Message String Table using Readcode
Results 1 to 3 of 3
    Feb 2004
    Germany
    Michael,
    apart from the fact that you have missed to declare ascii VAR BYTE
    it works just fine on my 18F's
    That way I can probably get rid of an external EEPROM I was using for message strings.
    (presuming there is codespace left to store the strings)
    MANY THANKS!
    I'll do some further testing and let you know the results.
    regards
    Ralph
    mytekcontrols's Avatar
    mytekcontrols Guest
    Wink Oppps!
    Thanks Ralph,
    I fixed it.
    Depending on how you were doing this before, you might see a tremendous savings (especially true if you were using PBP's Table Lookup function).
    I certainly can't take all the credit for the idea, since much of this was made possible by looking at other people's code examples. However I do think my approach is possibly unique, since I have been looking, and looking for a solution like this for quite some time now, and never found anything exactly like it. I would be curious to know what other PICs this will work on, since all I use now-a-days are the 18F series, and have no easy way to confirm this.
  1. How about String Variables?
    By mytekcontrols in forum PBP Wish List
    Last Post: - 20th January 2015, 13:53
  2. Lookup Table
    By yasser hassani in forum mel PIC BASIC Pro
    Last Post: - 11th March 2008, 11:38
  3. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 08:50
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. PIC 18F452 Table Pointer/ Table Read
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 04:07
