa's Avatar
    bioeng-mostafa Guest
    Default I Want Help
    Hellow
    I Want The File By Whish I Can Write Progrsm With Pbp
    Or Beatsh
    Thank You
    New England
    I'd guess the main reason for no graphic support is all the different types of graphic LCD's out there. If MELabs offered support for say the KS0108 type, people would want some other LCD variety supported too.
    The graphic LCD's are really fairly easy to use if you read the data sheets several times (the data sheets are typically pretty poor translations).
    There is also a web-site with some sample code:
    http://www.compsys1.com/workbench/
    Writing your own code allows you to tailor everything to your specific needs, without filling up a whole '876!
    Oct 2010
    Default Re: Graphic LCD support?
    Dear All,
    i would like to use GLCD but i cannot do it as your discussion here.
    I only found on the net that PROTON and micro e are able to control very easy GLCD.
    The problem is that we are using now picbasic and i dont wont to change from that, i'm used to it.
    Is there any plan to see an update of the picbasic pro for supporting the GLCD?
    Did you search the forum for your particular model of GLCD?
    Did you start a thread asking for help on code or schematic?
    There's already several examples on these forums. Sometimes you can use techniques used for one model and customize it for another with just a few tweaks.
    There was one particular model that I had used that had no examples anywhere on the web. I started with the datasheet, found a "close model" and went on from there.
    Putting too much functionality into PICs is not necessarily a good idea, it takes up space. Imagine if all PICs now had DT's interrupt, barely enough room to LCDOUT "Hello" on most of them, if at all.
    Oct 2010
    yes i have searched for the GLCD 128x64 with Samsung KS0108.
    to be honest with Proton i did a grahpical model in less that 10 minutes.
    Is it so difficult to put a library for these GLCDs? I dont care for the PIC's space since there are 32x16 ones that can store an elephant in there.
    I just want my life to be easier and save time. I didnt ask for a code but for better features like proton and micro c
    Sep 2009
    Default Graphic LCD support...
    I'm currently working on a driver for the GLCD.
    Here you can see how far I got.
    '*  Name    : GLCD driver                                       *
    '*  Author  : Pedja089                                          *
    ' LCD Commands are:
    '   Lcd_Init
    '   Lcd_SetX
    '   Lcd_SetY
    '   Lcd_Clr
    '   Lcd_On
    '   @ PrintStr x,y, "string goes here"  ' will auto wrap to next line if needed
    '   @ PrintVar x,y, _anyvariablehere
    '   You can manually position x,y and print characters by the following:
    '   PosX = 0            ' move to position 0 of 83 (char best viewed at spacing of 6)
    '   PosY = 1            ' move to second line of 6
    '   Lcd_SetX
    '   Lcd_SetY
    '   Lcd_Data = "H"      ' Note byte size single char.
    '   Gosub Lcd_SendChar
    symbol RW=portb.3
    symbol RS = portb.2
    symbol E = portb.4
    symbol CS1 = portb.0
    symbol CS2 = portb.1
    symbol RST = portb.5
    Symbol LCD_DATA=portd
    LCD_DATA=0
    TRISD=0
    output rst
    Output RW
    Output RS
    Output E
    Output CS1
    Output CS2
    PosX            var Byte        ' Variable for Position X
    PosY            var Byte        ' Variable for Position Y
    GLCD_SX     var byte
    GLCD_X          var byte
    GLCD_FC              var Byte [5]    ' Variable 5 bytes = 1 character
    GLCD_CharNum         var byte        ' character number
    GLCD_VarData         var word        ' variable to print to lcd
    GLCD_n0              var byte        ' for next variable
    GLCD_n1              var byte
    GLCD_digits          var bit         ' number of digits in VarData
    GLCD_Addr  VAR WORD
    GLCD_Char  VAR byte ' lcdchardata[0]
    gosub Lcd_init
    goto OverLCD
    '_______________________________________________________________________________
    ' @ PrintVar macro function
    ' format should look like this: @ PrintVar x,y, _anyvariable
