Battery monitoring - ever tried AN1072?
Results 1 to 40 of 57
    SWITZERLAND (french speaking)
    Default Re: Battery monitoring - ever tried AN1072?
    Thanks George,
    The aim of the thread I started is to find a good solution to check the battery's condition regardless with what PIC it is used.
    In my case, I'm building a cooking timer and I have a sounder that needs at least 5VDC. So I'll better know when the batteries get low or my eggs will be like stones
    Roger
    Hi Roger.
    I like my egg like stones, but thats just me...!
    About your circuit, you put a transistor I suppose to conserve energy while not measuring the battery, right?
    But when the transistor is OFF, you drive a PIC input at 6 volts, higher than the specs, and also higher than the Vdd supply. So, the protection diodes of the input will forward the current to the PIC Vdd pin and you fry your PIC than your eggs!
  1. Battery voltage monitoring for use on 16F1825
    Last Post: - 23rd April 2013, 14:57
  2. Replies: 13
    Last Post: - 22nd January 2012, 04:48
  3. ADCIN car battery monitoring
    By mitchf14 in forum mel PIC BASIC Pro
    Last Post: - 29th June 2008, 08:04
  4. 12v car battery monitoring
    By oldcarguy85 in forum Schematics
    Last Post: - 10th December 2007, 00:26
  5. Using the A/D for Monitoring a Solor Cell and Battery
    By chuck.sieveking in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 19:27
