Graphic LCD support?
Results 1 to 23 of 23
    Oct 2010
    Default Re: Graphic LCD support?
    that's very interesting, thank you a lot.
    But why they dont make one for all of us?
    Look at what I found going through my archives:
    'GLIPICW.BAS Graphic application for use with a KS0108 (or compatible)
    'graphic LCD controller connected to a Microchip(TM) PIC 16F877
    'Written in MELabs PicBasicPro(TM) Ver 3.32
    'Beta version 0.8.0
    '================== NOT FOR COMMERICIAL USE =============================
    '       Author: Ranjit Diol - COMPSys LLC, March 2000
    '            (c) Copyright Ranjit Diol, 2001
    '   DISCLAIMER: This file is being released as non-commericial
    '   freeware. It is being provided "AS IS", neither the author,
    '   nor COMPSys LLC shall be held liable for any damages caused
    '   by its use.
    '   LICENSE: This application may be used in its entirety or
    '   in parts within some other non-commercial application as long
    '   as the author is given credit for those parts used.
    '        Contact: [email protected] for more information
    '                  IMPORTANT, PLEASE NOTE THE FOLLOWING
    'This application assumes you have a 64KBit external eeprom connected
    'via I2C. Without that you will only be able to send images directly
    'to the LCD display and not be able to store them -- See the readme.txt
    'for the Windows GLiPIC interface.
    'Adjust the PIN assignments as neccessary for your prototype
    'This was tested using a 20MHz xtal if you use a different OSC speed
    'you may have to make some adjustement in the 'strobe' subroutine.
    DEFINE ONINT_USED 1 'Required if using ISP
    DEFINE OSC 20   'OSC speed, you may have to tweak the 'strobe'
        'routine's e_pause constant for other speeds
    ADCON1 = 7   'Make all pins digital, you may adjust as needed
    SPBRG=0    '************ NOTE ***********
    RCSTA=0    'This is required if you are using
    TXSTA=2    'Shane Tolmie's bootloader (PICLoader)
    dat  VAR  PORTD  'LCD bus Pins 7-14 LSB-MSB
    scl  VAR  PORTC.3  'I2C SCL  for ext eeprom
    sda  VAR PORTC.4  'I2C SDA for ext eeprom
    in_pin   VAR    PORTC.7         'Serial input pin
    out_pin  VAR    PORTC.6         'Serial output pin
    e  VAR  PORTC.0  'Enable pin on LCD
    cd  VAR PORTC.1  'Data/Command Pin 4 on LCD
    rw  VAR  PORTC.2  'Read/Write Pin 5 on LCD
    cs1  VAR  PORTB.1  'ChipSelect1 Pin 15 on LCD
    cs2  VAR PORTB.2  'ChipSelect2 Pin 16 on LCD
    rst  VAR PORTC.5  'Reset Pin 17 on LCD
    'Set pins for output
    TRISB.0  = 0
    TRISB.1  = 0
    TRISB.2  = 0
    TRISD  = 0
    TRISC.0  = 0
    TRISC.1  = 0
    TRISC.2  = 0
    TRISC.3  = 0
    TRISC.4  = 0
    TRISC.5  = 0
    'Constants used
    ser_baud  CON    32             '19200 baud serout/serin
    ctl       CON    $A0  'EEprom control code
    row    CON  $b8  'LCD page 0
    last_row  CON    $bf  'LCD page 7
    col   CON    $40         'Line byte position 0
    last_col  CON    63             'Last column (1-64)
    first_col CON    0  'First column
    max_col   CON    128            'Last column (1-127)
    max_line  CON    8  'Line 8 (based on 1-8)
    max_pos   CON    64             'Column 64 positon per side (1-64)
    cr        CON    13  'CR for serout
    lf        CON    10  'LF for serout
    disp_on   CON    $3f  'LCD Display ON
    disp_off  CON    $3e            'LCD Display OFF
    disp_ram  CON    $c0            'Ram Display 0 (Page 0 at top of display)
    blank     CON    $00  'Blank character
    e_pause   CON    10  'Pauseus 6 for Strobe routine
    'Word variables used
    eepaddr  VAR    WORD
    addr     VAR    WORD