    PrintVar macro x, y, Variable   ; input values from: @PrintVar 0,1, _any_variable
        local OverVar
        goto OverVar
    OverVar
        MOVE?CB  x, _GLCD_X
        MOVE?CB  x, _GLCD_SX
        MOVE?CB  y, _PosY          ; move y from above statement to PosY
        MOVE?WW  Variable, _GLCD_VarData ; move variable in statement to VarData
        L?CALL   _GLCD_VariableOut       ; call VariableOut function
    GLCD_VariableOut:
        'for GLCD_n1 = 4 to 0 step -1        ' cycles through all possible digits of number
            Gosub Lcd_SetX
            Gosub Lcd_SetY         ' place character at position PosX and PosY
            GLCD_Char = (GLCD_VarData dig 2) + 48 ' digit number n to character str format
            gosub Lcd_SendChar        ' print char to screen
            PosX = PosX + 6           ' next x position for character
            Gosub Lcd_SetX
            GLCD_Char = (GLCD_VarData dig 1) + 48 ' digit number n to character str format
                    Gosub Lcd_SetX
            GLCD_Char = (GLCD_VarData dig 0) + 48 ' digit number n to character str format
    GLCD_SkipChar:
        'next GLCD_n1
    PrintStr macro x, y, Str
        local TheString, OverStr
        goto OverStr
    TheString
        data  Str, 0
    OverStr
        MOVE?CB  x, _GLCD_X
        MOVE?CB  x, _GLCD_SX
        MOVE?CB  y, _PosY
        MOVE?CW  TheString, _GLCD_Addr
        L?CALL   _GLCD_StringOut
    GLCD_StringOut:
        Readcode GLCD_Addr, GLCD_Char           ' Get a character
        if GLCD_Char = 0 then GLCD_StringDone   ' Look for Null char, Stop if found
        if glcd_x=> 123 then             ' If end of line, cycle to next line
            PosY = PosY + 1
            glcd_x=GLCD_SX
        If glcd_x<64 then
         lcd_data=0
         cs1=0
         cs2=1
         posx=glcd_x
         lcd_data=0
         cs1=1
         cs2=0
         posx=glcd_x-64
        Gosub Lcd_SetX
        gosub Lcd_SetY
        gosub Lcd_SendChar            ' puttext
        GLCD_Addr = GLCD_Addr + 1               ' Point to next character
        glcd_x=glcd_x + 1
        goto GLCD_StringOut                ' Continue with rest of the string
      GLCD_StringDone:
    Lcd_SendChar:
        lookdown GLCD_Char,_
        [" !\#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxyz{|}~"],GLCD_CharNum
        GLCD_Char = GLCD_CharNum +32
        sELECT CASE GLCD_Char
        Case 32
            GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$00:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // sp
        Case 33
            GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$2f:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // !
        Case 34
            GLCD_FC(0)=$00:GLCD_FC(1)=$07:GLCD_FC(2)=$00:GLCD_FC(3)=$07:GLCD_FC(4)=$00 ' // " (shown as \ in Lookdown table)
        Case 35
            GLCD_FC(0)=$14:GLCD_FC(1)=$7f:GLCD_FC(2)=$14:GLCD_FC(3)=$7f:GLCD_FC(4)=$14 ' // #
        Case 36
            GLCD_FC(0)=$24:GLCD_FC(1)=$2a:GLCD_FC(2)=$7f:GLCD_FC(3)=$2a:GLCD_FC(4)=$12 ' // $
        Case 37
            GLCD_FC(0)=$c4:GLCD_FC(1)=$c8:GLCD_FC(2)=$10:GLCD_FC(3)=$26:GLCD_FC(4)=$46 ' // %
        Case 38
            GLCD_FC(0)=$36:GLCD_FC(1)=$49:GLCD_FC(2)=$55:GLCD_FC(3)=$22:GLCD_FC(4)=$50 ' // &
        Case 39
            GLCD_FC(0)=$00:GLCD_FC(1)=$05:GLCD_FC(2)=$03:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // '
        Case 40
            GLCD_FC(0)=$00:GLCD_FC(1)=$1c:GLCD_FC(2)=$22:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // (
        Case 41
            GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$22:GLCD_FC(3)=$1c:GLCD_FC(4)=$00 ' // )
        Case 42
            GLCD_FC(0)=$14:GLCD_FC(1)=$08:GLCD_FC(2)=$3E:GLCD_FC(3)=$08:GLCD_FC(4)=$14 ' // *
        Case 43
            GLCD_FC(0)=$08:GLCD_FC(1)=$08:GLCD_FC(2)=$3E:GLCD_FC(3)=$08:GLCD_FC(4)=$08 ' // +
        Case 44
            GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$50:GLCD_FC(3)=$30:GLCD_FC(4)=$00 ' // ,
        Case 45
            GLCD_FC(0)=$10:GLCD_FC(1)=$10:GLCD_FC(2)=$10:GLCD_FC(3)=$10:GLCD_FC(4)=$10 ' // -
        Case 46
            GLCD_FC(0)=$00:GLCD_FC(1)=$60:GLCD_FC(2)=$60:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // .
