help with PIC 16f877
Results 1 to 13 of 13
Threaded View
  1. #6
    naffets_23's Avatar
    naffets_23 Guest
    ok
    well our instructor decided to change the school project to using serial instead of parallel communication
    i am using pic code for the first time and im not sure how to get the pic to capture the input from the 8 switches and output it.
    which ports on the pic do i use?
    because when i was checking out the pic schematic, all the ports could be programmed ?!
    how do u determine which ports to use and how would u modify the code that SuB-ZeRo gave me for serial?? (thank u very much for ur help SuB-ZeRo)
    finally, how do u setup the baud rate??
    let me explain
    the pic takes the input from the switches and outputs to the serial port on the computer
    if i setup the pc's com port to use a baud rate of 9600... how do i setup the pic to output at that baud rate?
    please keep in mind, i have never used a pic before but that doesnt mean that u cant throw some moderate code at me... just that ill ask questions later!
    thanks for all ur help
  1. SPI Communication between two pic 16f877
    By anti83 in forum Serial
    Last Post: - 5th July 2008, 21:06
  2. serial communication between CMUcam and PIC 16F877
    By gengkeys in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 06:43
  3. pic 16f877 iel kayan yazı
    By bedir in forum mel PIC BASIC Pro
    Last Post: - 14th January 2007, 07:10
  4. Use the PIC 16f877 or 877A instead of shift registers.
    By tsanders in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 17:23