    'Arrays used
    in_array VAR    byte[32]
    in_ctl   VAR    byte[8]
    'Byte Variables used
    buff_count VAR  BYTE 'buffer count
    hex_nibble VAR  BYTE 'hex nibble from serin
    in_ascii   VAR  BYTE 'ASCII char from serin
    buf_cnt    VAR  BYTE 'buffer counter
    byte_pos   VAR  BYTE 'To keep track of a byte's position
    in_byte    VAR  BYTE 'The incoming byte
    tmp    VAR BYTE 'Temporary var
    index    VAR BYTE 'Index for arrays
    j    VAR  BYTE 'General counter
    k    VAR  BYTE 'General counter
    line    VAR  BYTE 'An LCD row
    delay      VAR  BYTE 'Execution delay, used with 'pause'
    'Initialize variables
    hex_nibble = 0
    byte_pos   = 0
    delay      = 10
    in_byte    = 0
    tmp        = 0
    index      = 0
    'Reset LCD
    dat = 0 ' Clear PORTD
    cd =  0
    rw =  0
    e =   0
    cs1 = 1
    cs2 = 0
    rst = 1
    pause 100 'Let things  stabilize
    rst = 0
    pause 10 ' Reset LCD
    rst = 1
    pause  500
    'Jump over subroutines to main program
    ' **** (GO)SUB ROUTINES ****
    strobe:
     e = 1
     pauseus e_pause
     e = 0
    clearall:
     cd = 0  ' Command mode
     dat = disp_off ' Display Off
     gosub strobe
     cs1=1
     cs2=0
     for index = 1 to 2
              for j = row to last_row
             cd = 0         'Command mode
              gosub strobe ' Write the data
             dat = col ' Column address = 0
             gosub strobe
             dat = j
             gosub strobe
             cd = 1  ' Write mode
               for k = first_col to last_col
                  dat = blank
                  gosub strobe
               next
       next
       swap cs1,cs2
            next
     cs1=0
     cs2=1
     cd=0
     dat=row
     gosub strobe
     dat = disp_ram ' Ram Line 0
     gosub strobe
     dat=col
     gosub strobe
     dat = disp_on 'display on
     gosub strobe
     cs1=1
     cs2=0
     dat=row
     gosub strobe
     gosub strobe
     dat=col
     gosub strobe
     gosub strobe
     cd = 1  ' Set Data command
     cs1 = 1  ' Left side active
     cs2 = 0
    init:   'Initialization
     cd = 0   ' Set command mode
     cs1 = 1   ' Left Side on
     cs2 = 0   ' Right Side off
             for index = 1 to 2
        dat = col  ' Y address = 0
        gosub strobe
        dat = row  ' Page = 0
        gosub strobe
        dat = disp_on ' Display On
        gosub strobe
        swap cs1,cs2
             next
     cs1=1
     cs2=0
    '****Place char on LCD Routine *****
    'Place byte of data on lcd assumes in_byte, byte_pos and line (line)
    'Char position on LCD byte_pos = 0-127 (Horiz), ROW 0-7 (vert)
    putbyte:
     dat = in_byte  'Display the byte
     gosub strobe
     byte_pos=byte_pos+1 'Increment position
     'Now do some LCD house cleaning and adjust counters
     if byte_pos=max_pos then
        cs1=0
        cs2=1
        cd = 0
        dat = col
        gosub strobe
        dat = disp_ram
        gosub strobe
        dat = row + line
        gosub strobe
        cd = 1
         if byte_pos = max_col then 'Check if
        line = line + 1  'New Line
                  if line = max_line then
             line = 0
         byte_pos = 0  'Reset byte_pos
            cs1=1
     cs2=0
     cd = 0
     dat=col
     gosub strobe
     dat = row + line
     gosub strobe
     dat = disp_ram
     gosub strobe
            cd =1
    '***** Convert incoming ascii to hex byte Routine *****
    find:
    Lookdown in_array[index],["0123456789abcdef"],hex_nibble
    ' **** BEGIN MAIN PROGRAM ******
     gosub init ' Initialize LCD
     gosub clearall ' Clear all pages
     serout2 out_pin,ser_baud,["Load image..."]
