Just as a precaution I would recommend to have the outputs at the same logic level when you do not want the sounder work. Thats because piezo do not like DC voltage.
Thanks Mr.Flotulopex and Mr.Ioannis !
It's verry usefull.
When the souder is not used, I set CCP1CON register to 0....I would recommend to have the outputs at the same logic level...
Is this okay?
Roger
....hum, sorry for my silly question
Just measured the ports and they need to be reset.
Thanks for noticing Ioannis![]()
Roger
As you observed Roger, you must be in luck to have both ports at the same level. They will be in a random state.