        Case 47
            GLCD_FC(0)=$20:GLCD_FC(1)=$10:GLCD_FC(2)=$08:GLCD_FC(3)=$04:GLCD_FC(4)=$02 ' // /
        Case 48
            GLCD_FC(0)=$3E:GLCD_FC(1)=$51:GLCD_FC(2)=$49:GLCD_FC(3)=$45:GLCD_FC(4)=$3E ' // 0
        Case 49
            GLCD_FC(0)=$00:GLCD_FC(1)=$42:GLCD_FC(2)=$7F:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // 1
        Case 50
            GLCD_FC(0)=$42:GLCD_FC(1)=$61:GLCD_FC(2)=$51:GLCD_FC(3)=$49:GLCD_FC(4)=$46 ' // 2
        Case 51
            GLCD_FC(0)=$21:GLCD_FC(1)=$41:GLCD_FC(2)=$45:GLCD_FC(3)=$4B:GLCD_FC(4)=$31 ' // 3
        Case 52
            GLCD_FC(0)=$18:GLCD_FC(1)=$14:GLCD_FC(2)=$12:GLCD_FC(3)=$7F:GLCD_FC(4)=$10 ' // 4
        Case 53
            GLCD_FC(0)=$27:GLCD_FC(1)=$45:GLCD_FC(2)=$45:GLCD_FC(3)=$45:GLCD_FC(4)=$39 ' // 5
        Case 54
            GLCD_FC(0)=$3C:GLCD_FC(1)=$4A:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$30 ' // 6
        Case 55
            GLCD_FC(0)=$01:GLCD_FC(1)=$71:GLCD_FC(2)=$09:GLCD_FC(3)=$05:GLCD_FC(4)=$03 ' // 7
        Case 56
            GLCD_FC(0)=$36:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$36 ' // 8
        Case 57
            GLCD_FC(0)=$06:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$29:GLCD_FC(4)=$1E ' // 9
        Case 58
            GLCD_FC(0)=$00:GLCD_FC(1)=$36:GLCD_FC(2)=$36:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // :
        Case 59
            GLCD_FC(0)=$00:GLCD_FC(1)=$56:GLCD_FC(2)=$36:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // ";"
        Case 60
            GLCD_FC(0)=$08:GLCD_FC(1)=$14:GLCD_FC(2)=$22:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // <
        Case 61
            GLCD_FC(0)=$14:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$14:GLCD_FC(4)=$14 ' // =
        Case 62
            GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$22:GLCD_FC(3)=$14:GLCD_FC(4)=$08 ' // >
        Case 63
            GLCD_FC(0)=$02:GLCD_FC(1)=$01:GLCD_FC(2)=$51:GLCD_FC(3)=$09:GLCD_FC(4)=$06 ' // ?
