LCD defines?
Results 1 to 19 of 19
Thread: LCD defines?
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    Im using a JDM programmer (the one called "Serial Port Programmer - Socketed" at http://www.sparkfun.com/shop/index.p...=323317&cat=3&) and IC-Prog as my downloading program. I just tested the IO lines and they all work.
    I have also tried the program on another PIC18F252 and I get the same results.
    EDIT:
    The LCDOut command is for 44780 controllers right??
    RUBiksCUbe, If I may ask, What type of LCD display is it? Who makes it? Part number?
    Dec 2003
    Wichita KS
    I Noticed that your comment was the black squares were on the second line... I also noticed the examples presented looked like they were all for the first line of your LCD.
    1. Since you only have 1 line of squares on your LCD, then I would suspect your line 1 is bad... test another LCD.
    2. If you want, try writing to your second line on your LCD...
    I believe the command is a $C0?
    Somthing like :
    LCDOUT $FE,$C0,“Hello”
    If this works on your second line... then you may have found your problem.
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    The LCD is a 16 character by 2 line display. Although it says "UNIQ/eVision" on the back, it has the part number GC-1602I1 Ver: C, which is a part number for Solomon Goldentek display company. They don't have the exact datasheet on their website, but the closest one they have is here: http://www.goldentek.com/english/pdf...B0SBL1B%20.pdf
    I was told when I bought it (on ebay) that the display driver is 44780 compatible.
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I put the LCDOUT $FE,$C0,“Hello” into the program but it did not work either. This LCD must be busted.
    They use samsung controller KS0066 wich is really compatible with Hitachi, in fact i have some LCD here with the same controller and i used the same code... as is and it's work...mmm weird
    Yuk, probably not really handy but, worth a try...
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    @ __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    @ __CONFIG _CONFIG4L, _LVP_OFF_4L
    Define OSC 10
    TRISA=0
    TRISB=0
    Define LCD_BITS 4   ' 4-bit interface
    Define LCD_LINES 2 ' 2 line LCD
    ' LCD should be connected as follows:
    ' LCD PIC
    ' DB4 PortA.0
    ' DB5 PortA.1
    ' DB6 PortA.2
    ' DB7 PortA.3
    Define  LCD_DREG  PORTA
    Define  LCD_DBIT  0
    ' RS PortA.4 (add 4.7K pullup resistor to 5 volts)
    Define  LCD_RSREG  PORTA
    Define  LCD_RSBIT  4
    ' E PortB.3
    Define  LCD_EREG  PORTB
    Define  LCD_EBIT  3
    ' RW Ground
    ' Vdd 5 volts
    ' Vss Ground
    ' Vo 20K potentiometer (wire wiper to Vo, adjust for contrast)
    ' DB0-3 No connect
    Define LCD_COMMANDUS  2000 ' Adjust for slower LCD modules
    Define LCD_DATAUS 50
    ADCON1 = 7 ' portA digital
    Pause 1000
    FLAGS=0
    Pause 1000
    loop:
        Lcdout $fe, 1,"Hello"
        Pause 500 ' Wait .5 second
        Lcdout $fe, 1,"World"
        Goto loop ' Do it forever
    I heard few time, but never encouter the problem, that some LCDs are noise sensitive, what about if you add a 0.1uF and a 10uF(or higher) on the VDD line close to the LCD(as close as you can)???
    Now if nothing works... it could be a blowed one... On EBay... not a surprise
    RUBiksCUbe's Avatar
    RUBiksCUbe Guest
    I tried capacitors with no success, so Im going to try to get another. Thanks for all the diagnostic help!
    Daniel's Avatar
    Daniel Guest
    Default UNIQ/eVision 16x2 LCD
    Hello RUBiksCUbe,
    I have just bought the same display as you and I was searching the net for datasheet and found this page.
    I have not received this display and I hope I will get it working.
    But it doesnt sound good to read your problem.
    I hope to get it in a week or two, then I will test it and come back to you guys.
    Good luck now...
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. LCD will not start
  5. Configuring Defines For 8-bit LCD
    Last Post: - 1st November 2006, 10:59