    goto term
    logo: gosub init ' Initialize LCD
    '**** DISPLAY IMAGES IN EXTERNAL 64KBit EEPROM VIA I2C *****
    ' Load opening screen from eeprom assuming a 64KBit eeprom
     byte_pos=0
     line =0
     for addr = 0 to 8192
            I2CREAD sda,scl,ctl,addr,[in_byte]
     gosub putbyte
            if (addr=1024) OR (addr=2048) OR (addr= 3072) OR (addr=4096) OR (addr=5120) OR (addr=6144) OR (addr=7168) OR (addr=8192) then
     pause 4000
     gosub init
     gosub clearall
     next
            pause 4000
     gosub init
     gosub clearall
    'goto logo  'Continue looping inifitum!
    'Terminal Subroutine
    term:  'Assumes Home Position
    'Setup variables
    j=0
    index=0
    k=0
    'line=0
    addr=0
    in_ascii = 0
    buff_count = 32
    delay = 10
    'addr = 0
    'byte_pos = 0
    'Get the initial parameters
    get_param:
            addr = 0
            byte_pos = 0
            line=0
     serin2 in_pin,ser_baud,[wait ("*"),STR in_ctl\9]
     for index = 0 to 8
            Lookdown in_ctl[index],["0123456789abcdef"],hex_nibble
     in_ctl[index]=hex_nibble
     next
     delay = (in_ctl[7]<<4) | in_ctl[8]
     buff_count = (in_ctl[1]<<4) | in_ctl[2]
     addr.byte1 = (in_ctl[3] <<4) | in_ctl[4]
     addr.byte0 = (in_ctl[5] <<4) | in_ctl[6]
     buf_cnt = (buff_count - 1)
            eepaddr = addr
     j=in_ctl[0]
     if j = 3 then lcd_loop   'Display directly on LCD
     if j = 1 then eep_loop  'Load ext eeprom
     if j = 2 then logo  'Display images loop
     goto get_param
    eep_loop:
      serin2 in_pin,ser_baud,5000,get_param,[wait ("]"),STR in_array\buff_count]  'Wait for ] and the load in_array
      for index = 0 to (buff_count - 1)
                    gosub find   'Get char and place in array
             in_array[index]=hex_nibble
      next
     for index = 0 to (buff_count - 1) step 2
      in_byte = (in_array[index]<<4) | (in_array[index+1]) 'Form a hex number MSB-LSB
             I2CWRITE sda,scl,ctl,addr,[in_byte]
             pause 5
                    addr=addr+1
     next
    goto eep_loop
    lcd_loop:
      next
             gosub putbyte
     next
    goto lcd_loop
    '*********** E N D ************
    ' **** END OF MAIN PROGRAM ****
    It had the following text file for pinout:
    GLIPIC BOARD Ver C and and Higher
    The GL board 20 pin header has the following pinouts:
    PIN ----- PIC PIN ------------ KS0108 pin
    01---------- GND --------------- GND
    02-----------Vdd 5v--------------Vdd
    03---- wiper of 20k pot-----------Vo
    04-----------PORTC.1--------------D/I
    05---------- PORTC.2--------------R/W
    06-----------PORTC.0-------------- E
    07-----------PORTD.0--------------DB0
    08-----------PORTD.1--------------DB1
    09-----------PORTD.2--------------DB2
    10-----------PORTD.3--------------DB3
    11-----------PORTD.4--------------DB4
    12-----------PORTD.5--------------DB5
    13-----------PORTD.6--------------DB6
    14-----------PORTD.7--------------DB7
    15-----------PORTB.1--------------CS1
    16-----------PORTB.1--------------CS2
    17-----------PORTC.5-------------RESET
    18-------one end of 20k pot----- Vee(connects to Vo via the 20k pot)
    19-----------PORTE.1---Do not connect to KS0108 LCD*
    20-----------PORTE.2---Do not connect to KS0108 LCD*
    *If the LCD has a backlight LCD PINS 19 and 20 are used to power the backlight. Usually, for an LED backlight PIN19 is the A (anode) and PIN 20 is K (cathode). However, on some displays the order is reversed. Check LCD documentation before connecting power to them!