        Case 64
            GLCD_FC(0)=$32:GLCD_FC(1)=$49:GLCD_FC(2)=$59:GLCD_FC(3)=$51:GLCD_FC(4)=$3E ' // @
        Case 65
            GLCD_FC(0)=$7E:GLCD_FC(1)=$11:GLCD_FC(2)=$11:GLCD_FC(3)=$11:GLCD_FC(4)=$7E ' // A
        Case 66
            GLCD_FC(0)=$7F:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$36 ' // B
        Case 67
            GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$22 ' // C
        Case 68
            GLCD_FC(0)=$7F:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$22:GLCD_FC(4)=$1C ' // D
        Case 69
            GLCD_FC(0)=$7F:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$41 ' // E
        Case 70
            GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$09:GLCD_FC(3)=$09:GLCD_FC(4)=$01 ' // F
        Case 71
            GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$7A ' // G
        Case 72
            GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$08:GLCD_FC(4)=$7F ' // H
        Case 73
            GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$7F:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // I
        Case 74
            GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$41:GLCD_FC(3)=$3F:GLCD_FC(4)=$01 ' // J
        Case 75
            GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$14:GLCD_FC(3)=$22:GLCD_FC(4)=$41 ' // K
        Case 76
            GLCD_FC(0)=$7F:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$40 ' // L
        Case 77
            GLCD_FC(0)=$7F:GLCD_FC(1)=$02:GLCD_FC(2)=$0C:GLCD_FC(3)=$02:GLCD_FC(4)=$7F ' // M
        Case 78
            GLCD_FC(0)=$7F:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$7F ' // N
        Case 79
            GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$3E ' // O
        Case 80
            GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$09:GLCD_FC(3)=$09:GLCD_FC(4)=$06 ' // P
        Case 81
            GLCD_FC(0)=$3E:GLCD_FC(1)=$41:GLCD_FC(2)=$51:GLCD_FC(3)=$21:GLCD_FC(4)=$5E ' // Q
        Case 82
            GLCD_FC(0)=$7F:GLCD_FC(1)=$09:GLCD_FC(2)=$19:GLCD_FC(3)=$29:GLCD_FC(4)=$46 ' // R
        Case 83
            GLCD_FC(0)=$46:GLCD_FC(1)=$49:GLCD_FC(2)=$49:GLCD_FC(3)=$49:GLCD_FC(4)=$31 ' // S
        Case 84
            GLCD_FC(0)=$01:GLCD_FC(1)=$01:GLCD_FC(2)=$7F:GLCD_FC(3)=$01:GLCD_FC(4)=$01 ' // T
        Case 85
            GLCD_FC(0)=$3F:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$3F ' // U
        Case 86
            GLCD_FC(0)=$1F:GLCD_FC(1)=$20:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$1F ' // V
        Case 87
            GLCD_FC(0)=$3F:GLCD_FC(1)=$40:GLCD_FC(2)=$38:GLCD_FC(3)=$40:GLCD_FC(4)=$3F ' // W
        Case 88
            GLCD_FC(0)=$63:GLCD_FC(1)=$14:GLCD_FC(2)=$08:GLCD_FC(3)=$14:GLCD_FC(4)=$63 ' // X
        Case 89
            GLCD_FC(0)=$07:GLCD_FC(1)=$08:GLCD_FC(2)=$70:GLCD_FC(3)=$08:GLCD_FC(4)=$07 ' // Y
        Case 90
            GLCD_FC(0)=$61:GLCD_FC(1)=$51:GLCD_FC(2)=$49:GLCD_FC(3)=$45:GLCD_FC(4)=$43 ' // Z
        Case 91
            GLCD_FC(0)=$00:GLCD_FC(1)=$7F:GLCD_FC(2)=$41:GLCD_FC(3)=$41:GLCD_FC(4)=$00 ' // [
        Case 92
            GLCD_FC(0)=$02:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$20 ' // \  (we are using this for Case 34 " above)
