Pic18f452 pwm1 and pwm2 help
Results 1 to 10 of 10
    Jun 2008
    Varese , Italy
    Default Re: Pic18f452 pwm1 and pwm2 help
    The point is that there is no output on any pin of the PIC18 relevant to the pwm2.
    I did check all the pins using the scope.
    I have good output for pwm1 only.
    I uded the HPWM of the picbasic pbp2.50 as above: so the output should be at the hardware pins c1 and c2 if the spec os correct.
    Is there someone that was able to get two PWM's output from the pic18f452 ? ( of course having the same frequency but a different duty cycle ).
    Ambrogio
    DEFINE CCP2_REG PORTC 'Channel-2 port
    DEFINE CCP2_BIT 1 'Channel-2 bit
    might help
    assuming you are using portc.1 for ccp2
    could even try trisc.1=0 also
    Jun 2008
    Varese , Italy
    Thanks Richard,
    no way for me to get output for both pwm's:
    I did try your suggestion too.
    Pls: see the attached code.
    regards,
    Ambrogio
    __CONFIG _CONFIG3H, _CCP2MX_OFF_3H puts ccp2 onto portb.3
    use
    DEFINE CCP2_REG PORTB 'Channel-2 port
    DEFINE CCP2_BIT 3 'Channel-2 bit
    or
    __CONFIG _CONFIG3H, _CCP2MX_ON_3H
    or set trisb.3 to 0 and trisc.2 to 0 and CCP2CON=12
    from data sheet
    bit 0 CCP2MX: CCP2 Mux bit
    1 = CCP2 input/output is multiplexed with RC1
    0 = CCP2 input/output is multiplexed with RB3
    Jun 2008
    Varese , Italy
    Richard,
    thanks very much for the great help in solving my problem.
    The output of pwm2 is now available on B3: very good !
    All the best
    Ambrogio
  1. pic18f452 ADC
    By hamid_knight in forum General
    Last Post: - 15th December 2009, 16:42
  2. Shiftin pic18f452
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 18th August 2009, 10:38
  3. PIC18F452.INC not found
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 27th March 2008, 00:53
  4. Pic18F452
    By TonyCNC in forum mel PIC BASIC Pro
    Last Post: - 25th July 2007, 06:29
  5. pic18f452 programmer
    By ahmet2004 in forum Schematics
    Last Post: - 19th July 2004, 09:20
