Microchip TC32M Supervisory Circuit and Bootloader
Results 1 to 8 of 8
    modifyit, I personally use the ADM690 or MAX690 supervisory ic in my designs because if the input pin is left unconnected or (tristated) the watchdog timer quits operation. This way during the bootloader initialization the port I have it connected to is also in a input or (tristate) mode so the bootload can take place. After which the port is programmed as an output and from then on the watch dog timer will have to be strobed atleast every 1.6 seconds before it will reset the micro and external circuitry. Try it, You'll like it....
    Apr 2005
    The MAX690 seems to be a nice solution, but the watchdog timeout is a little long at 1.6sec. I think I would prefer to use the TC32M if I can figure out a creative way to do it.
    mytekcontrols's Avatar
    mytekcontrols Guest
    Question
    Just curious...
    Any reason you're not using the PIC's internal watchdog and/or brownout detector?
    Apr 2005
    My project is working in a harsh enviroment which has caused issues with the microprocessor even with internal brownout and watchdog protection. So partially its out of necessity and partially belts and suspenders.
    Apr 2005
    Any other thoughts? I guess I could try and come up with a circuit that will monitor the rs232 chip to tell if it is programing and disconnect the mclr from the TC32M when that happens. I'm not positive how to do that tho.
    Thanks again
    Feb 2004
    Germany
    Quote Originally Posted by modifyit
    Any other thoughts?
    How about using a 10F PIC as supervisory circuit?
    (It would be fully programmable)
    That's what I'm going to do on one of my current projects.
    regards
    Ralph
    Apr 2005
    Interesting thought, how would you suggest implementing the brownout protection portion of the 10F?
    I guess I could make a 10F send a strobe out to reset the TC32M during a bootload.This may be a little excessive tho, not sure what I am going to do at this point.
  1. Max/232 Bootloader problems - Schematic attached...
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 16:54
  2. MAX232 Pin Voltages / Bootloader / Microcode Studio
    By rossfree in forum Schematics
    Last Post: - 3rd May 2007, 16:00
  3. Bootloader Problems
    Last Post: - 11th February 2005, 18:51