        Case 93
            GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$41:GLCD_FC(3)=$7F:GLCD_FC(4)=$00 ' // ]
        Case 94
            GLCD_FC(0)=$04:GLCD_FC(1)=$02:GLCD_FC(2)=$01:GLCD_FC(3)=$02:GLCD_FC(4)=$04 ' // ^
        Case 95
            GLCD_FC(0)=$40:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$40:GLCD_FC(4)=$40 ' // _
        Case 96
    '        GLCD_FC(0)=$00:GLCD_FC(1)=$01:GLCD_FC(2)=$02:GLCD_FC(3)=$04:GLCD_FC(4)=$00 ' // `
            GLCD_FC(0)=$02:GLCD_FC(1)=$04:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$20 ' // \ (shown as ` in Lookdown table)
        Case 97
            GLCD_FC(0)=$20:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$78 ' // a
        Case 98
            GLCD_FC(0)=$7F:GLCD_FC(1)=$48:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$38 ' // b
        Case 99
            GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$20 ' // c
        Case 100
            GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$48:GLCD_FC(4)=$7F ' // d
        Case 101
            GLCD_FC(0)=$38:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$18 ' // e
        Case 102
            GLCD_FC(0)=$08:GLCD_FC(1)=$7E:GLCD_FC(2)=$09:GLCD_FC(3)=$01:GLCD_FC(4)=$02 ' // f
        Case 103
            GLCD_FC(0)=$0C:GLCD_FC(1)=$52:GLCD_FC(2)=$52:GLCD_FC(3)=$52:GLCD_FC(4)=$3E ' // g
        Case 104
            GLCD_FC(0)=$7F:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // h
        Case 105
            GLCD_FC(0)=$00:GLCD_FC(1)=$44:GLCD_FC(2)=$7D:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // i
        Case 106
            GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$44:GLCD_FC(3)=$3D:GLCD_FC(4)=$00 ' // j
        Case 107
            GLCD_FC(0)=$7F:GLCD_FC(1)=$10:GLCD_FC(2)=$28:GLCD_FC(3)=$44:GLCD_FC(4)=$00 ' // k
        Case 108
            GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$7F:GLCD_FC(3)=$40:GLCD_FC(4)=$00 ' // l
        Case 109
            GLCD_FC(0)=$7C:GLCD_FC(1)=$04:GLCD_FC(2)=$18:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // m
        Case 110
            GLCD_FC(0)=$7C:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$78 ' // n
        Case 111
            GLCD_FC(0)=$38:GLCD_FC(1)=$44:GLCD_FC(2)=$44:GLCD_FC(3)=$44:GLCD_FC(4)=$38 ' // o
        Case 112
            GLCD_FC(0)=$7C:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$14:GLCD_FC(4)=$08 ' // p
        Case 113
            GLCD_FC(0)=$08:GLCD_FC(1)=$14:GLCD_FC(2)=$14:GLCD_FC(3)=$18:GLCD_FC(4)=$7C ' // q
        Case 114
            GLCD_FC(0)=$7C:GLCD_FC(1)=$08:GLCD_FC(2)=$04:GLCD_FC(3)=$04:GLCD_FC(4)=$08 ' // r
        Case 115
            GLCD_FC(0)=$48:GLCD_FC(1)=$54:GLCD_FC(2)=$54:GLCD_FC(3)=$54:GLCD_FC(4)=$20 ' // s
        Case 116
            GLCD_FC(0)=$04:GLCD_FC(1)=$3F:GLCD_FC(2)=$44:GLCD_FC(3)=$40:GLCD_FC(4)=$20 ' // t
        Case 117
            GLCD_FC(0)=$3C:GLCD_FC(1)=$40:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$7C ' // u
        Case 118
            GLCD_FC(0)=$1C:GLCD_FC(1)=$20:GLCD_FC(2)=$40:GLCD_FC(3)=$20:GLCD_FC(4)=$1C ' // v
        Case 119
            GLCD_FC(0)=$3C:GLCD_FC(1)=$40:GLCD_FC(2)=$30:GLCD_FC(3)=$40:GLCD_FC(4)=$3C ' // w