    If you have a 128x64 KS0108 LCD with the above pinouts, then you can test out the GL board by running the Windows app GLUTIL2.EXE.
    All the credit goes to the good people at Compsys.
    http://www.compsys1.com/workbench/On...ontroller.html
    I had saved these files back in 2005 when I was starting on LCDs.
    Sep 2009
    I first I tried so I just used a lookup instead of eeprom ....
    Here's the code
    trisb=0
    trisd=0
    portb=0
    portd=0
    symbol RW=portb.3
    symbol RS = portb.2
    symbol E = portb.4
    symbol CS1 = portb.0
    symbol CS2 = portb.1
    symbol RST = portb.5
    Symbol LCDDATA=portd
    i var byte
    X var byte
    Y var byte
    pocetak:
    call init
     LCDDATA=0
     call clr
     cs1=0
     x=1
     call setx
     y=0
     call sety
     for i=0 to 63
        Lookup i, [$00,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0C,$00,$00,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FC,$F8,$F0,$00,0,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FE,$FC,$F8], LCDDATA
        call pod
     next i
     x=2
     y=0
     call sety
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$F0,$F0,$F0,$F0,$F0,$F0,$F0,$F0,$FF,$FF,$7F,$3F,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$00,$00,$E0,$FF,$FF,$FF,$FF,$E0,$E0,$C0,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF], LCDDATA
        call pod
     next i
      x=3
      y=0
     call sety
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$01,$01,$01,$01,$01,$01,$01,$00,$00,$01,$FF,$FF,$FF,$FF,$01,$01,$01,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF], LCDDATA
        call pod
     next i
      x=4
      y=0
     call sety
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,0,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF], LCDDATA
        call pod
     next i
     LCDDATA=0
     cs1=1
     cs2=0
      x=1
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$1E,$1E,$1E,$1E,$1E,$1E,$FE,$FE,$FC,$F8,$00,$FE,$FE,$FE,$FE,$0E,$0E,$0E,$0E,$0E,$0E,$0E,$FE,$FE,$FC,$F8,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA
        call pod
     next i
     x=2
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$80,$80,$80,$80,$80,$80,$80,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA
        call pod
     next i
      x=3
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF,$00,$07,$07,$07,$07,$07,$07,$07,$07,$07,$07,$07,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA
        call pod
     next i
      x=4
     call setx
     for i=0 to 63
        Lookup i, [$00,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$FF,$FF,$FF,$FF,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$00,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$E0,$FF,$FF,$FF,$FF,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00,$00], LCDDATA
        call pod
     next i
     PAUSE 5000
    cs1=1
    cs2=1
     CALL CLr
     x=0
     y=0
     call setx
     call sety
     LCDDATA=0
     CS2=1
     cs1=0
      y=10
      x=1
     call setx
     call sety
     for i=0 to 63
        Lookup i, [$00,$7E,$12,$1E,$00,$00,$7E,$4A,$4A,$4A,$00,$7E,$42,$42,$3C,$00,$60,$40,$7E,$00,$60,$1C,$12,$1C,$60,$00,$7E,$42,$7E,$00,$7E,$4A,$7E,$00,$5E,$52,$7E,$00], LCDDATA
        call pod
     next i
      y=26
      x=3
     call setx
     call sety
     for i=0 to 37
        Lookup i, [$00,$3E,$40,$3C,$02,$3C,$40,$3E,$00,$00,$3E,$40,$3C,$02,$3C,$40,$3E,$00,$00,$3E,$40,$3C,$02,$3C,$40,$3E,0,64,0,$7E,$4A,$4A,$4A,$00,$7E,$40,$40,$00], LCDDATA
        call pod
     next i
     cs2=0
     cs1=1
     x=3
     call setx
    for i=0 to 63
        Lookup i, [$7E,$4A,$4A,$4A,$00,$7E,$10,$18,$24,$42,$02,$7E,$02,$02,$00,$7E,$0A,$1A,$6E,$00,$3C,$42,$42,$42,$3C,$00,$7E,$0C,$30,$7E,$00,$00,$7E,$00,$7E,$10,$18,$24,$42,$00,$60,$1C,$12,$1C,$60,$00,$40,$00,$7E,$48,$78,$00,$60,$1C,$12,$1C,$60,0], LCDDATA
