Just can't get started
Results 1 to 8 of 8
    Sep 2015
    Default Just can't get started
    Hi All,
    I am a brand newbie to PICs as far as software goes, but I have about 30 years experience on the hardware side. I am having a devil of a time just getting an LED to blink with a 16F887. The LED is connected to port D bit 0; pin 19. I am trying to run blinkx.pbp from the melabs website; http://melabs.com/samples/LABX1-16F887/blinkx.htm. I have MicroCode Studio 4 with PicBasicPro v2.6 compiler. Here is the code:
    ANSEL = %00000000
    ANSELH= %00000000
    LED var Portd.0
    mainloop:
    High LED
    low led
    goto mainloop
    This gives syntax errors on lines 11 and 12 (ANSEL and ANSELH), and a bad data type error on line 13 (LED var Portd.0). I am really buffaloed by these errors. As I said, this example came right off of the microEngineering labs website. Any help would be appreciated.
    Thanks in advance.
    mike
    Default Re: Just can't get started
    Compiles without issue for me.
    Check to be SURE you have selected the correct PIC in Microcode studio, If that's not correct you will see those errors.
    Sep 2015
    Hi Archangel,
    I have the correct PIC selected. I was looking around at the menus, and inadvertently told it to find automatically the PBP compiler under View, Compile and Program Options. It reselected C:\pbp, so nothing has changed. But I still get these 3 compile errors. Any other ideas?
    regards,
    mike
    Quote Originally Posted by mikejp56 View Post
    Hi Archangel,
    regards,
    mike
Size:  70.5 KBName:  sucess.png
    Sorry I copy pasted your code, see the image. Now if you select a chip WITHOUT ansel you will error out.
    Mar 2005
    Cocoa, Florida
    Red face Re: Just can't get started
    HIGH and LOW do not require any port setup. They set as output automatically, see the manual.
    You don't need the ANSELs.
    Sep 2015
    Hi Archangel and kenif,
    I uninstalled MCS and PBP, and reinstalled both programs, and now it works.
    Thanks for your time.
    regards,
    mike
    I have PBPX 3.0.7.1 and is compiles OK - an obvious mistake is to select 16F877 when you mean 16F887. Maybe the syntax is different in 2.6? Anyone with 2.6?
    Among the more common things that got wrong (does not apply to your immediate problem) clock not running, incorrect setting of fuses and not turning off comparators. Suggest you have a look at anything by Darrel Taylor and in particular his ALLDIGITAL and FUSE CONFIGURATION programs.
    George
    That is only partly correct!
    HIGH/LOW manages the TRIS register for you but it does NOT manage ANSEL, CMCOM or any other registers which may prevent a digital pin from functioning as an output.
  1. Need help getting started.
    By TheOldFart in forum PBP3
    Last Post: - 1st January 2015, 10:18
  2. Help Getting Started
    By doggitz in forum mel PIC BASIC Pro
    Last Post: - 25th August 2009, 21:30
  3. getting started
    By cunninghamjohn in forum mel PIC BASIC Pro
    Last Post: - 15th November 2008, 18:42
  4. Getting started... again...
    By Neosec in forum mel PIC BASIC Pro
    Last Post: - 31st May 2008, 02:09
  5. getting started
    By rmow in forum Schematics
    Last Post: - 21st March 2008, 03:06