        Case 120
            GLCD_FC(0)=$44:GLCD_FC(1)=$28:GLCD_FC(2)=$10:GLCD_FC(3)=$28:GLCD_FC(4)=$44 ' // x
        Case 121
            GLCD_FC(0)=$0C:GLCD_FC(1)=$50:GLCD_FC(2)=$50:GLCD_FC(3)=$50:GLCD_FC(4)=$3C ' // y
        Case 122
            GLCD_FC(0)=$44:GLCD_FC(1)=$64:GLCD_FC(2)=$54:GLCD_FC(3)=$4C:GLCD_FC(4)=$44 ' // z
        case 123
    '        GLCD_FC(0)=$00:GLCD_FC(1)=$08:GLCD_FC(2)=$36:GLCD_FC(3)=$41:GLCD_FC(4)=$00'  // {
            GLCD_FC(0)=$10:GLCD_FC(1)=$24:GLCD_FC(2)=$20:GLCD_FC(3)=$24:GLCD_FC(4)=$10 ' // Smily face (shown as { in Lookdown table)
        case 124
    '        GLCD_FC(0)=$00:GLCD_FC(1)=$00:GLCD_FC(2)=$7F:GLCD_FC(3)=$00:GLCD_FC(4)=$00 ' // |
            GLCD_FC(0)=$20:GLCD_FC(1)=$40:GLCD_FC(2)=$20:GLCD_FC(3)=$10:GLCD_FC(4)=$08 ' // Tick (shown as | in Lookdown table)
        case 125
    '        GLCD_FC(0)=$00:GLCD_FC(1)=$41:GLCD_FC(2)=$36:GLCD_FC(3)=$08:GLCD_FC(4)=$00'  // }
            GLCD_FC(0)=$20:GLCD_FC(1)=$14:GLCD_FC(2)=$10:GLCD_FC(3)=$14:GLCD_FC(4)=$20 ' // Frown face (shown as } in Lookdown table)
        case 126
            GLCD_FC(0)=$10:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$08'  // ~
    '    case 127
    '        GLCD_FC(0)=$10:GLCD_FC(1)=$08:GLCD_FC(2)=$08:GLCD_FC(3)=$10:GLCD_FC(4)=$08'  // DEL
    '    Case 128
    '        GLCD_FC(0)=$55:GLCD_FC(1)=$2A:GLCD_FC(2)=$55:GLCD_FC(3)=$2A:GLCD_FC(4)=$55 ' // 55 (shaded)
        end SELECT
        for GLCD_n0 = 0 to 4
         If glcd_x=64 then
               lcd_data=0
               cs1=1
               cs2=0
               posx=0
               gosub lcd_setx
               gosub lcd_sety
         glcd_x=glcd_x + 1
         lcd_data=GLCD_FC(GLCD_n0)
         GOSUB Lcd_Pod
        next GLCD_n0
    Lcd_Init:
     posx=0
     posy=0
     rw=0
     cs1=0
     cs2=0
     e=1
     LCD_DATA=0
     rst=0
     pause 1
     rst=1
     cs1=1
     cs2=1
     gosub Lcd_On
     LCD_DATA=192
     gosub Lcd_Kom
     gosub Lcd_clr
    Lcd_Pod:
        rs=1
        e=0
        pauseus 1
        e=1
        pauseus 1
    Lcd_Kom:
        rs=0
        e=0
        pauseus 1
        e=1
        pauseus 1
    Lcd_SetX:
        LCD_DATA=64+posx
        gosub Lcd_Kom
    Lcd_SetY:
        LCD_DATA=184+posy
        gosub Lcd_Kom
    Lcd_Clr:
     for GLCD_n0=0 to 7
      posy=GLCD_n0
      gosub Lcd_SetY
      posx=0
      gosub Lcd_SetX
      LCD_DATA=0
      for GLCD_n1=0 to 63
       gosub Lcd_pod
      next GLCD_n1
     next GLCD_n0
    Lcd_Off:
    LCD_DATA=62
    gosub Lcd_kom
    Lcd_On:
    LCD_DATA=63
    gosub Lcd_Kom
    OverLCD:
    include "glcd.pbp"
    z var byte
    z=12
        pause 2000
    pocetak:
    @ PrintStr 1,0,"Some text and move to second line if first line isn't enought bla bla"
    PAUSE 2000
    @ PrintStr 7,4,"test"
    '@ PrintVar 3,6, _z ' I allways get random number
    Text works correctly, but the variable can not make it to work.
    Code is not mine, I downloaded it from the forum and make some changes.
    Oct 2010
    that's very interesting, thank you a lot.
    But why they dont make one for all of us?
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 19:14
  3. Play with LCD on PICDEM
  5. LCD will not start
