Battery monitoring - ever tried AN1072?
Results 1 to 40 of 57
    SWITZERLAND (french speaking)
    Thumbs up It works!!!!
    Finally YOU made it!!!
    I just changed my circuit to power it directly from my variable power-supply and simulate the batterie's weakening.
    @5VDC, my display shows a value of 135 and @4,2VDC (can't go lower or my display won't work anymore) I read 147.
    So, except the particular init sequence for the LCD I use, the code example here under is working fine and should be quite standard.
    ' PIC 16F690 Fuses
    @ __config _FCMEN_OFF &_IESO_OFF &_CPD_OFF &_WDT_OFF &_HS_OSC &_BOR_OFF &_CP_OFF &_PWRTE_OFF &_MCLRE_OFF
    ' Registers   76543210
    OPTION_REG = %10000000 'OPTION register
    ANSEL      = %00000000 'Select analog inputs Channels 0 to 7
    ANSELH     = %00000000 'Select analog inputs Channels 8 to 11
    WPUA       = %00000000 'Select weak pull-ups
    WPUB       = %00000000 'Select weak pull-ups
    ADCON0     = %00000000 'AD Module
    ADCON1     = %00000000 'AD control register
    CM1CON0    = %00000000 'Comparator1 Module
    CM2CON0    = %00000000 'Comparator2 Module
    INTCON     = %00000000 'INTerrupts CONtrol
    TRISA      = %00000000 'Select Input/Output (0 to 5)
    PORTA      = %00000000 'Set High/Low (0 to 5)
    TRISB      = %00000000 'Select Input/Output (4 to 7)
    PORTB      = %00000000 'Set High/Low (4 to 7)
    TRISC      = %00000000 'Select Input/Output (0 to 7)
    PORTC      = %00000000 'Set High/Low (0 to 7)
    ' Defines
    DEFINE OSC 8
    DEFINE LCD_DREG PORTC  'LCD data port
    DEFINE LCD_DBIT 4      'LCD data starting PORT.bit (0 or 4)
    DEFINE LCD_RSREG PORTC 'LCD register select port
    DEFINE LCD_RSBIT 3     'LCD register select bit
    DEFINE LCD_EREG PORTC  'LCD enable port
    DEFINE LCD_EBIT 2      'LCD enable bit
    DEFINE LCD_BITS 4      'LCD bus size 4 or 8
    DEFINE ADC_BITS 10     'Number of bits in ADCIN result
    ' Init display
    ' ELECTRONIC ASSEMBLY DOGM081 LCD display Mandatory settings
    '  See datasheet for circuitry changes by 5V or 3,3V operation
    PAUSE 1000      'Time to settle Vdd (THIS IS CRUCIAL FOR THIS DISPLAY!!!)
    LCDOUT $FE, $29 'Function Set: 4 bits bus mode
    LCDOUT $FE, $1C 'Bias set
    LCDOUT $FE, $52 'Power control + Contrast (HiByte)(for 5V=$52 or 3,3V=55)
    LCDOUT $FE, $69 'Follower control (5V=$69/3,3V=6D)
    LCDOUT $FE, $78 'Contrast (LowByte)
    ' Variables
    Bat_Value   var word 'holds ADC value
    Bat_Value   = 0
    ' Start program
    MAIN:
        ADCON0=%10110101   ' Here we drive the 0,6 volts to the ADC
        'ADCON1=%00110000   ' I prefer to be sure to have FRC for the beginning at least
        VRCON= %00010000   ' Enable the VP6 reference
        ADCON0.1=1
        WHILE ADCON0.1 : WEND
        Bat_Value.HIGHBYTE = ADRESH : Bat_Value.LOWBYTE = ADRESL
        LCDOUT $FE,2,DEC4 Bat_Value
        PAUSE 1000
    GOTO MAIN
    Using the internal 0,6V reference:
    - 0,8Vbatt difference = 12 value change
    + no external components
    Using an external voltage divider:
    + 0,8Vbatt difference = 84 value change
    - external components
    Thanks a lot for all your help
    Roger
    Default Adcin 13
    ...and while testing things, here is something I just tried based on the code in my previous post using the ADCIN command:
    ' Start program
    MAIN:
        ADCON1 = %00110000   ' I prefer to be sure to have FRC for the beginning at least
        VRCON  = %00010000   ' Enable the VP6 reference
        ADCIN 13, Bat_Value  ' ADCON0 = %10110100 where bits 5:2 are the 0,6V reference's channel address (1101 = 13)
        LCDOUT $FE,2,DEC5 Bat_Value
        PAUSE 1000
    GOTO MAIN
    The results are @5VDC I read 8640 and 9790 @4,2VDC (?!) but it looks to work somehow.
    Roger
    Default Re: Adcin 13
    The ADC is 10 bit, the largest value you can read is 1023 (10 1's). BTW check to table in the ADC section re. recommended ADC clock source, at 8 Mhz use Fosc/16 or Fosc/32. See note re using FRC as a clock source above 1Mhz.
    You seem to have missed out the conversion to 0v1.
    George
    Are you sure that you still have right justification? Maybe you have accidentaly set the ADCON.7 to zero?
    In general the bigger number for lower voltage is correct. Since you have the same 0,6 volts at the ADC input, lowering the Vref (through Vdd) will give bigger ADC result.
    But not more than 1023 as George stated.
    Default "Right Justifying" is the key
    Thanks Ioannis and George,
    Here is the corected and 100% working code example using ADCIN:
    ' PIC 16F690 Fuses
    ' Defines
    DEFINE OSC 8
    ' Init display
    ' Variables
    Bat_Value   = 0
    ' Start program
    MAIN:
        ADCON0 = %10000000   ' Here we drive the 0,6 volts to the ADC
        ADCIN 13, Bat_Value  ' Select the VP6 channel's address ADCON0 = %xx1101xx
        PAUSE 1000
    GOTO MAIN
    Roger
    Default Re: "Right Justifying" is the key
    Did you see how to convert he ADC count in Bat_Value to volts?
    I see you are still not using a recommended value for ADCS in ADCON1.
    George
    Default the maths and the proof the system works
    Yes George,
    For any reason, either ADCON1.ADCS setting will affect the results.
    For those interested in the maths (where "2n" is 1024 because I use 10bits in ADC):
    Name:  2015-09-30 21_43_57-Clipboard.png
    Regarding my results and comparing them to the table A-1 (Appendix A: AC Result Table in AN1072), something must be wrong.
    A 135 ADC result corresponds to 4,52V and 147 to 4,16V (?!).
    Grrrrrr! I didn't notice I hadn't removed the voltage regulator on my breadboard. My PICkit2 programmer delivers 4,78VDC (even if it shows 5V in the "VDD PICkit2" field) so the "new" ADC values I get now seem to be much closer to what they are supposed to be "on the paper".
    For 4,82V displayed on my FLUKE87, the ADC result is now 127 (exact as table A-1) and @4,31V I get 142 (exact as table A-1).
    ((1024 - 1) / 4,82) * 0,6 = 127 and ((1024 - 1) / 4,31) * 0,6 = 142
    Roger
  1. Battery voltage monitoring for use on 16F1825
    Last Post: - 23rd April 2013, 15:57
  2. Replies: 13
    Last Post: - 22nd January 2012, 05:48
  3. ADCIN car battery monitoring
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 09:04
  4. 12v car battery monitoring
    By oldcarguy85 in forum Schematics
    Last Post: - 10th December 2007, 01:26
  5. Using the A/D for Monitoring a Solor Cell and Battery
    By chuck.sieveking in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 20:27
