Scrolling text on display
Results 1 to 8 of 8
    But if you plan to do some smooth scrolling... you better use some GLCD. a 2 lines character display will not do the effect you want... well i guess.
    It's not impossible with a character display but you'll have to build a load of specific half, quater dimension character table and refer to them do produce the effect.... much code than results IMHO.
    Feb 2005
    Kolkata-India
    Thumbs down I agree with mister_e
    It is not practical to do a smooth vertical scroll on display. Even if you use half and quarter height custom characters the gap between the first and the second line is bigger than that between characters.
    You can copy the second line to the first line, then write a new second line and repeat the entire process with a pause. This would let you display much more info on that tiny LCD. However a graphic LCD would be a better option if you have enough room.
    Sougata
    Talking
    Is there ... Is there ... some echoe .... Is there ... some echoe .... here ... some echoe ... here ... ???? ... ???? .... here ....
    Alain ... Alain ... Alain ... Alain ... Alain ...........
    Srig: If you just want one code example of how to scroll some text (sideways), download the Olympic Timer thread pdf wherein some text scrolling was put in just for fun.
  1. 8x8 Scrolling LED display (Simple example)
    By wellyboot in forum Code Examples
    Last Post: - 11th July 2013, 06:03
  2. Hdsp 21xx display
    By Original in forum mel PIC BASIC Pro
    Last Post: - 7th June 2012, 21:07
  3. Replies: 2
    Last Post: - 5th November 2009, 18:07
  4. 5x7 LED Matrix Scrolling Display
    By roycarlson in forum mel PIC BASIC Pro
    Last Post: - 5th August 2008, 00:50
  5. Replies: 14
    Last Post: - 26th September 2007, 06:41
