Soft-start for mains LEDs?
Results 1 to 11 of 11
    Default Re: Soft-start for mains LEDs?
    Dave, this is not an exposed LED; its one of those LED bulbs that directly replace an incandescent or CFL lamp in its mains holder.
    Hi Anand. I did this so long ago I forgot how. But I remember using a triac and diac configured as a lamp dimmer. It started as dim and gradually ramped up by charging a capacitor. I also remember one of my attempts blew everything up. Be careful. An exploding capacitor is like a firecracker with electrolyte inside.
    Hi Peter, thanks for that information; now I know at least that its possible!
    Do you have any tips at all, from whatever you can remember? Those would go a long way towards not re-inventing the wheel.
    I'm familiar with triacs and phase control, as can be applied to incandescent bulbs, or resistive, or inductive loads. Its just that I cant figure out how to control something like these, to ramp up to full intensity spread over a few seconds. http://www.shopclues.com/philips-led...B&gclsrc=aw.ds
    Anand
    Sorry Anand. This was at least 20 years ago. All I remember is building a dimmer circuit and modifying the section that used the potentiometer to control the brightness. If I had to do it all over again, I would probably buy a dimmer and modify it. It's probably cheaper than buying all the parts and making it yourself.
    Peter, LED lamps (bulbs) 20 years ago?
    Yes. In about 1980 a buddy of mine had a digital LED wristwatch, LED calculators and alarm clocks were becoming popular. Google it. LED's were around since the 70's.
    I'm sorry I wasn't clear in my original post. Of course I didn't do the brightness thing with an LED replacement bulb. It was to slowly start an AC motor but the same process would work with AC lighting.
  1. Soft On/Off switch
    By Audette in forum General
    Last Post: - 18th August 2012, 20:54
  2. Run a string of LEDs from the mains
    Last Post: - 1st October 2009, 19:55
  3. 'Soft' On/Off Power Switch
    By Art in forum General
    Last Post: - 14th November 2008, 02:54
  4. Measuring mains load
    By Freman in forum General
    Last Post: - 13th June 2008, 01:33
  5. HT-Soft C compiler issues
    By ken_mazur in forum General
    Last Post: - 19th October 2006, 15:10
