How can I read an RS485 stream?
Results 1 to 5 of 5
    Feb 2005
    GREECE
    Question How can I read an RS485 stream?
    Hello guys,
    I hope you are all well.
    A simple question.How can I read an RS485 stream from a device(MASTER) using 16f628(SLAVE).Do I need to convert the stream to rs232 protocol?
    I have MAX1482 low power transeiver for rs485 communication.
    Please send any usefull info,schematic.
    Best Regards
    Nikos Geronikolos
    Mentor, Ohio
    Smile
    Hello ngeronikolos,
    Rs485 is simply the transmission means to send serial data from one device to many. You use a RS485 transceiver connected to the same pins on the PIC that you would connect a RS232 interface and then you can send and receive your data as you would regular RS232. You will need to create the software that will talk to the individual slaves. Search this forum as there have been articles written about RS485. You can also get Jan Axelson's great book on the SERIAL PORT. It has alot of examples of RS485 communications.
    BobK
    Jun 2005
    Wisconsin
    One tip: You have to place the chip in either transmit or receive mode. If your planning on doing some type of bidirectional communication you will need to use one pin on your PIC for this task AND write your commands to toggle it when needed.
    Feb 2005
    GREECE
    Thanks guys,
    I understand.I have to use the same commands as in RS232 interface?
    If it is that correct,I have to replace the max232 with the MAX1482. My chip I want to be in receive mode!!
    Before I connect the master device with my pic,how can I read the data using my COM1 of my PC?
    Nikos Geronikolos
    Jun 2005
    Wisconsin
    To receive via your PC you would need to connect the RS-485 transceiver to a RS-232 converter. You would then either pull RX TX enable lines high or low. Alternatively, you could tie the enable line to RS on the serial port...your call.
  1. Cleaning up code
    Last Post: - 2nd December 2009, 07:14
  2. SEROUT WORD variable problem
    Last Post: - 19th April 2009, 11:20
  3. Q: using MCLR for Input on 12F683
    By picster in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 15:25
  4. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  5. Conflict receiving RS485 stream
    Last Post: - 4th August 2005, 15:27
