LCD Display Formatting
Results 1 to 5 of 5
    Oct 2015
    Default LCD Display Formatting
    I am a newbie to PBP3.0 and have studied the LCDOUT statement in the reference manual for some time without much enlightenment. (Examples in very short supply). Anyway, what I believe I want to do is to measure a voltage level with a ADC input, convert the output of the A/D to an actual voltage by scaling, store the result in memory, and then later read memory and insert this data into an LCDOUT statement as follows
    LCDOUT $FE, $80, B0,B1,".",B3,"VOLTS"
    Is this form of formatting OK?
    Default Re: LCD Display Formatting
    That depends on HOW you scale the values and what's actually stored in B0, B1 and B2. As written the LCDOUT statement will send whatever is stored in B0 to the LCD meaning that if the B0 holds the value 65 you'll get the letter 'A' on the screen because the ASCII code for 'A' is 65. So, if you have ALREADY converted the value to ASCII and stored the first digit in B0 and the second in B1 then what you have is correct.
    What I suspect you want is something like
    Voltage VAR WORD
    Voltage = ADResult */ 125   'Convert 0-1023 to 0-500 (roughly)
    LCDOUT $FE, $80, DEC Voltage / 100, "." DEC Voltage // 100
    Oct 2015
    Hi Henrick,
    Yep, goes without saying that (a) the data stored would be in ASCII format and (b) I don't do stupid things like using B0,B1, etc instead of labels :-(. Geez, I am getting old................ As well as getting old, I'm getting lazy. Thank God for much early programming experience because the PBP manual ain't exactly forth coming :-)
    Thanks for coming back
    best regards
    Jim
    Voltage VAR WORD
    Oct 2009
    Utah, USA
    Have you set up the circuit and tested any of your code?
    If not then that is what I would do...
    noting like the instant feedback of seeing the minor changes to your code and the effect on what is displayed on the LCD.
    Dwight
    May 2009
    Yes your formatting looks good.
  1. formatting #config question
    By tracecom in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2013, 19:18
  2. Replies: 2
    Last Post: - 5th November 2009, 18:07
  3. glcd display vs lcd display
    By davids in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2009, 19:16
  4. Replies: 3
    Last Post: - 30th June 2009, 23:06
  5. serial formatting
    By barkerben in forum General
    Last Post: - 7th January 2005, 18:54
