Interrupt?? problem
Results 1 to 5 of 5
    scorpion's Avatar
    scorpion Guest
    Default say what now?
    I will try it first thing tomorow, but one question: If I move the disable and enable how will it ever get run? wouldnt it just skip right past those??? maybe im not sure exactly what you mean:
    disable 'disable interrupts
    ticker:
    intcon.2 = 0 'clear flag
    TMR0 = 129 'Set Preload
    tick = tick + 1 'keeps track of times it was interrupted
    if tick = onsteps then low pwmout 'if its where it needs to be to be switched, switch it
    if tick = 100 then 'if its at the end
    if current > offmax then high pwmout'and its above hysterisys then turn reset the PWM
    tick = 0 'and restart the ticker
    resume 'Restart the main program from where it left off
    enable 'enable interrupts
    I really cant see how this would work. i am assuming that i misunderstood.....
    Disable tells PBP to STOP auto-insertion of interrupt checking code. Placing
    disable "before" the interrupt service label doesn't actually disable interrupts.
    It just tells PBP to stop automatically placing interrupt checking code between
    each BASIC command. Your interrupt will work either way.
    ON INTERRUPT GOTO ? tells PBP where the interrupt service routine is located.
    Resume inserts RETFIE right at the end of your interrupt handler "code", and
    that's where you want RETFIE to be.
    Enable tells PBP to start auto-inserting interrupt testing code after each
    BASIC instruction, and you want this at the very end or after RESUME. Just
    like the ON INTERRUPT example shown in the manual.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    scorpion's Avatar
    scorpion Guest
    Talking
    gotcha.
    thanks for the help!
    -scorp
  1. problem using GOSUB under interrupt
    By fobya71 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 19:52
  2. Problem with Interrupt on PIC18F4620 PORTB
    By rookie in forum Off Topic
    Last Post: - 22nd March 2007, 01:34
  3. Interrupt Problem
    Last Post: - 16th November 2005, 20:58
  4. Interrupt stack overflow problem with Resume {label}
    By Yuantu Huang in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2005, 01:17
    Last Post: - 6th March 2005, 01:07