        call pod
     next i
     cs2=1
     cs1=1
    pause 2000
    for i=63 to 32 step -1
     LCDDATA=192+i
     call kom
     pause 400
    next i
    goto pocetak
    Init:
     x=0
     y=0
     rw=0
     cs1=0
     cs2=0
     e=1
     LCDDATA=0
     rst=0
     pause 1
     rst=1
     cs1=1
     cs2=1
     call Dispon
     LCDDATA=192
     call kom
    Pod:
        rs=1
        e=0
        pauseus 1
        e=1
    Kom:
        rs=0
        e=0
        pauseus 1
        e=1
    SetX:
        LCDDATA=184+x
        call Kom
    SetY:
        LCDDATA=64+y
        call Kom
    Clr:
     for x=0 to 7
      call setx
      y=0
      call sety
     LCDDATA=0
     for i=0 to 63
      call pod
     next i
     next x
    DispOff:
    LCDDATA=62
    call kom
    DispOn:
    LCDDATA=63
    call kom
    But then the problem was that every time I want to print something, I have to draw a picture of the entire display, or create the font, and for each letter copy 5 bytes. Then I found a forum for the LCD of Nokia 3310, and tried to correct for KS0108.
    I hope to be able to finish it, but now I am busy doing other things, so...
    Sao Paulo - Brazil
    Hi guys,
    I have been talking to our friend pedja089 about the lib in the first lib.
    I did some good improvements, and now, I can print strings and Variables correctly.
    I have already started writing some basic graphic routines, and I would like to publish it here as a contribution if our friend pedja089 agree with it, and I think he will.
    To test it I did a small simple digital clock, just to check if printing is working.
    The code compiles ok when I use a 18F4550 as a target controller. The hex's size is about 4500 bytes.
    But, when I change to the 16F877, (which has 8kb available) it always show me the following erros :
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6573)
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (7420)
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (436C)
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6F63)
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (6800)
    Message[303] c:\teste_~1\glcd_p~1.asm 207 : Program word too large.Truncated to core size. (7820)
    The line 207 in the Asm code is :
    data Str, 0
    from the macro :
    PrintStr macro x, y, Str
    local TheString, OverStr
    goto OverStr
    TheString
    data Str, 0
    OverStr
    MOVE?CB x, _GLCD_X
    MOVE?CB x, _GLCD_SX
    MOVE?CB y, _PosY
    MOVE?CW TheString, _GLCD_Addr
    L?CALL _GLCD_StringOut
    I admit that I am absolutely noob on writing/uderstanding assembler.
    Does some one have any ideao of what is wrong with this Macro.
    Is this restricted to 18F series ?
    Thank you !
    regards,
    Sérgio
    Yup 18F don't work the same way for embedded strings. You may want to have a look at least at the following.
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    Notice the use of da vs Data and how to retrieve them.
    You could also have a look at my NOKIA driver/wrapper.
    http://www.picbasic.co.uk/forum/show...?t=327&page=54
    Sao Paulo - Brazil
    Thank you Mister_e !
    I will spend some time this weekend trying to make the Lib better.
    I would like to make it work with 16F series (877 and above) and 18F and make it public.
    There are a lot of nice and cheap KS0108 for sale on eBay. I bought some from the seller Wide Hk and they are small and nice. Perfect for embeded solutions.
    Well, let´s study the posts and try to fix it !
    regards,
    Sérgio
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  5. LCD will not start
