Asynchronous baud rates on a 12F683 (serin / serout)
Results 1 to 4 of 4
    Default Re: Asynchronous baud rates on a 12F683 (serin / serout)
    Ok,
    I see some "minor details"
    Var names must generally match B0 != b0
    You used 1 for the pin name, I don't use that as it confuses me, I use GPIO.1
    Defines must be caps, Define OSCCON_1K, define OSC 4 (notice I did NOT Capitalize the word define (no matter) but OSC IS CAPITALIZED.
    DEFINE OSCCON_1k 1 ' 4 ' 4mhz
    ANSEL = %00000000 ' all pins digital
    Include "modedefs.bas"
    OSCCON = %01100000
    B0  var byte
    B1  var byte
    B10 var byte
    SERIN GPIO.1, T9600, 10, main, [$65],B1,B0
    You might find the debug command is faster, and more compact than any of the other "software" serial commands.
  1. 18F24J11 clock and HSER/HSER2 baud rates
    By kinburn in forum mel PIC BASIC Pro
    Last Post: - 17th September 2010, 19:00
  2. 2 Pics, different baud rates needed
    By peter_wiersig in forum Serial
    Last Post: - 27th February 2010, 16:51
  3. HighSpeed A/D and Baud Rates
    By flyingasics in forum mel PIC BASIC Pro
    Last Post: - 14th January 2010, 02:35
  4. DEBUG baud rates
    By btaylor in forum Serial
    Last Post: - 23rd January 2006, 13:00
  5. Faster baud rates with SEROUT commands
    By TurboLS in forum PBP Wish List
    Last Post: - 19th February 2005, 11:05
