AC Signal...
Results 1 to 19 of 19
Thread: AC Signal...
    Tear's Avatar
    Tear Guest
    After posting this morning I was looking at the data sheet for the PIC16F84 and came to the same conclusion that the PIC16F84 doesn't have an A/D converter. However, even if I went to a pic that did have a A/D converter that still wouldn't do anything for me then? I am not sure how the A/D converter works and I am going to look into this this afternoon.
    I am also having a little bit of trouble understanding your circuit schematic. From what I understand it looks like the diode goes across terminals 1 (L) and 2 (N) of the IC1. (L) I am guessing is the AC Voltage coming in through the capacitor and then into terminal 1 of the IC1. Pin 4 goes to the input pin of the microcontroller, and pin 3 goes to ground. What is the (N) or what I am guessing is pin 2 to IC1?
    Thanks for the help and sorry for the confusion on my part.
    Michael
    Feb 2004
    Germany
    Tear,
    before we continue our guessing session,
    would you tell us a bit more in detail what you are actually trying to achive?
    (At least to me t is not really clear)
    Your initial posting on this thread sounds a bit like you would like AC to supply your PIC.
    regards
    Ralph
    The L and N are Live and Neutral from your high-voltage AC Supply Input.
    Warrier's Avatar
    Warrier Guest
    Default AC signal
    Ms. Newman,
    don't you think you need to provide a DC path for the LEDs in the opto coupler to conduct? - even a 100k would be sufficeint as the voltage across the diodes is clamped to about +/-1.7volts.
    I think Mr. Schmidt should be warned of potential shock hazards! If he is aware of it then he could even use a series resistor (1Meg or more) to any input as the internal clamping diodes will limit this to Gnd and Vdd.
    But then Ralph's question is also valid... Is Mr. Schmidt trying to use an AC power source? Hope not since he has used the title "AC Signal" and refers to internal ADC for the F84!
    -warrier
    Feb 2004
    Germany
    Quote Originally Posted by Warrier
    ...a 100k would be sufficeint as the voltage across the diodes is clamped to about +/-1.7volts.
    Well, in general this is correct, but:
    lets's assume the Opto's LED current is as low as 10mA,
    even at that low current at a voltage of 120 or 240 V the resistor would have to be quite large (in size) and dissipate a lot of heat,
    would you really like this?
    regards
    Ralph
    Warrier's Avatar
    Warrier Guest
    Default AC signal
    Ralph:
    Sorry I didn't make it clear, I guess. When using the optocoupler, the resistor would be across the two back to back LEDs inside the opto coupler. So the voltage across the resistor would only be +/- 1.7volts (the LED drop). Wattage is thus not an issue...
    The series resistor of say 1Meg is INSTEAD of the opto coupler and need not carry the LED currents. It would be connected in series with the input pin of the PIC and is to limit the current through the clamping diodes provided on all I/O pins with a max current limit of +/-20mA.
    With a 1 M resistor, the I/O current is safely limited to 240uA and the wattage would be about 0.06watts for the 240VAC. My concern was that Mr. Schmidt may accidentally come in contact with the live AC line with a "shocking" experience**** There might be some fire-works also.
    -warrier
    -warrier
    No. Think outside the box. Look at what C1 is doing at the supply frequency.
    Again no. This particular opto only has one LED.
    You really want to rely on a Resistor and the PICs clamping diodes to stand between you and oblivion?
    In my circuit the LIVE AC is on the primary (input) side of the opto. No LIVE circuitry (nope not even 240uA of it) ever touches the PIC. If your Resistor failed, the PIC would become LIVE at supply potential. In my circuit, if either C1, D1 or the opto failed, you would still be insulated by the ISOLATION characteristics of the opto (usually 5kV breakdown or more).
    This is not a 'Theoretical' circuit plucked out of the air... it actually works and is in use in thousands of products every day. In the snapshot appended, here is the very circuit where the PIC is monitoring the state of two totally separate but critical AC Supply fuses.
    Tear's Avatar
    Tear Guest
    What I am trying to accomplish is to build a delay device that turns on your amp a few secs after the radio is turned on. I have already built this using the amp turn on line from the stereo which is DC Voltage line. However for my brother's car, that I also would like to put this in, his stereo doesn't have an amp turn on. Due to this I need to use the speaker lead which is an AC voltage signal.
    Orginally I thought that using a AC/DC converter on a microcontroller might do the trick, but on further inspection it turns out this is not the case. I am now thinking about building a simple PNP Transistor Switching Circuit where the AC Voltage signal (line) would be connected to the base and control the switching with a +5V DC voltage following to the PIC when the switch is closed. However, I am not sure if this will work.
    Essentially the easiest way to characterize what I need to do is somehow have the PIC dectect when the AC signal is HIGH either directly or maybe through some circuit like a PNP Transistor switch. Once the PIC detects the line as being HIGH then it will delay and set the output HIGH.
    I hope that this explains what I am trying to do a little better, and thanks for the help.
    ~Michael
  1. Measuring p-p of a 1.5v to 12v ac signal?
    By sccoupe in forum mel PIC BASIC Pro
    Last Post: - 30th October 2009, 17:22
  2. Decoding an incoming infrared signal: need advice
    Last Post: - 9th May 2008, 17:28
  3. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  5. Rc signal help
    By geckogrotto in forum mel PIC BASIC Pro
    Last Post: - 27th August 2006, 01:10
